HDMI to TV shows a blank screen
When I plug in my TV through HDMI, the TV is just blank. In the display settings the display mode is Mirror. When I try to change it to Join Displays my laptop screen blinks and goes back to login. When I log in it goes back as if nothing happened. TV is still blank, display settings goes back to Mirror.
Please refer to your TV’s manual and fix the resolution to something (I.E. probably turn off “auto-negotiation” somewhere in its settings) because what is probably happening is the TV asking the Display adapter: “What resolution do you want” and the display adapter asking “What resolution can you give?” and the TV responding “What resolution do you want” and the display adapter asking “What resolution can you give?” and the TV responding … ad infinitum.
Which is great if you want to watch HD and SD TV channels and the TV auto-switching resolutions on the go, but not so good when hooking up a computer…
:sob:
Thanks for the suggestion but the TV doesn’t have any options like that.
Then you cannot use it as a monitor…
Having said that, as you did not provide much information, it could be a number of things, so please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
and provide at least the output to:
inxi --admin --verbosity=7 --filter --no-host
xrandr
(Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:innocent:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Apologies for the lack of info. Here’s what I have:
  Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=260c331a-ce37-421e-b75f-696a4df21616 rw
  modprobe_blacklist=iTCO_wdt quiet
  resume=UUID=8b3f4d8e-89ca-47ef-800c-08fce76aa125 udev.log_priority=3
  Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
  serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
  UEFI [Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
  ID-1: BAT0 charge: 51.5 Wh condition: 62.1/60.0 Wh (104%) volts: 16.6/15.4
  model: Celxpert L19C4PC0 type: Li-poly serial: <filter>
  status: Discharging cycles: 23
  RAM: total: 7.22 GiB used: 3.26 GiB (45.2%)
  RAM Report:
  Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600103 L2 cache: 4096 KiB bogomips: 92666
  Speed: 1399 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
  1: 1398 2: 1641 3: 1397 4: 1397 5: 1394 6: 1396 7: 1397 8: 1397 9: 1376
  10: 1389 11: 1397 12: 1372 13: 1367 14: 1307 15: 1397 16: 1397
  f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
  rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
  sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
  tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
  driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1f95
  Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
  bus ID: 05:00.0 chip ID: 1002:1636
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
  bus ID: 1-3:2 chip ID: 04f2:b6c2 serial: <filter>
  Display: x11 server: X.org 1.20.8 compositor: gnome-shell
  driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa resolution: <xdpyinfo missing>
  OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.6 direct render: Yes
  Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x
  bus ID: 05:00.5 chip ID: 1022:15e2
  Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.8.3-2-MANJARO
  vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
  chip ID: 10ec:8168
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
  bus ID: 04:00.0 chip ID: 8086:2723
  IF: wlp4s0 state: down mac: <filter>
  Local Storage: total: 476.94 GiB used: 84.69 GiB (17.8%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2
  size: 476.94 GiB block size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 3L1QEXF7 scheme: MBR
  ID-1: / raw size: 468.13 GiB size: 459.79 GiB (98.22%)
  used: 84.69 GiB (18.4%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
  uuid: 260c331a-ce37-421e-b75f-696a4df21616
  ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p2 label: N/A
  uuid: 8b3f4d8e-89ca-47ef-800c-08fce76aa125
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Device-1: 1-3:2 info: Chicony Integrated Camera type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b6c2
  serial: <filter>
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
  chip ID: 05e3:0610
  Hub: 3-1.1:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  chip ID: 1a40:0101
  Device-1: 3-1.1.2:6 info: Lenovo type: Mouse,Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  chip ID: 17ef:60e4
  Device-2: 3-1.1.3:7 info: China Resource Semico Keyboard
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s chip ID: 1a2c:2124
  Device-3: 3-3:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
  Device-4: 3-4:5 info: Integrated Express ITE Device(8910) type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  chip ID: 048d:c100
  Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  Hub: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
  chip ID: 05e3:0620
  System Temperatures: cpu: 36.9 C mobo: N/A gpu: amdgpu temp: 36 C
  Processes: 403 Uptime: 2h 43m Init: systemd v: 246 Compilers: gcc: 10.2.0
  Packages: 1262 pacman: 1255 lib: 434 flatpak: 7 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.1.05
xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
    eDP connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
       1920x1080    120.21*+
       1680x1050    120.21
       1280x1024    120.21
       1440x900     120.21
       1280x800     120.21
       1280x720     120.21
       1024x768     120.21
       800x600      120.21
       640x480      120.21
    DP-1-0 disconnected
    DP-1-1 disconnected
    HDMI-1-0 connected primary 1920x1080+0+0 1063mm x 598mm
       1920x1080     60.00*+  59.94    50.00    29.97    23.98
       1680x1050     59.95
       1600x900      60.00
       1280x1024     60.02
       1280x720      60.00    59.94    50.00    29.97    23.98
       1152x864      75.00
       1024x768      60.00
       800x600       60.32
       720x576       50.00
       720x480       59.94
       640x480       59.94    59.93
    DP-1-2 disconnected
You have both nVidia and AMD drivers loaded:
Which one are you using and how do you switch between those (as I’m unfamiliar with such a setup) as a Lenovo Legion 5 drives its HDMI port through the nVidia only…
The TV seems to be connected, so it’s not a cabling issue:
With the hybrid drivers it’s supposed to switch between both automatically. So I would assume that the AMD GPU is being used unless I run a program with prime-run then it switches to the Nvidia GPU like I do with games.
Is there a way to tell which one is being used at any given moment?
That’s the issue: IIRC the HDMI port on a Lenovo is driven by the nVidia card only, so you need to “switch” to nVidia only to have the TV work as the TV is hooked up to the HDMI port…
As I’m running in pure nVidia mode, I can only:
  • point you to the Reverse PRIME article
    OR
  • I can help you get rid of the AMD driver and run in pure nVidia mode which doesn’t pose any of these problems and the way I’m running as I like simplicity…
:innocent:
Bummer. I guess I’ll have to look for other options. But thanks anyway for your help.
Looking at the names of the monitors, I’d say reverse prime is active. Can you share the output of xrandr --listproviders?
I don’t think removing the AMD driver is particularly helpful. An appropriate Xorg configuration could achieve the same thing without removing anything.
It’s the way I run and have never had any issues (except less battery life if I push the nVidia really hard) but it’s up to the OP to decide which kind of solution he/she prefers…
mhwd --listinstalled
> Installed PCI configs:
    video-nvidia-440xx            2019.10.25               false            PCI
:innocent:
~ >>> xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x54 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 1 associated providers: 1 name:Unknown AMD Radeon GPU @ pci:0000:05:00.0
Provider 1: id: 0x1f6 cap: 0x2, Sink Output crtcs: 4 outputs: 4 associated providers: 1 name:NVIDIA-G0
As expected, “reverse PRIME” is active. Can you try to connect the TV again, and after it goes to login, please share the Xorg logs which are in ~/.local/share/xorg/?
