Hello people.
I recently bought a new computer and I’ve installed manjaro gnome, as always do. But I had an unpleasant surprise, the machine don’t recognize the headphones wen I plug them in 3.5 jack. As I say in the title the sound works fine trough HDMI and Bluetooth. I appreciate any help.
inxi -Faz
Kernel: 5.10.83-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6ef7f63a-da33-464c-bc01-6d22053d72af rw quiet splash apparmor=1
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: AZW product: SEi v: N/A serial: <superuser required>
Mobo: AZW model: SEi v: Type2 - Board Version serial: <superuser required>
UEFI: INSYDE v: CB1D_FV106 date: 08/25/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard
status: Discharging
Info: Quad Core model: Intel Core i5-8279U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 38408
Speed: 1049 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 1200 2: 1200
3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200
Type: l1tf
Device-1: Intel CoffeeLake-U GT3e [Iris Plus Graphics 655] driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea5 class-ID: 0300
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Realtek
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.83-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-3:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.36 TiB used: 534.07 GiB (38.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO M.2 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 030 scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 11.35 GiB (29.0%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 423.26 GiB size: 415.54 GiB (98.18%)
used: 176.4 GiB (42.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 27.8 C pch: 46.0 C mobo: N/A
Processes: 257 Uptime: 17m wakeups: 7 Memory: 15.48 GiB
used: 2.36 GiB (15.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1343 lib: 365 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.09
pacmd dump
### Configuration dump generated at Tue Dec 14 23:25:51 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.56WHE1
load-module module-x11-cork-request display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.56WHE1
load-module module-x11-xsmp display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.56WHE1 session_manager=local/Manzaneda:@/tmp/.ICE-unix/8521,unix/Manzaneda:/tmp/.ICE-unix/8521
load-module module-bluez5-device path=/org/bluez/hci0/dev_70_26_05_D9_C3_5D autodetect_mtu=0 output_rate_refresh_interval_ms=500 avrcp_absolute_volume=1
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3.hdmi-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3.hdmi-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.hdmi-stereo yes
set-sink-volume bluez_sink.70_26_05_D9_C3_5D.a2dp_sink 0x6ede
set-sink-mute bluez_sink.70_26_05_D9_C3_5D.a2dp_sink no
suspend-sink bluez_sink.70_26_05_D9_C3_5D.a2dp_sink no
set-source-volume alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor yes
set-source-volume bluez_sink.70_26_05_D9_C3_5D.a2dp_sink.monitor 0x10000
set-source-mute bluez_sink.70_26_05_D9_C3_5D.a2dp_sink.monitor no
suspend-source bluez_sink.70_26_05_D9_C3_5D.a2dp_sink.monitor no
set-card-profile alsa_card.pci-0000_00_1f.3 output:hdmi-stereo
set-card-profile bluez_card.70_26_05_D9_C3_5D a2dp_sink
set-default-sink bluez_sink.70_26_05_D9_C3_5D.a2dp_sink
set-default-source bluez_sink.70_26_05_D9_C3_5D.a2dp_sink.monitor
### EOF
pactl list sinks
Destino #0
Estado: SUSPENDED
Nombre: alsa_output.pci-0000_00_1f.3.hdmi-stereo
Descripción: Audio Interno Digital Stereo (HDMI)
Controlador: module-alsa-card.c
Especificación de muestra: s16le 2ch 44100Hz
Mapa de canales: front-left,front-right
Módulo propietario: 6
Silencio: no
Volumen: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Volumen base: 65536 / 100% / 0,00 dB
Fuente que lo monitoriza: alsa_output.pci-0000_00_1f.3.hdmi-stereo.monitor
Latencia: 0 usec, configurados 0 usec
Indicadores: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Propiedades:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xa1310000 irq 131"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9dc8"
device.product.name = "Cannon Point-LP High Definition Audio Controller"
device.string = "hdmi:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
device.description = "Audio Interno Digital Stereo (HDMI)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Puertos:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, disponible)
Puerto Activo: hdmi-output-0
Formatos:
pcm
Destino #1
Estado: RUNNING
Nombre: bluez_sink.70_26_05_D9_C3_5D.a2dp_sink
Descripción: WI-1000X
Controlador: module-bluez5-device.c
Módulo propietario: 27
Silencio: no
Volumen: front-left: 28382 / 43% / -21,81 dB, front-right: 28382 / 43% / -21,81 dB
balance 0,00
Fuente que lo monitoriza: bluez_sink.70_26_05_D9_C3_5D.a2dp_sink.monitor
Latencia: 54411 usec, configurados 45317 usec
Indicadores: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Propiedades:
bluetooth.protocol = "a2dp_sink"
bluetooth.codec = "sbc"
device.description = "WI-1000X"
device.string = "70:26:05:D9:C3:5D"
device.api = "bluez"
device.bus = "bluetooth"
bluez.path = "/org/bluez/hci0/dev_70_26_05_D9_C3_5D"
bluez.class = "0x000000"
bluez.alias = "WI-1000X"
device.icon_name = "audio-card-bluetooth"
Puertos:
unknown-output: Salida bluetooth (type: Bluetooth, priority: 0, disponible)
Puerto Activo: unknown-output
Formatos:
pcm
I also tried using linux515 kernel but didn’t work of course.
Thanks guys.
