Hi,
When I connect my external monitor via HDMI the system reacts with a screen where you choose what to do (switch, extend, etc), but the monitor receives no signal and goes back to standby. The device is tested and works fine with my older laptop also on Manjaro.
Here’s my inxi:
System: Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=adebe5df-56a6-44e4-9f48-03451392bc85 ro quiet
udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP ENVY Laptop 15-ep0xxx v: N/A serial: Chassis: type: 10
serial:
Mobo: HP model: 878D v: 18.32 serial: UEFI: AMI v: F.05 date: 12/29/2020
Battery: ID-1: BAT0 charge: 57.6 Wh condition: 78.5/78.5 Wh (100%) volts: 11.9/11.6 model: HP Primary type: Li-ion
serial: status: Discharging cycles: 29
Memory: RAM: total: 15.41 GiB used: 4.64 GiB (30.1%)
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165)
stepping: 2 microcode: E0 L2 cache: 12 MiB bogomips: 62431
Speed: 891 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 891 2: 860 3: 853 4: 850 5: 800 6: 800 7: 800 8: 814
9: 800 10: 856 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2
bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9bc4
class ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard driver: nvidia v: 460.56
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:2191 class ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 1-6:2 chip ID: 0408:5429
class ID: 0e02 serial:
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:06c8 class ID: 0401
Device-2: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB driver: snd-usb-audio,usb-storage bus ID: 1-2.3:8
chip ID: 1235:8211 class ID: 0806 serial:
Sound Server: ALSA v: k5.11.2-1-MANJARO
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:06f0
class ID: 0280
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: global
IP v6: type: noprefixroute scope: link
IP v4: scope: global broadcast:
IP v6: virtual: stable-privacy scope: link
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-14:4 chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060 bus ID: 00:17.0
chip ID: 8086.282a rev: N/A
Drives: Local Storage: total: 476.94 GiB used: 194.18 GiB (40.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000H1 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: rev: HPS0NEXF temp: 32.9 C
scheme: GPT
ID-2: /dev/sdc maj-min: 8:32 type: USB model: Scarlett Welcome Disk size: 192 KiB block size: physical: 512 B
logical: 512 B serial: rev: 0.10 scheme: MBR
Partition: ID-1: / raw size: 183.96 GiB size: 180.08 GiB (97.89%) used: 83.99 GiB (46.6%) fs: ext4 dev: /dev/nvme0n1p6
maj-min: 259:6 label: Manjaro uuid: adebe5df-56a6-44e4-9f48-03451392bc85
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%) used: 139.4 MiB (54.5%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: 549C-5DCB
ID-3: /mnt/workspace raw size: 195.31 GiB size: 191.25 GiB (97.92%) used: 110.06 GiB (57.6%) fs: ext4
dev: /dev/nvme0n1p7 maj-min: 259:7 label: workspace uuid: 6087054a-9912-4729-991d-839d9f5fd012
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 3.73 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 2b7b687b-c518-4ccb-bcd7-b18756c5f0da
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 93.13 GiB fs: ntfs label: Windows uuid: 622A2D342A2D071F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 540 MiB fs: ntfs label: Windows RE tools uuid: 88AABF40AABF2998
ID-4: /dev/sdc1 maj-min: 8:33 size: 160 KiB fs: vfat label: SCARLETT uuid: 8886-5B6C
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:5 info: Logitech M90/M100 Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s chip ID: 046d:c05a class ID: 0301
Hub-2: 1-2:6 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 05e3:0610 class ID: 0900
Device-1: 1-2.2:7 info: Dell Dell USB Wired Multimedia Keyboard type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s chip ID: 413c:2112 class ID: 0300
Device-2: 1-2.3:8 info: Focusrite-Novation Scarlett Solo (3rd Gen.) type: Audio,Mass Storage
driver: snd-usb-audio,usb-storage interfaces: 5 rev: 2.1 speed: 480 Mb/s chip ID: 1235:8211 class ID: 0806
serial:
Device-3: 1-6:2 info: Quanta HP Wide Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 0408:5429 class ID: 0e02 serial:
Device-4: 1-9:3 info: Elan Micro ELAN:ARM-M4 type: driver: N/A interfaces: 1 rev: 2.0
speed: 12 Mb/s chip ID: 04f3:0c4c class ID: 0000
Device-5: 1-14:4 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0026
class ID: e001
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
Hub-4: 2-2:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s chip ID: 05e3:0626 class ID: 0900
Device-1: 2-2.4:3 info: Genesys Logic SD Card Reader and Writer type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.1 speed: 5 Gb/s chip ID: 05e3:0749 class ID: 0806 serial:
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
Sensors: System Temperatures: cpu: 39.0 C mobo: N/A
Info: Processes: 398 Uptime: 5h 00m wakeups: 4863 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1434 pacman: 1413
lib: 458 flatpak: 9 snap: 12 Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.3.01
and
mhwd --listinstalled
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
I’ve tried switching to a LTS kernel but it didn’t change anything. Any help appreciated.