[    11.404] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    11.404] _XSERVTransMakeAllCOTSServerListeners: server already running
[    11.404] (--) Log file renamed from "/home/magicpotion/.local/share/xorg/Xorg.pid-1615.log" to "/home/magicpotion/.local/share/xorg/Xorg.1.log"
[    11.404] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    11.405]
X.Org X Server 1.20.8
[    11.405] Build Operating System: Linux Manjaro Linux
[    11.405] Current Operating System: Linux magicpotion 5.6.15-1-MANJARO #1 SMP PREEMPT Wed May 27 20:38:56 UTC 2020 x86_64
[    11.405] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=260c331a-ce37-421e-b75f-696a4df21616 rw quiet resume=UUID=8b3f4d8e-89ca-47ef-800c-08fce76aa125 udev.log_priority=3
[    11.405] Build Date: 03 June 2020  10:02:55AM
[    11.405]
[    11.405] Current version of pixman: 0.40.0
[    11.405] 	Before reporting problems, check http://wiki.x.org
[    11.405] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.405] (==) Log file: "/home/magicpotion/.local/share/xorg/Xorg.1.log", Time: Mon Aug 31 18:49:35 2020
[    11.405] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.405] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.405] (==) No Layout section.  Using the first Screen section.
[    11.405] (==) No screen section available. Using defaults.
[    11.405] (**) |-->Screen "Default Screen Section" (0)
[    11.406] (**) |   |-->Monitor "<default monitor>"
[    11.406] (==) No monitor specified for screen "Default Screen Section".
[    11.406] (==) Automatically adding devices
[    11.406] (==) Automatically enabling devices
[    11.406] (==) Automatically adding GPU devices
[    11.406] (==) Automatically binding GPU devices
[    11.406] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.406] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    11.406] 	Entry deleted from font path.
[    11.406] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    11.406] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    11.406] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    11.406] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    11.406] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    11.406] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    11.406] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.406] (II) The server relies on udev to provide the list of input devices.
[    11.406] (II) Module ABI versions:
[    11.406] 	X.Org ANSI C Emulation: 0.4
[    11.406] 	X.Org Video Driver: 24.1
[    11.406] 	X.Org XInput driver : 24.1
[    11.406] 	X.Org Server Extension : 10.0
[    11.407] (++) using VT number 2
[    11.412] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    11.413] (II) xfree86: Adding drm device (/dev/dri/card1)
[    11.414] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[    11.415] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.416] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[    11.421] (--) PCI: (1@0:0:0) 10de:1f95:17aa:3a3e rev 161, Mem @ 0xc1000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[    11.421] (--) PCI:*(5@0:0:0) 1002:1636:17aa:3a3e rev 198, Mem @ 0xb0000000/268435456, 0xc0000000/2097152, 0xc2500000/524288, I/O @ 0x00001000/256, BIOS @ 0x????????/131072
[    11.421] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    11.421] (II) LoadModule: "glx"
[    11.421] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.423] (II) Module glx: vendor="X.Org Foundation"
[    11.423] 	compiled for 1.20.8, module version = 1.0.0
[    11.423] 	ABI class: X.Org Server Extension, version 10.0
[    11.423] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[    11.423] 	loading driver: amdgpu
[    11.423] (==) Matched amdgpu as autoconfigured driver 0
[    11.423] (==) Matched ati as autoconfigured driver 1
[    11.423] (==) Matched nouveau as autoconfigured driver 2
[    11.423] (==) Matched nv as autoconfigured driver 3
[    11.423] (==) Matched modesetting as autoconfigured driver 4
[    11.423] (==) Matched fbdev as autoconfigured driver 5
[    11.423] (==) Matched vesa as autoconfigured driver 6
[    11.423] (==) Assigned the driver to the xf86ConfigLayout
[    11.423] (II) LoadModule: "amdgpu"
[    11.423] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    11.424] (II) Module amdgpu: vendor="X.Org Foundation"
[    11.424] 	compiled for 1.20.8, module version = 19.1.0
[    11.424] 	Module class: X.Org Video Driver
[    11.424] 	ABI class: X.Org Video Driver, version 24.1
[    11.424] (II) LoadModule: "ati"
[    11.424] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    11.424] (II) Module ati: vendor="X.Org Foundation"
[    11.425] (II) LoadModule: "nouveau"
[    11.425] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    11.426] (II) Module nouveau: vendor="X.Org Foundation"
[    11.426] 	compiled for 1.20.8, module version = 1.0.16
[    11.426] 	Module class: X.Org Video Driver
[    11.426] 	ABI class: X.Org Video Driver, version 24.1
[    11.426] (II) LoadModule: "nv"
[    11.426] (WW) Warning, couldn't open module nv
[    11.426] (EE) Failed to load module "nv" (module does not exist, 0)
[    11.426] (II) LoadModule: "modesetting"
[    11.426] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.426] (II) Module modesetting: vendor="X.Org Foundation"
[    11.426] 	compiled for 1.20.8, module version = 1.20.8
[    11.426] (II) LoadModule: "fbdev"
[    11.427] (WW) Warning, couldn't open module fbdev
[    11.427] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    11.427] (II) LoadModule: "vesa"
[    11.427] (WW) Warning, couldn't open module vesa
[    11.427] (EE) Failed to load module "vesa" (module does not exist, 0)
[    11.427] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[    11.427] (II) NOUVEAU driver
[    11.427] (II) NOUVEAU driver for NVIDIA chipset families :
[    11.427] 	RIVA TNT            (NV04)
[    11.427] 	RIVA TNT2           (NV05)
[    11.427] 	GeForce 256         (NV10)
[    11.427] 	GeForce 2           (NV11, NV15)
[    11.427] 	GeForce 4MX         (NV17, NV18)
[    11.427] 	GeForce 3           (NV20)
[    11.427] 	GeForce 4Ti         (NV25, NV28)
[    11.427] 	GeForce FX          (NV3x)
[    11.427] 	GeForce 6           (NV4x)
[    11.427] 	GeForce 7           (G7x)
[    11.427] 	GeForce 8           (G8x)
[    11.427] 	GeForce 9           (G9x)
[    11.427] 	GeForce GTX 2xx/3xx (GT2xx)
[    11.427] 	GeForce GTX 4xx/5xx (GFxxx)
[    11.427] 	GeForce GTX 6xx/7xx (GKxxx)
[    11.427] 	GeForce GTX 9xx     (GMxxx)
[    11.427] 	GeForce GTX 10xx    (GPxxx)
[    11.427] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.430] (WW) Falling back to old probe method for modesetting
[    11.430] (II) [drm] nouveau interface version: 1.3.1
[    11.430] (EE) Unknown chipset: NV167
[    11.430] (II) modeset(G0): using drv /dev/dri/card1
[    11.430] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    11.430] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    11.430] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[    11.430] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    11.430] (==) AMDGPU(0): Default visual is TrueColor
[    11.431] (==) AMDGPU(0): RGB weight 888
[    11.431] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[    11.431] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[    11.431] (II) Loading sub module "fb"
