I have possibly tried everything, including downgrading to stable kernel 5.15, but nothing has changed my bugged jack software, maybe you could help me?
- inxi -Faz
Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=6173103c-429a-429b-bd10-c08d5a712a55 rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HONOR product: BBR-WAX9 v: M1050
serial: <superuser required>
Mobo: HONOR model: BBR-WAX9-PCB v: M1050 serial: <superuser required>
UEFI: HONOR v: 3.15 date: 02/22/2022
ID-1: BAT1 charge: 42.0 Wh (100.0%) condition: 42.0/41.6 Wh (101.1%)
volts: 13.1 min: 11.5 model: Sunwoda-H HB4692J5ECW-31 type: Li-ion
serial: <filter> status: full cycles: 4
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 789 high: 800 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 734 4: 800
5: 800 6: 800 7: 800 8: 778 bogomips: 33615
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: QUANTA driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 13d3:5480 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 508x572mm (20.00x22.52")
s-diag: 765mm (30.12")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top
model: ViewSonic VA2418-FHD serial: <filter> built: 2020 res: 1920x1080
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: bottom model: BOE Display 0x0872 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 27.1 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1036 size: 476.94 GiB block-size: physical: 512 B
rev: 21112000 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%) used: 27.06 GiB
(11.3%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%) used: 46.9 MiB
(24.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 39.0 C pch: 34.0 C mobo: N/A
Processes: 277 Uptime: 22m wakeups: 1 Memory: 15.37 GiB used: 5.56 GiB
(36.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1241 pm: pacman pkgs: 1235
libs: 336 tools: pamac pm: flatpak pkgs: 0 pm: snap pkgs: 6 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.22
- sudo alsa-info.sh --upload
!!ALSA Information Script v 0.5.1
!!Script ran on: Sun Oct 23 20:12:42 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: HONOR
Product Name: BBR-WAX9
Product Version: M1050
Firmware Version: 3.15
System SKU: C171
Board Vendor: HONOR
Board Name: BBR-WAX9-PCB
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ESSX8336:00/status 15
/sys/bus/acpi/devices/GXFP51A0:00/status 15
/sys/bus/acpi/devices/GXTP7863:00/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT3403:03/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT34BB:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 15
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/WDT0001:00/status 15
/sys/bus/acpi/devices/device:17/status 15
/sys/bus/acpi/devices/device:23/status 15
!!Kernel Information
Kernel release: 6.0.2-2-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.0.2-2-MANJARO
Library version: 1.2.7.2
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xb121c000 irq 148
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Comet Lake PCH-LP cAVS [8086:02c8]
Subsystem: QUANTA Computer Inc Device [152d:125d]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Conexant CX8070
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x14f11f86
Subsystem Id: 0x152d1422
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
rates [0x540]: 48000 96000 192000
bits [0xa]: 16 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=5, o=0, i=0, unsolicited=1, wake=1
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=1, dir=0, wake=0, sticky=0, data=0, unsol=1
Node 0x10 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name="Master Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name="Master Playback Switch", index=0, device=0
Device: name="CX8070 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-Out vals: [0x43 0x43]
Converter: stream=0, channel=0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x11 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Amp-Out vals: [0x42 0x42]
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x12 [Beep Generator Widget] wcaps 0x70000c: Mono Amp-Out
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x07, nsteps=0x07, stepsize=0x0f, mute=0
Amp-Out vals: [0x03]
Node 0x13 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x4a, nsteps=0x50, stepsize=0x03, mute=1
Amp-In vals: [0x80 0x80] [0x50 0x50] [0x50 0x50] [0x80 0x80]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 4
0x18 0x19 0x1a* 0x15
Node 0x14 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Amp-In vals: [0x45 0x45] [0x4a 0x4a]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 2
0x1a* 0x15
Node 0x15 [Vendor Defined Widget] wcaps 0xf0050b: Stereo Amp-In
Amp-In caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-In vals: [0x4a 0x4a] [0x4a 0x4a]
Connection: 2
0x10* 0x11
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00010010: OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x91170110: [Fixed] Speaker at Int Rear
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x10* 0x11
Node 0x18 [Pin Complex] wcaps 0x40058b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x2f, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x0001133c: IN OUT HP EAPD Detect
Vref caps: HIZ 50 80
EAPD 0x2: EAPD
Pin Default 0x40f001f0: [N/A] Other at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x80: HP VREF_HIZ
Unsolicited: tag=02, enabled=0
Connection: 2
0x10* 0x11
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Pincap 0x00001324: IN Detect
Pin Default 0x03a11030: [Jack] Mic at Ext Left
Conn = 1/8, Color = Black
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=01, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In vals: [0x02 0x02]
Pincap 0x00000024: IN Detect
Pin Default 0x95a60120: [Fixed] Mic at Int Top
Conn = Digital, Color = Unknown
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Unsolicited: tag=00, enabled=0
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x1e [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x1f [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x20 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Node 0x21 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x20
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=15, channel=0
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Power: setting=D3, actual=D3
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Devices: 0
Connection: 3
0x02* 0x03 0x04
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 11 Oct 23 22:59 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 9 Oct 23 22:59 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 10 Oct 23 22:59 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 3 Oct 23 23:11 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 2 Oct 23 23:11 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 8 Oct 23 22:59 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 4 Oct 23 22:59 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 5 Oct 23 22:59 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 6 Oct 23 22:59 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 7 Oct 23 22:59 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 1 Oct 23 22:59 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Oct 23 22:59 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Oct 23 22:59 .
