Hi there,
I installed manjaro KDE distribution from December 16, 2024 and each time I make System Update and Reboot the system, my display on HDMI port is not detected.
Now I have installed manjaro for the third time and didn’t update it.
Here are the outputs of
`inxi --filter --verbosity=8
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9244174e-9ed2-4935-a504-05e6444a96ca rw quiet splash
udev.log_priority=3 acpi_osi=! "acpi_osi=Windows 2009"
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Micro-Star product: GS65 Stealth Thin 8RF v: REV:1.0
Mobo: Micro-Star model: MS-16Q2 v: REV:1.0 serial: <superuser required>
part-nu: 16Q2.1 uuid: <superuser required> UEFI: American Megatrends
v: E16Q2IMS.111 date: 12/05/2018
ID-1: BAT1 charge: 75.1 Wh (93.3%) condition: 80.5/80.3 Wh (100.3%)
volts: 16.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
System RAM: total: 32 GiB available: 31.19 GiB used: 6.8 GiB (21.8%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43CB1-CTD
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: HDMI-A-2 empty: DP-2 bus-ID: 01:00.0
chip-ID: 10de:1ba1 class-ID: 0300 temp: 48.0 C
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris,nouveau gpu: i915,nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 6000x2520 s-dpi: 96 s-size: 1587x666mm (62.48x26.22")
s-diag: 1721mm (67.76")
Monitor-1: DP-1 pos: top-left model: HP 27mq serial: <filter> built: 2021
res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
x: 0.655 y: 0.325 green: x: 0.298 y: 0.624 blue: x: 0.149 y: 0.051 white:
x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-1-2 pos: top-right model: Samsung S34J55x
serial: <filter> built: 2014 res: mode: 3440x1440 hz: 60 scale: 100% (1)
dpi: 110 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green: x: 0.310
y: 0.608 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: 3440x1440,
2560x1440, 2560x1080, 1920x1080, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
Monitor-3: eDP-1 pos: primary,bottom-c model: AU Optronics 0x80ed
built: 2017 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
chroma: red: x: 0.643 y: 0.337 green: x: 0.322 y: 0.612 blue: x: 0.153
y: 0.043 white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 15.23 GiB unified: yes
API: Vulkan v: 1.4.309 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.0.2-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi vendor: Rivet Networks Killer
Wireless-AC 1550i Wireless driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 122.45 GiB (25.7%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7301Q temp: 41.9 C scheme: GPT
ID-1: / raw-size: 50.08 GiB size: 48.99 GiB (97.83%) used: 11.9 GiB (24.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 9244174e-9ed2-4935-a504-05e6444a96ca
ID-2: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 0697-952C
ID-3: /home raw-size: 193.01 GiB size: 188.92 GiB (97.88%)
used: 110.54 GiB (58.5%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: d251b8f2-5d32-46fe-8a46-d4362a49b706
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: ntfs label: WINRE
uuid: FA26800D267FC961
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: SYSTEM
uuid: C080-74F2
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 232.28 GiB fs: ntfs label: OS
uuid: 4646815A46814B9D
Device-1: 1-2:2 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-7:3 info: SteelSeries ApS KLC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-3: 1-14:9 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 49.0 C pch: 51.0 C mobo: N/A gpu: nouveau
temp: 48.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1259 libs: 361 tools: pamac pm: flatpak pkgs: 0
1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 283
1: cpu: 25.0% command: kwin_x11 pid: 888 mem: 206.9 MiB (0.6%)
2: cpu: 20.2% command: firefox pid: 1925 mem: 642.2 MiB (2.0%)
3: cpu: 19.9% command: Xorg pid: 689 mem: 116.5 MiB (0.3%)
4: cpu: 8.1% command: firefox pid: 2355 mem: 334.6 MiB (1.0%)
5: cpu: 5.1% command: plasma-systemmonitor pid: 1291 mem: 192.5 MiB (0.6%)
Memory top: 5 of 283
1: mem: 644.0 MiB (2.0%) command: plasmashell pid: 917 cpu: 2.5%
2: mem: 642.2 MiB (2.0%) command: firefox pid: 1925 cpu: 20.2%
3: mem: 533.1 MiB (1.6%) command: firefox pid: 2482 cpu: 5.1%
4: mem: 436.0 MiB (1.3%) command: firefox pid: 2215 cpu: 2.6%
5: mem: 410.7 MiB (1.2%) command: firefox pid: 2119 cpu: 1.5%
Processes: 283 Power: uptime: 18m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: yakuake inxi: 3.3.38
`pamac search --installed nvidia
mhwd-nvidia-470xx 470.256.02-10 extra
MHWD module-ids for nvidia 470.256.02
mhwd-nvidia-390xx 390.157-19 extra
MHWD module-ids for nvidia 390.157
mhwd-nvidia 570.133.07-2 extra
MHWD module-ids for nvidia 570.133.07
nvidia-driver-assistant 0.20.124.06-1 extra
Detect and install the best NVIDIA driver packages for the system
and mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
I will be more than happy to find a solution to this problem and keep my system up-to-date.