[    11.431] (II) LoadModule: "fb"
[    11.431] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.431] (II) Module fb: vendor="X.Org Foundation"
[    11.431] 	compiled for 1.20.8, module version = 1.0.0
[    11.431] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.431] (II) Loading sub module "dri2"
[    11.431] (II) LoadModule: "dri2"
[    11.431] (II) Module "dri2" already built-in
[    11.499] (II) Loading sub module "glamoregl"
[    11.499] (II) LoadModule: "glamoregl"
[    11.499] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.501] (II) Module glamoregl: vendor="X.Org Foundation"
[    11.501] 	compiled for 1.20.8, module version = 1.0.1
[    11.501] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.508] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.36.0, 5.6.15-1-MANJARO, LLVM 10.0.0)
[    11.508] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[    11.508] (==) AMDGPU(0): TearFree property default: auto
[    11.508] (==) AMDGPU(0): VariableRefresh: disabled
[    11.508] (II) AMDGPU(0): KMS Pageflipping: enabled
[    11.508] (II) AMDGPU(0): Output eDP-1 has no monitor section
[    11.509] (II) AMDGPU(0): EDID for output eDP-1
[    11.509] (II) AMDGPU(0): Manufacturer: AUO  Model: d1ed  Serial#: 0
[    11.509] (II) AMDGPU(0): Year: 2019  Week: 34
[    11.509] (II) AMDGPU(0): EDID Version: 1.4
[    11.509] (II) AMDGPU(0): Digital Display Input
[    11.509] (II) AMDGPU(0): 8 bits per channel
[    11.509] (II) AMDGPU(0): Digital interface is DisplayPort
[    11.509] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    11.509] (II) AMDGPU(0): Gamma: 2.20
[    11.509] (II) AMDGPU(0): No DPMS capabilities specified
[    11.509] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[    11.509] (II) AMDGPU(0): First detailed timing is preferred mode
[    11.509] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[    11.509] (II) AMDGPU(0): Display is continuous-frequency
[    11.509] (II) AMDGPU(0): redX: 0.560 redY: 0.340   greenX: 0.350 greenY: 0.570
[    11.509] (II) AMDGPU(0): blueX: 0.160 blueY: 0.120   whiteX: 0.313 whiteY: 0.329
[    11.509] (II) AMDGPU(0): Manufacturer's mask: 0
[    11.509] (II) AMDGPU(0): Supported detailed timing:
[    11.509] (II) AMDGPU(0): clock: 285.0 MHz   Image Size:  344 x 193 mm
[    11.509] (II) AMDGPU(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2076 h_border: 0
[    11.509] (II) AMDGPU(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1142 v_border: 0
[    11.509] (II) AMDGPU(0): Unknown vendor-specific block f
[    11.509] (II) AMDGPU(0): Ranges: V min: 60 V max: 120 Hz, H min: 138 H max: 138 kHz, PixClock max 295 MHz
[    11.509] (II) AMDGPU(0):  B156HAN13.1
[    11.509] (II) AMDGPU(0): EDID (in hex):
[    11.509] (II) AMDGPU(0): 	00ffffffffffff0006afedd100000000
[    11.509] (II) AMDGPU(0): 	221d0104a52213780348358f57599229
[    11.509] (II) AMDGPU(0): 	1e505400000001010101010101010101
[    11.509] (II) AMDGPU(0): 	010101010101546f809c70383e406c30
[    11.509] (II) AMDGPU(0): 	aa0058c1100000180000000f00000000
[    11.509] (II) AMDGPU(0): 	00000000000000000020000000fd003c
[    11.509] (II) AMDGPU(0): 	788a8a1d010a202020202020000000fe
[    11.509] (II) AMDGPU(0): 	004231353648414e31332e31200a00a9
[    11.509] (II) AMDGPU(0): Printing probed modes for output eDP-1
[    11.509] (II) AMDGPU(0): Modeline "1920x1080"x120.2  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[    11.509] (II) AMDGPU(0): Modeline "1680x1050"x120.2  285.00  1680 2028 2076 2076  1050 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "1280x1024"x120.2  285.00  1280 2028 2076 2076  1024 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "1440x900"x120.2  285.00  1440 2028 2076 2076  900 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "1280x800"x120.2  285.00  1280 2028 2076 2076  800 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "1280x720"x120.2  285.00  1280 2028 2076 2076  720 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "1024x768"x120.2  285.00  1024 2028 2076 2076  768 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "800x600"x120.2  285.00  800 2028 2076 2076  600 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Modeline "640x480"x120.2  285.00  640 2028 2076 2076  480 1090 1100 1142 -hsync -vsync (137.3 kHz e)
[    11.509] (II) AMDGPU(0): Output eDP-1 connected
[    11.509] (II) AMDGPU(0): Using exact sizes for initial modes
[    11.509] (II) AMDGPU(0): Output eDP-1 using initial mode 1920x1080 +0+0
[    11.509] (II) AMDGPU(0): mem size init: gart size :bf7b6000 vram size: s:1e388000 visible:1e388000
[    11.509] (==) AMDGPU(0): DPI set to (96, 96)
[    11.509] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[    11.509] (II) Loading sub module "ramdac"
[    11.509] (II) LoadModule: "ramdac"
[    11.509] (II) Module "ramdac" already built-in
[    11.510] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    11.510] (==) modeset(G0): RGB weight 888
[    11.510] (==) modeset(G0): Default visual is TrueColor
[    11.510] (II) Loading sub module "glamoregl"
[    11.510] (II) LoadModule: "glamoregl"
[    11.510] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.510] (II) Module glamoregl: vendor="X.Org Foundation"
[    11.510] 	compiled for 1.20.8, module version = 1.0.1
[    11.510] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.516] (II) modeset(G0): Refusing to try glamor on llvmpipe
[    11.517] (EE) modeset(G0): glamor initialization failed
[    11.517] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[    11.517] (II) modeset(G0): Double-buffered shadow updates: off
[    11.568] (II) modeset(G0): Output DP-1-1 has no monitor section
[    11.569] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    11.569] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    11.621] (II) modeset(G0): EDID for output DP-1-1
[    11.622] (II) modeset(G0): EDID for output HDMI-1-1
[    11.622] (II) modeset(G0): EDID for output eDP-1-1
[    11.622] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    11.622] (==) modeset(G0): DPI set to (96, 96)
[    11.622] (II) Loading sub module "fb"
[    11.622] (II) LoadModule: "fb"
[    11.622] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.622] (II) Module fb: vendor="X.Org Foundation"
[    11.622] 	compiled for 1.20.8, module version = 1.0.0
[    11.622] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.622] (II) Loading sub module "shadow"
[    11.622] (II) LoadModule: "shadow"
[    11.622] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    11.623] (II) Module shadow: vendor="X.Org Foundation"
[    11.623] 	compiled for 1.20.8, module version = 1.1.0
[    11.623] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.623] (II) AMDGPU(0): [DRI2] Setup complete
[    11.623] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[    11.623] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[    11.649] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[    11.649] (II) AMDGPU(0): SYNC extension fences enabled
[    11.649] (II) AMDGPU(0): Present extension enabled
[    11.649] (==) AMDGPU(0): DRI3 enabled
[    11.649] (==) AMDGPU(0): Backing store enabled
[    11.649] (II) AMDGPU(0): Direct rendering enabled
[    11.660] (II) AMDGPU(0): Use GLAMOR acceleration.
