I have installed Manjaro on dual boot with Windows today on my laptop and my headphones (connected via headphone jack) aren’t working. Everything else (laptop camera, webcam, and microphone) is. I was running the same config on my PC until a month or so ago and I didn’t have this issue which makes me think it might be related to the laptop. The headphones don’t work when booting from the USB pendrive with the installation media or after installing and updating everything. It’s like they aren’t even being detected. I would love to include the output of some commands but I only know about troubleshooting USB devices, not one connected over headphone jack, so any guidance is appreciated.
Please post system information
inxi -Fazy
and information about audio outputs
pactl list sinks
inxi -Fazy
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=36b4e5b0-9d8a-429b-ae72-2e725136702f rw quiet apparmor=1
security=apparmor resume=UUID=e7b8f73a-8bb8-4396-92cd-1538ffc989f9
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: VALE product: Notebook Classic C140 v: N/A
Mobo: VA_IP3 model: GMLR_V01 serial: <superuser required>
UEFI: American Megatrends v: C140CGMLR_1.0.1 date: 09/09/2021
ID-1: BAT0 charge: 53.2 Wh (100.0%) condition: 53.2/53.2 Wh (100.0%)
volts: 8.5 min: 7.6 model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: Full
Info: Dual Core model: Intel Celeron N4020 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 8 microcode: 1A
cache: L1: 112 KiB L2: 8 MiB
flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4378
Speed: 2681 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 2776 2: 2750
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7.1:6 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Device-3: BKX-210918 SPCA2650 AV Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-8:5 chip-ID: 18cf:29ed
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0401
Device-2: Logitech Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:3 chip-ID: 046d:0ab9
class-ID: 0300 serial: <filter>
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: BKX-210918 SPCA2650 AV Camera type: USB
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlo2 state: up mac: <filter>
Device-2: Intel Ethernet I225-V driver: igc v: kernel port: N/A
bus-ID: 01:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 119.24 GiB used: 15.18 GiB (12.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gloway model: VAL128GS3-M.2 80
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 45 scheme: GPT
ID-1: / raw-size: 46.28 GiB size: 45.25 GiB (97.78%) used: 14.78 GiB (32.7%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-1: swap-1 type: partition size: 4 GiB used: 414.7 MiB (10.1%)
priority: -2 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 213 Uptime: 2h 17m wakeups: 1 Memory: 3.65 GiB
used: 1.83 GiB (50.3%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1257 lib: 341 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
pactl list sinks
Sink #0
State: SUSPENDED
Description: Dummy Output
Driver: module-null-sink.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 15
Mute: no
Volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
Formats:
pcm