drwxr-xr-x 3 root root 300 Oct 23 22:59 ..
lrwxrwxrwx 1 root root 12 Oct 23 22:59 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: CX8070 Analog [CX8070 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [VA2418-FHD]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xb121c000 irq 148'
Mixer name : 'Conexant CX8070'
Components : 'HDA:14f11f86,152d1422,00100100 HDA:8086280b,80860101,00100000'
Controls : 49
Simple ctrls : 11
Simple mixer control 'Master',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 74
Mono:
Front Left: Playback 67 [91%] [-7.00dB] [on]
Front Right: Playback 67 [91%] [-7.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 251 [98%] [-0.80dB]
Front Right: Playback 251 [98%] [-0.80dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Beep',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Mono: Playback 3 [43%] [-16.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 80 [100%] [6.00dB] [on]
Front Right: Capture 80 [100%] [6.00dB] [on]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 2 [67%] [24.00dB]
Front Right: 2 [67%] [24.00dB]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Beep Playback Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -2800
dbmax 0
dbvalue.0 -1600
control.2 {
iface MIXER
name 'Beep Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface MIXER
name 'Master Playback Volume'
value.0 67
value.1 67
comment {
access 'read write'
type INTEGER
count 2
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 -700
dbvalue.1 -700
control.4 {
iface MIXER
name 'Master Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Capture Volume'
value.0 80
value.1 80
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -7400
dbmax 600
dbvalue.0 600
dbvalue.1 600
control.6 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.7 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 2
value.1 2
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 2400
dbvalue.1 2400
control.8 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 0
dbvalue.1 0
control.9 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.10 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.11 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.12 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.13 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.14 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.17 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.18 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.19 {
iface PCM
device 3
name ELD
value '100008006a10000100000000000000005a6339d75641323431382d464844097f07000000'
comment {
access 'read volatile'
type BYTES
count 36
control.20 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.21 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.23 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.24 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.25 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.26 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.27 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.29 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.30 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.32 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.33 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.35 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.36 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.37 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.38 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.41 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.42 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.43 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.44 {
iface PCM
device 3
value.0 3
value.1 4
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface MIXER
name 'PCM Playback Volume'
value.0 251
value.1 251
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 -80
dbvalue.1 -80
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
bpf_preload
btbcm
btintel
btmtk
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm_buddy
drm_display_helper
dw_dmac
ecdh_generic
ext4
fat
fuse
ghash_clmulni_intel
hid_multitouch
huawei_wmi
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_tcc_cooling
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mei_pxp
mousedev
mtd
nvme
nvme_core
pcspkr
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
rapl
rfcomm
rfkill
rng_core
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_conexant
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_es8316
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
spi_pxa2xx_platform
squashfs
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x17 0x91170110
0x18 0x40f001f0
0x19 0x03a11030
0x1a 0x95a60120
0x21 0x40f001f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.101980] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.101981] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.101981] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 3.965946] ACPI: battery: new extension: Huawei Battery Extension
[ 3.966272] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.992160] mousedev: PS/2 mouse device common for all mice
[ 4.208724] intel_tcc_cooling: Programmable TCC Offset detected
[ 4.236254] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.284371] snd_hda_codec_conexant hdaudioC0D0: CX8070: BIOS auto-probing.
[ 4.285015] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX8070: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 4.285019] snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.285020] snd_hda_codec_conexant hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.285022] snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
[ 4.285023] snd_hda_codec_conexant hdaudioC0D0: inputs:
[ 4.285023] snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x1a
[ 4.285025] snd_hda_codec_conexant hdaudioC0D0: Mic=0x19
[ 4.335695] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 4.335729] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 4.335757] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 4.335785] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 4.335812] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 4.335838] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 5.302232] input: Kensington Kensington Expert Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:047D:1020.0002/input/input20
my laptop is link_to_store
inxi -Aa
what do you suggest to do?