[    11.660] (II) AMDGPU(0): Acceleration enabled
[    11.660] (==) AMDGPU(0): DPMS enabled
[    11.660] (==) AMDGPU(0): Silken mouse disabled
[    11.660] (II) AMDGPU(0): Set up textured video (glamor)
[    11.662] (==) modeset(G0): Backing store enabled
[    11.662] (==) modeset(G0): Silken mouse disabled
[    11.663] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    11.663] (==) modeset(G0): DPMS enabled
[    11.663] (II) Initializing extension Generic Event Extension
[    11.663] (II) Initializing extension SHAPE
[    11.663] (II) Initializing extension MIT-SHM
[    11.663] (II) Initializing extension XInputExtension
[    11.663] (II) Initializing extension XTEST
[    11.663] (II) Initializing extension BIG-REQUESTS
[    11.663] (II) Initializing extension SYNC
[    11.663] (II) Initializing extension XKEYBOARD
[    11.663] (II) Initializing extension XC-MISC
[    11.663] (II) Initializing extension SECURITY
[    11.663] (II) Initializing extension XFIXES
[    11.663] (II) Initializing extension RENDER
[    11.663] (II) Initializing extension RANDR
[    11.663] (II) Initializing extension COMPOSITE
[    11.663] (II) Initializing extension DAMAGE
[    11.663] (II) Initializing extension MIT-SCREEN-SAVER
[    11.663] (II) Initializing extension DOUBLE-BUFFER
[    11.663] (II) Initializing extension RECORD
[    11.663] (II) Initializing extension DPMS
[    11.663] (II) Initializing extension Present
[    11.663] (II) Initializing extension DRI3
[    11.663] (II) Initializing extension X-Resource
[    11.663] (II) Initializing extension XVideo
[    11.663] (II) Initializing extension XVideo-MotionCompensation
[    11.663] (II) Initializing extension GLX
[    11.666] (II) AIGLX: Loaded and initialized radeonsi
[    11.666] (II) GLX: Initialized DRI2 GL provider for screen 0
[    11.666] (II) Initializing extension XFree86-VidModeExtension
[    11.666] (II) Initializing extension XFree86-DGA
[    11.666] (II) Initializing extension XFree86-DRI
[    11.666] (II) Initializing extension DRI2
[    11.667] (II) modeset(G0): Damage tracking initialized
[    11.667] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[    11.731] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    11.731] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    11.731] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    11.731] (**) Power Button: Applying InputClass "system-keyboard"
[    11.731] (II) LoadModule: "libinput"
[    11.731] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    11.732] (II) Module libinput: vendor="X.Org Foundation"
[    11.732] 	compiled for 1.20.8, module version = 0.30.0
[    11.732] 	Module class: X.Org XInput Driver
[    11.732] 	ABI class: X.Org XInput driver, version 24.1
[    11.732] (II) Using input driver 'libinput' for 'Power Button'
[    11.733] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 23 paused 0
[    11.734] (**) Power Button: always reports core events
[    11.734] (**) Option "Device" "/dev/input/event2"
[    11.734] (**) Option "_source" "server/udev"
[    11.735] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    11.735] (II) event2  - Power Button: device is a keyboard
[    11.735] (II) event2  - Power Button: device removed
[    11.735] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    11.735] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    11.735] (**) Option "xkb_model" "pc105"
[    11.735] (**) Option "xkb_layout" "us"
[    11.736] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    11.736] (II) event2  - Power Button: device is a keyboard
[    11.736] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[    11.736] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    11.736] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    11.736] (**) Video Bus: Applying InputClass "system-keyboard"
[    11.736] (II) Using input driver 'libinput' for 'Video Bus'
[    11.737] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 26 paused 0
[    11.737] (**) Video Bus: always reports core events
[    11.737] (**) Option "Device" "/dev/input/event3"
[    11.738] (**) Option "_source" "server/udev"
[    11.738] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    11.738] (II) event3  - Video Bus: device is a keyboard
[    11.738] (II) event3  - Video Bus: device removed
[    11.738] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input3/event3"
[    11.738] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    11.738] (**) Option "xkb_model" "pc105"
[    11.738] (**) Option "xkb_layout" "us"
[    11.739] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    11.739] (II) event3  - Video Bus: device is a keyboard
[    11.740] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[    11.740] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    11.740] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    11.740] (**) Video Bus: Applying InputClass "system-keyboard"
[    11.740] (II) Using input driver 'libinput' for 'Video Bus'
[    11.741] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 27 paused 0
[    11.741] (**) Video Bus: always reports core events
[    11.741] (**) Option "Device" "/dev/input/event4"
[    11.741] (**) Option "_source" "server/udev"
[    11.742] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[    11.742] (II) event4  - Video Bus: device is a keyboard
[    11.742] (II) event4  - Video Bus: device removed
[    11.742] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input4/event4"
[    11.742] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    11.742] (**) Option "xkb_model" "pc105"
[    11.742] (**) Option "xkb_layout" "us"
[    11.744] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[    11.744] (II) event4  - Video Bus: device is a keyboard
[    11.745] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    11.745] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    11.745] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    11.745] (**) Power Button: Applying InputClass "system-keyboard"
[    11.745] (II) Using input driver 'libinput' for 'Power Button'
[    11.746] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 28 paused 0
[    11.746] (**) Power Button: always reports core events
[    11.746] (**) Option "Device" "/dev/input/event1"
[    11.746] (**) Option "_source" "server/udev"
[    11.747] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    11.747] (II) event1  - Power Button: device is a keyboard
[    11.747] (II) event1  - Power Button: device removed
[    11.747] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    11.747] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    11.747] (**) Option "xkb_model" "pc105"
[    11.747] (**) Option "xkb_layout" "us"
[    11.748] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    11.748] (II) event1  - Power Button: device is a keyboard
[    11.748] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    11.748] (II) No input driver specified, ignoring this device.
