Hello there, first time into the Manjaro World and im facing a crucial issue with internal sound that prevent me from participating on online curses and learning/discussing online.
As the title says i have no sound from Internal hardware by using a set of Panasonic headphones with microphone (3.5 mm jack) which work perfectly on other Debian based distros and Ms Windows as well.
Speakers working, plug in the head phones, they are recognized, the notebook switches automatically to them but no sound.
Distro: KDE Manjaro 21.2.0, on 5.13.19-2 Kernel
By giving the command alsamixer i got back:
card:Pulseaudio
chip:Pulsaudio
default0 HDA INTEL HDMI
default1 HDA INTEL PCH (headphone is not muted)
Kernel v5.13 has been marked End Of Life in update announcements for some time and will likely be dropped completely from Manjaro soon
Kernel v5.14.21-2 has been marked End Of Life in Testing branch and will be marked similar when it lands in Stable branch
I suggest you install kernel v5.15 using Manjaro Settings Manager GUI
( manjaro-settings-manager -m msm_kernel )
OR use these terminal commands to install new kernel and remove old one
I installed Kernel 5.15 which is currently running of my system, and “Sound Server-4: PipeWire v: 0.3.40 running” set it to “no” by given the above command.
Nonetheless, the issue remains, i have still no sound from internal Audio ( I have rebooted 2 times)
in addition , audio kde settings show an inactive internal card as well as an inactive profile with no further options to choose
Is there a way to set front headphone jack as the default audio device in Manjaro and may solve this issue?
Is the Audio Realtek ALC283 codec responsible for it?