[    11.748] (II) This device may have been added with another device file.
[    11.749] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[    11.749] (II) No input driver specified, ignoring this device.
[    11.749] (II) This device may have been added with another device file.
[    11.750] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[    11.750] (II) No input driver specified, ignoring this device.
[    11.750] (II) This device may have been added with another device file.
[    11.750] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[    11.751] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[    11.751] (II) No input driver specified, ignoring this device.
[    11.751] (II) This device may have been added with another device file.
[    11.751] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[    11.753] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event18)
[    11.753] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[    11.753] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[    11.753] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[    11.753] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[    11.754] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 29 paused 0
[    11.754] (**) Integrated Camera: Integrated C: always reports core events
[    11.754] (**) Option "Device" "/dev/input/event18"
[    11.754] (**) Option "_source" "server/udev"
[    11.756] (II) event18 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    11.756] (II) event18 - Integrated Camera: Integrated C: device is a keyboard
[    11.756] (II) event18 - Integrated Camera: Integrated C: device removed
[    11.756] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/input/input20/event18"
[    11.756] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[    11.756] (**) Option "xkb_model" "pc105"
[    11.756] (**) Option "xkb_layout" "us"
[    11.757] (II) event18 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    11.757] (II) event18 - Integrated Camera: Integrated C: device is a keyboard
[    11.757] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/event22)
[    11.757] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[    11.757] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[    11.757] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse'
[    11.758] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 30 paused 0
[    11.758] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: always reports core events
[    11.758] (**) Option "Device" "/dev/input/event22"
[    11.758] (**) Option "_source" "server/udev"
[    11.761] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Mouse
[    11.761] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a pointer
[    11.761] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[    11.761] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input24/event22"
[    11.761] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse" (type: MOUSE, id 11)
[    11.761] (**) Option "AccelerationScheme" "none"
[    11.761] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) selected scheme none/0
[    11.761] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) acceleration factor: 2.000
[    11.761] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: (accel) acceleration threshold: 4
[    11.764] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Mouse
[    11.764] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a pointer
[    11.766] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/mouse2)
[    11.766] (II) No input driver specified, ignoring this device.
[    11.766] (II) This device may have been added with another device file.
[    11.767] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control (/dev/input/event23)
[    11.767] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.767] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.767] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[    11.767] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control'
[    11.768] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 31 paused 0
[    11.768] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: always reports core events
[    11.768] (**) Option "Device" "/dev/input/event23"
[    11.768] (**) Option "_source" "server/udev"
[    11.771] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[    11.771] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device is a keyboard
[    11.771] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device removed
[    11.771] (II) libinput: Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: needs a virtual subdevice
[    11.771] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input25/event23"
[    11.771] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control" (type: MOUSE, id 12)
[    11.771] (**) Option "AccelerationScheme" "none"
[    11.771] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) selected scheme none/0
[    11.771] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[    11.771] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[    11.774] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[    11.774] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device is a keyboard
[    11.776] (II) config/udev: Adding input device Lenovo Lenovo Legion M300 RGB Gaming Mouse (/dev/input/event24)
[    11.776] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[    11.776] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[    11.776] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: Applying InputClass "system-keyboard"
[    11.776] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse'
[    11.777] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 32 paused 0
[    11.777] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse: always reports core events
[    11.777] (**) Option "Device" "/dev/input/event24"
[    11.777] (**) Option "_source" "server/udev"
[    11.780] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Keyboard
[    11.780] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a keyboard
[    11.781] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[    11.781] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.1/0003:17EF:60E4.0004/input/input26/event24"
[    11.781] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse" (type: KEYBOARD, id 13)
[    11.781] (**) Option "xkb_model" "pc105"
[    11.781] (**) Option "xkb_layout" "us"
[    11.784] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: is tagged by udev as: Keyboard
[    11.784] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device is a keyboard
[    11.786] (II) config/udev: Adding input device SEM USB Keyboard (/dev/input/event25)
[    11.786] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    11.786] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    11.786] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[    11.786] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[    11.787] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 33 paused 0
[    11.787] (**) SEM USB Keyboard: always reports core events
[    11.787] (**) Option "Device" "/dev/input/event25"
[    11.787] (**) Option "_source" "server/udev"
[    11.790] (II) event25 - SEM USB Keyboard: is tagged by udev as: Keyboard
[    11.790] (II) event25 - SEM USB Keyboard: device is a keyboard
[    11.790] (II) event25 - SEM USB Keyboard: device removed
[    11.790] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.0/0003:1A2C:2124.0006/input/input27/event25"
[    11.790] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: KEYBOARD, id 14)
[    11.790] (**) Option "xkb_model" "pc105"
[    11.790] (**) Option "xkb_layout" "us"
[    11.793] (II) event25 - SEM USB Keyboard: is tagged by udev as: Keyboard
[    11.793] (II) event25 - SEM USB Keyboard: device is a keyboard
[    11.795] (II) config/udev: Adding input device SEM USB Keyboard Consumer Control (/dev/input/event26)
[    11.795] (**) SEM USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.795] (**) SEM USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.795] (**) SEM USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    11.795] (II) Using input driver 'libinput' for 'SEM USB Keyboard Consumer Control'
[    11.797] (II) systemd-logind: got fd for /dev/input/event26 13:90 fd 34 paused 0
[    11.797] (**) SEM USB Keyboard Consumer Control: always reports core events
[    11.797] (**) Option "Device" "/dev/input/event26"
[    11.797] (**) Option "_source" "server/udev"
[    11.799] (II) event26 - SEM USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    11.799] (II) event26 - SEM USB Keyboard Consumer Control: device is a keyboard
[    11.799] (II) event26 - SEM USB Keyboard Consumer Control: device removed
[    11.799] (II) libinput: SEM USB Keyboard Consumer Control: needs a virtual subdevice
[    11.799] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:1A2C:2124.0007/input/input28/event26"
[    11.800] (II) XINPUT: Adding extended input device "SEM USB Keyboard Consumer Control" (type: MOUSE, id 15)
[    11.800] (**) Option "AccelerationScheme" "none"
[    11.800] (**) SEM USB Keyboard Consumer Control: (accel) selected scheme none/0
[    11.800] (**) SEM USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[    11.800] (**) SEM USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[    11.802] (II) event26 - SEM USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    11.802] (II) event26 - SEM USB Keyboard Consumer Control: device is a keyboard
[    11.803] (II) config/udev: Adding input device SEM USB Keyboard System Control (/dev/input/event27)
[    11.803] (**) SEM USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    11.803] (**) SEM USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    11.803] (**) SEM USB Keyboard System Control: Applying InputClass "system-keyboard"
[    11.803] (II) Using input driver 'libinput' for 'SEM USB Keyboard System Control'
[    11.804] (II) systemd-logind: got fd for /dev/input/event27 13:91 fd 35 paused 0
[    11.804] (**) SEM USB Keyboard System Control: always reports core events
[    11.804] (**) Option "Device" "/dev/input/event27"
[    11.804] (**) Option "_source" "server/udev"
[    11.805] (II) event27 - SEM USB Keyboard System Control: is tagged by udev as: Keyboard
[    11.805] (II) event27 - SEM USB Keyboard System Control: device is a keyboard
[    11.805] (II) event27 - SEM USB Keyboard System Control: device removed
[    11.805] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:1A2C:2124.0007/input/input29/event27"
[    11.805] (II) XINPUT: Adding extended input device "SEM USB Keyboard System Control" (type: KEYBOARD, id 16)
[    11.805] (**) Option "xkb_model" "pc105"
[    11.805] (**) Option "xkb_layout" "us"
[    11.806] (II) event27 - SEM USB Keyboard System Control: is tagged by udev as: Keyboard
[    11.806] (II) event27 - SEM USB Keyboard System Control: device is a keyboard
[    11.807] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event19)
[    11.807] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "evdev keyboard catchall"
[    11.807] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[    11.807] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[    11.807] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[    11.808] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 36 paused 0
[    11.808] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[    11.808] (**) Option "Device" "/dev/input/event19"
[    11.808] (**) Option "_source" "server/udev"
[    11.809] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[    11.809] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[    11.809] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[    11.809] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input21/event19"
[    11.809] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 17)
[    11.809] (**) Option "xkb_model" "pc105"
[    11.809] (**) Option "xkb_layout" "us"
[    11.810] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[    11.810] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[    11.811] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Consumer Control (/dev/input/event20)
[    11.811] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.811] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.811] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[    11.811] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[    11.812] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 37 paused 0
[    11.812] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[    11.812] (**) Option "Device" "/dev/input/event20"
[    11.812] (**) Option "_source" "server/udev"
[    11.813] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[    11.813] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[    11.813] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[    11.813] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: needs a virtual subdevice
[    11.813] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input22/event20"
[    11.813] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: MOUSE, id 18)
[    11.813] (**) Option "AccelerationScheme" "none"
[    11.813] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) selected scheme none/0
[    11.813] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration factor: 2.000
[    11.813] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration threshold: 4
[    11.814] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[    11.814] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[    11.814] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event21)
[    11.814] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[    11.814] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[    11.814] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[    11.814] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[    11.815] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 38 paused 0
[    11.815] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[    11.815] (**) Option "Device" "/dev/input/event21"
[    11.815] (**) Option "_source" "server/udev"
[    11.816] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[    11.816] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[    11.817] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[    11.817] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input23/event21"
[    11.817] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 19)
[    11.817] (**) Option "xkb_model" "pc105"
[    11.817] (**) Option "xkb_layout" "us"
[    11.818] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[    11.818] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[    11.818] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event13)
[    11.818] (II) No input driver specified, ignoring this device.
[    11.818] (II) This device may have been added with another device file.
[    11.818] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event14)
[    11.819] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event15)
[    11.819] (II) No input driver specified, ignoring this device.
[    11.819] (II) This device may have been added with another device file.
[    11.819] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event7)
[    11.819] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[    11.819] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[    11.819] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[    11.819] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[    11.820] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 39 paused 0
[    11.820] (**) Ideapad extra buttons: always reports core events
[    11.820] (**) Option "Device" "/dev/input/event7"
[    11.820] (**) Option "_source" "server/udev"
[    11.821] (II) event7  - Ideapad extra buttons: is tagged by udev as: Keyboard
[    11.821] (II) event7  - Ideapad extra buttons: device is a keyboard
[    11.821] (II) event7  - Ideapad extra buttons: device removed
[    11.821] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input7/event7"
[    11.821] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 20)
[    11.821] (**) Option "xkb_model" "pc105"
[    11.821] (**) Option "xkb_layout" "us"
[    11.822] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/event16)
[    11.822] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "evdev pointer catchall"
[    11.822] (**) MSFT0001:00 04F3:3140 Mouse: Applying InputClass "libinput pointer catchall"
[    11.822] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Mouse'
[    11.823] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 40 paused 0
[    11.823] (**) MSFT0001:00 04F3:3140 Mouse: always reports core events
[    11.823] (**) Option "Device" "/dev/input/event16"
[    11.823] (**) Option "_source" "server/udev"
[    11.824] (II) event16 - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[    11.824] (II) event16 - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[    11.825] (II) event16 - MSFT0001:00 04F3:3140 Mouse: device removed
[    11.825] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input18/event16"
[    11.825] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Mouse" (type: MOUSE, id 21)
[    11.825] (**) Option "AccelerationScheme" "none"
[    11.825] (**) MSFT0001:00 04F3:3140 Mouse: (accel) selected scheme none/0
[    11.825] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration factor: 2.000
[    11.825] (**) MSFT0001:00 04F3:3140 Mouse: (accel) acceleration threshold: 4
[    11.825] (II) event16 - MSFT0001:00 04F3:3140 Mouse: is tagged by udev as: Mouse Pointingstick
[    11.826] (II) event16 - MSFT0001:00 04F3:3140 Mouse: device is a pointer
[    11.827] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Mouse (/dev/input/mouse0)
[    11.827] (II) No input driver specified, ignoring this device.
[    11.827] (II) This device may have been added with another device file.
[    11.827] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/event17)
[    11.827] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "evdev touchpad catchall"
[    11.827] (**) MSFT0001:00 04F3:3140 Touchpad: Applying InputClass "libinput touchpad catchall"
[    11.827] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3140 Touchpad'
[    11.828] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 41 paused 0
[    11.828] (**) MSFT0001:00 04F3:3140 Touchpad: always reports core events
[    11.828] (**) Option "Device" "/dev/input/event17"
[    11.828] (**) Option "_source" "server/udev"
[    11.830] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[    11.832] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[    11.832] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: device removed
[    11.833] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3140.0001/input/input19/event17"
[    11.833] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3140 Touchpad" (type: TOUCHPAD, id 22)
[    11.834] (**) Option "AccelerationScheme" "none"
[    11.834] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) selected scheme none/0
[    11.834] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration factor: 2.000
[    11.834] (**) MSFT0001:00 04F3:3140 Touchpad: (accel) acceleration threshold: 4
[    11.835] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: is tagged by udev as: Touchpad
[    11.836] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: device is a touchpad
[    11.837] (II) config/udev: Adding input device MSFT0001:00 04F3:3140 Touchpad (/dev/input/mouse1)
[    11.837] (II) No input driver specified, ignoring this device.
[    11.837] (II) This device may have been added with another device file.
[    11.837] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event5)
[    11.837] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    11.837] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    11.837] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    11.837] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    11.838] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 42 paused 0
[    11.838] (**) AT Translated Set 2 keyboard: always reports core events
[    11.838] (**) Option "Device" "/dev/input/event5"
[    11.838] (**) Option "_source" "server/udev"
[    11.839] (II) event5  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    11.839] (II) event5  - AT Translated Set 2 keyboard: device is a keyboard
[    11.841] (II) event5  - AT Translated Set 2 keyboard: device removed
[    11.841] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input5/event5"
[    11.841] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 23)
[    11.841] (**) Option "xkb_model" "pc105"
[    11.841] (**) Option "xkb_layout" "us"
[    11.843] (II) event5  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    11.843] (II) event5  - AT Translated Set 2 keyboard: device is a keyboard
[    11.845] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    11.845] (II) No input driver specified, ignoring this device.
[    11.845] (II) This device may have been added with another device file.
[    11.847] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.847] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.847] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[    11.847] (II) Using input driver 'libinput' for 'Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control'
[    11.847] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[    11.847] (**) Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: always reports core events
[    11.847] (**) Option "Device" "/dev/input/event23"
[    11.847] (**) Option "_source" "_driver/libinput"
[    11.847] (II) libinput: Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: is a virtual subdevice
[    11.848] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.2/3-1.1.2:1.0/0003:17EF:60E4.0003/input/input25/event23"
[    11.848] (II) XINPUT: Adding extended input device "Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control" (type: KEYBOARD, id 24)
[    11.848] (**) Option "xkb_model" "pc105"
[    11.848] (**) Option "xkb_layout" "us"
[    11.848] (**) SEM USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.848] (**) SEM USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.848] (**) SEM USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    11.848] (II) Using input driver 'libinput' for 'SEM USB Keyboard Consumer Control'
[    11.848] (II) systemd-logind: returning pre-existing fd for /dev/input/event26 13:90
[    11.848] (**) SEM USB Keyboard Consumer Control: always reports core events
[    11.848] (**) Option "Device" "/dev/input/event26"
[    11.848] (**) Option "_source" "_driver/libinput"
[    11.848] (II) libinput: SEM USB Keyboard Consumer Control: is a virtual subdevice
[    11.848] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.1/0003:1A2C:2124.0007/input/input28/event26"
[    11.848] (II) XINPUT: Adding extended input device "SEM USB Keyboard Consumer Control" (type: KEYBOARD, id 25)
[    11.848] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.848] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.848] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "system-keyboard"
[    11.848] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[    11.848] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[    11.848] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[    11.848] (**) Option "Device" "/dev/input/event20"
[    11.848] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: is a virtual subdevice
[    11.848] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input22/event20"
[    11.848] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: KEYBOARD, id 26)
[    12.290] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[    12.290] (II) AMDGPU(0): Using EDID range info for horizontal sync
[    12.290] (II) AMDGPU(0): Using EDID range info for vertical refresh
[    12.290] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    12.290] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[    12.290] (II) AMDGPU(0): Using hsync ranges from config file
[    12.290] (II) AMDGPU(0): Using vrefresh ranges from config file
[    21.892] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[    21.892] (II) AMDGPU(0): Using hsync ranges from config file
[    21.892] (II) AMDGPU(0): Using vrefresh ranges from config file
[    21.892] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    21.892] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[   436.678] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[   436.678] (II) AMDGPU(0): Using hsync ranges from config file
[   436.678] (II) AMDGPU(0): Using vrefresh ranges from config file
[   436.678] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   436.678] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  1056.452] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  1056.452] (II) AMDGPU(0): Using hsync ranges from config file
[  1056.452] (II) AMDGPU(0): Using vrefresh ranges from config file
[  1056.452] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  1056.452] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  1056.453] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  1056.453] (II) AMDGPU(0): Using hsync ranges from config file
[  1056.453] (II) AMDGPU(0): Using vrefresh ranges from config file
[  1056.453] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  1056.453] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  1072.752] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  1072.752] (II) AMDGPU(0): Using hsync ranges from config file
[  1072.752] (II) AMDGPU(0): Using vrefresh ranges from config file
[  1072.752] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  1072.752] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  1072.753] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  1072.753] (II) AMDGPU(0): Using hsync ranges from config file
[  1072.753] (II) AMDGPU(0): Using vrefresh ranges from config file
[  1072.753] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  1072.753] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  2764.576] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  2764.576] (II) AMDGPU(0): Using hsync ranges from config file
[  2764.576] (II) AMDGPU(0): Using vrefresh ranges from config file
[  2764.576] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  2764.576] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6107.109] (EE) client bug: timer event22 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[  6107.109] (EE) client bug: timer event22 debounce short: scheduled expiry is in the past (-20ms), your system is too slow
[  6508.139] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6508.139] (II) AMDGPU(0): Using hsync ranges from config file
[  6508.139] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6508.139] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6508.139] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6508.140] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6508.140] (II) AMDGPU(0): Using hsync ranges from config file
[  6508.140] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6508.140] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6508.140] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6575.072] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6575.072] (II) AMDGPU(0): Using hsync ranges from config file
[  6575.072] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6575.072] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6575.072] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6716.127] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6716.127] (II) AMDGPU(0): Using hsync ranges from config file
[  6716.127] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6716.127] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6716.127] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6716.128] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6716.128] (II) AMDGPU(0): Using hsync ranges from config file
[  6716.128] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6716.128] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6716.128] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6742.390] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6742.390] (II) AMDGPU(0): Using hsync ranges from config file
[  6742.390] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6742.390] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6742.390] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6742.391] (II) AMDGPU(0): EDID vendor "AUO", prod id 53741
[  6742.391] (II) AMDGPU(0): Using hsync ranges from config file
[  6742.391] (II) AMDGPU(0): Using vrefresh ranges from config file
[  6742.391] (II) AMDGPU(0): Printing DDC gathered Modelines:
[  6742.391] (II) AMDGPU(0): Modeline "1920x1080"x0.0  285.00  1920 2028 2076 2076  1080 1090 1100 1142 -hsync -vsync (137.3 kHz eP)
[  6994.976] (**) Option "fd" "23"
[  6994.976] (II) event2  - Power Button: device removed
[  6994.976] (**) Option "fd" "26"
[  6994.976] (II) event3  - Video Bus: device removed
[  6994.976] (**) Option "fd" "27"
[  6994.976] (II) event4  - Video Bus: device removed
[  6994.976] (**) Option "fd" "28"
[  6994.976] (II) event1  - Power Button: device removed
[  6994.976] (**) Option "fd" "29"
[  6994.976] (II) event18 - Integrated Camera: Integrated C: device removed
[  6994.976] (**) Option "fd" "30"
[  6994.976] (II) event22 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[  6994.976] (**) Option "fd" "31"
[  6994.976] (**) Option "fd" "32"
[  6994.976] (II) event24 - Lenovo Lenovo Legion M300 RGB Gaming Mouse: device removed
[  6994.976] (**) Option "fd" "33"
[  6994.976] (II) event25 - SEM USB Keyboard: device removed
[  6994.976] (**) Option "fd" "34"
[  6994.976] (**) Option "fd" "35"
[  6994.976] (II) event27 - SEM USB Keyboard System Control: device removed
[  6994.976] (**) Option "fd" "36"
[  6994.976] (II) event19 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[  6994.976] (**) Option "fd" "37"
[  6994.976] (**) Option "fd" "38"
[  6994.976] (II) event21 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[  6994.976] (**) Option "fd" "39"
[  6994.976] (II) event7  - Ideapad extra buttons: device removed
[  6994.976] (**) Option "fd" "40"
[  6994.976] (II) event16 - MSFT0001:00 04F3:3140 Mouse: device removed
[  6994.976] (**) Option "fd" "41"
[  6994.976] (II) event17 - MSFT0001:00 04F3:3140 Touchpad: device removed
[  6994.976] (**) Option "fd" "42"
[  6994.977] (II) event5  - AT Translated Set 2 keyboard: device removed
[  6994.977] (**) Option "fd" "31"
[  6994.977] (II) event23 - Lenovo Lenovo Legion M300 RGB Gaming Mouse Consumer Control: device removed
[  6994.977] (**) Option "fd" "34"
[  6994.977] (II) event26 - SEM USB Keyboard Consumer Control: device removed
[  6994.977] (**) Option "fd" "37"
[  6994.977] (II) event20 - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[  6994.978] (II) UnloadModule: "libinput"
[  6994.978] (II) systemd-logind: not releasing fd for 13:84, still in use
[  6994.978] (II) systemd-logind: not releasing fd for 13:90, still in use
[  6994.978] (II) systemd-logind: not releasing fd for 13:87, still in use
[  6994.978] (II) systemd-logind: releasing fd for 13:69
[  6995.047] (II) UnloadModule: "libinput"
[  6995.047] (II) systemd-logind: releasing fd for 13:81
[  6995.081] (II) UnloadModule: "libinput"
[  6995.081] (II) systemd-logind: releasing fd for 13:80
[  6995.101] (II) UnloadModule: "libinput"
[  6995.101] (II) systemd-logind: releasing fd for 13:71
[  6995.124] (II) UnloadModule: "libinput"
[  6995.124] (II) systemd-logind: releasing fd for 13:85
[  6995.161] (II) UnloadModule: "libinput"
[  6995.161] (II) systemd-logind: releasing fd for 13:84
[  6995.217] (II) UnloadModule: "libinput"
[  6995.217] (II) systemd-logind: releasing fd for 13:83
[  6995.234] (II) UnloadModule: "libinput"
[  6995.234] (II) systemd-logind: releasing fd for 13:91
[  6995.364] (II) UnloadModule: "libinput"
[  6995.364] (II) systemd-logind: releasing fd for 13:90
[  6995.405] (II) UnloadModule: "libinput"
[  6995.405] (II) systemd-logind: releasing fd for 13:89
[  6995.433] (II) UnloadModule: "libinput"
[  6995.433] (II) systemd-logind: releasing fd for 13:88
[  6995.492] (II) UnloadModule: "libinput"
[  6995.492] (II) systemd-logind: releasing fd for 13:87
[  6995.566] (II) UnloadModule: "libinput"
[  6995.566] (II) systemd-logind: releasing fd for 13:86
[  6995.674] (II) UnloadModule: "libinput"
[  6995.674] (II) systemd-logind: releasing fd for 13:82
[  6995.777] (II) UnloadModule: "libinput"
[  6995.777] (II) systemd-logind: releasing fd for 13:65
[  6995.841] (II) UnloadModule: "libinput"
[  6995.841] (II) systemd-logind: releasing fd for 13:68
[  6995.964] (II) UnloadModule: "libinput"
[  6995.964] (II) systemd-logind: releasing fd for 13:67
[  6996.032] (II) UnloadModule: "libinput"
[  6996.032] (II) systemd-logind: releasing fd for 13:66
[  6996.078] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[  6996.078] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[  6996.078] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[  6996.079] (II) Server terminated successfully (0). Closing log file.
I’m kind of confused about Reverse Prime. Does that mean that the system is using the Nvidia GPU by default? If so, how can I make it so that the default is the AMD? Also, if Reverse Prime is active, it doesn’t seem to affect games that I run with prime-run.
It means that the AMD GPU does the rendering, but it is possible to pass the image through the nvidia GPU to an external display. So both GPUs are active, but the nvidia one isn’t really doing anything, just taking and image, and sending it out via its output(s).
Ok, I got confused. I thought Reverse Prime would be the opposite. And just to be sure, prime-run will force the Nvidia to be used right?
Yes.
Now that I look at the Xorg log… it seems the nvidia X driver is not installed. That’d explain the issue. Are you sure that’s the latest log you have? What’s the output of sudo mhwd -li?
When I looked at ~/.local/share/xorg/ I used the Xorg.1.log file. The other one is Xorg.1.log.old so I assume that’s the latest. I even shutdown before starting up, logging back in and looking at the log. When I installed the drivers I just used the Auto Install Proprietary Driver in the Manjaro Settings Manager.
sudo mhwd -li
> Installed PCI configs:
video-hybrid-amd-nvidia-450xx-prime            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
Also, should I be concerned about the warning about no installed USB configs?
Could you run pacman -Ss nvidia | grep installed. And I don’t think you should be worried about the “no USB configs”.
