I collected various information to compare Ubuntu and Manjaro.
Ubuntu:
________________
> pulseaudio_ps_do
admin 1428 0.4 0.0 1767852 13600 ? S<sl 08:00 0:03 /usr/bin/pulseaudio --daemonize=no --log-target=journal
admin 5724 0.0 0.0 3168 804 pts/2 S+ 08:11 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1428
________________
> pulseaudio --version
pulseaudio 14.2
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 10
Tile Size: 65472
User Name: admin
Host Name: Dell-G5-5505
Server Name: pulseaudio
Server Version: 14.2
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_03_00.1.HiFi__hw_HDMI_3__sink
Default Source: alsa_input.pci-0000_07_00.6.HiFi__hw_acp__source
Cookie: 9acb:6dc1
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.2"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="1" name="pci-0000_03_00.1" card_name="alsa_card.pci-0000_03_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 1
Properties:
module.description = "ALSA Card"
Module #7
Argument: device_id="2" name="pci-0000_07_00.1" card_name="alsa_card.pci-0000_07_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #9
Argument: device_id="3" name="pci-0000_07_00.6" card_name="alsa_card.pci-0000_07_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #10
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #11
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #12
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #16
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #18
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #24
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #25
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #26
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #27
Argument: display=:0 xauthority=/home/admin/.Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #28
Argument: display=:0 xauthority=/home/admin/.Xauthority session_manager=local/Dell-G5-5505:@/tmp/.ICE-unix/1374,unix/Dell-G5-5505:/tmp/.ICE-unix/1374
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #2
State: SUSPENDED
Description: Family 17h (Models 10h-1fh) HD Audio Controller Speaker + Headphones
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Owner Module: 9
Mute: no
Volume: front-left: 8739 / 13% / -52.50 dB, front-right: 8739 / 13% / -52.50 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_07_00.6.HiFi__hw_Generic_1__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC3254 Analog"
alsa.id = "ALC3254 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "3"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xd04c0000 irq 103"
device.bus_path = "pci-0000:07:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.6/sound/card3"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller"
device.string = "hw:Generic_1"
device.buffering.buffer_size = "19200"
device.buffering.fragment_size = "3840"
device.access_mode = "mmap"
device.profile.name = "HiFi: hw:Generic_1: sink"
device.profile.description = "Speaker + Headphones"
alsa.mixer_device = "hw:Generic_1"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller Speaker + Headphones"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone Mic, not available)
Active Port: [Out] Speaker
Formats:
pcm
Sink #3
State: SUSPENDED
Description: Navi 10 HDMI Audio HDMI2 Output
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_03_00.1.HiFi__hw_HDMI_7__sink.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.name = "HDMI 1"
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xd0880000 irq 101"
device.bus_path = "pci-0000:03:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "ab38"
device.product.name = "Navi 10 HDMI Audio"
device.string = "hw:HDMI,7"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "HiFi: hw:HDMI,7: sink"
device.profile.description = "HDMI2 Output"
alsa.mixer_device = "hw:HDMI"
device.description = "Navi 10 HDMI Audio HDMI2 Output"
Ports:
[Out] HDMI2: HDMI2 Output (type: HDMI, priority: 1200, not available)
Active Port: [Out] HDMI2
Formats:
pcm
Sink #4
State: RUNNING
Description: Navi 10 HDMI Audio HDMI1 Output
Owner Module: 6
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_03_00.1.HiFi__hw_HDMI_3__sink.monitor
Latency: 46911 usec, configured 75000 usec
Properties:
device.api = "alsa"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "1"
device.bus = "pci"
device.string = "hw:HDMI,3"
device.profile.name = "HiFi: hw:HDMI,3: sink"
device.profile.description = "HDMI1 Output"
device.description = "Navi 10 HDMI Audio HDMI1 Output"
Ports:
[Out] HDMI1: HDMI1 Output (type: HDMI, priority: 1100, available)
Active Port: [Out] HDMI1
Formats:
pcm
Source #2
State: SUSPENDED
Description: Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Speaker + Headphones
Owner Module: 9
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_07_00.6.HiFi__hw_Generic_1__sink
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Speaker + Headphones"
device.class = "monitor"
alsa.card = "3"
device.bus = "pci"
device.string = "3"
Formats:
pcm
Source #3
State: SUSPENDED
Description: Family 17h (Models 10h-1fh) HD Audio Controller Digital Microphone
Sample Specification: s32le 2ch 48000Hz
Owner Module: 9
Mute: yes
Volume: front-left: 28443 / 43% / -21.75 dB, front-right: 28443 / 43% / -21.75 dB
balance 0.00
Base Volume: 20724 / 32% / -30.00 dB
Monitor of Sink: n/a
Properties:
alsa.resolution_bits = "32"
device.api = "alsa"
alsa.name = ""
alsa.id = "DMIC capture dmic-hifi-0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "acp"
alsa.long_card_name = "DellInc.-G55505-1.5.0-0JT83K"
alsa.driver_name = "snd_acp3x_rn"
device.bus_path = "pci-0000:07:00.5-platform-acp_pdm_mach.0"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.5/acp_pdm_mach.0/sound/card0"
device.bus = "pci"
device.product.id = "15e2"
device.product.name = "Raven/Raven2/FireFlight/Renoir Audio Processor"
device.string = "hw:acp"
device.buffering.buffer_size = "32768"
device.buffering.fragment_size = "8192"
device.profile.name = "HiFi: hw:acp: source"
device.profile.description = "Digital Microphone"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller Digital Microphone"
Ports:
[In] Mic1: Digital Microphone (type: Mic, priority: 100, availability unknown)
Active Port: [In] Mic1
Formats:
pcm
Source #4
State: SUSPENDED
Description: Family 17h (Models 10h-1fh) HD Audio Controller Headset Mono Microphone + Headphones Stereo Microphone
Owner Module: 9
Mute: yes
Volume: front-left: 28836 / 44% / -21.39 dB, front-right: 28836 / 44% / -21.39 dB
balance 0.00
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "3"
device.bus = "pci"
device.buffering.buffer_size = "17664"
device.buffering.fragment_size = "2944"
device.profile.name = "HiFi: hw:Generic_1: source"
device.profile.description = "Headset Mono Microphone + Headphones Stereo Microphone"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller Headset Mono Microphone + Headphones Stereo Microphone"
Ports:
[In] Headset: Headset Mono Microphone (type: Headset, priority: 300, availability group: Headphone Mic, not available)
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, availability group: Headphone Mic, not available)
Active Port: [In] Headset
Formats:
pcm
Source #5
State: SUSPENDED
Description: Monitor of Navi 10 HDMI Audio HDMI2 Output
Owner Module: 6
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_03_00.1.HiFi__hw_HDMI_7__sink
Properties:
device.description = "Monitor of Navi 10 HDMI Audio HDMI2 Output"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #6
State: IDLE
Description: Monitor of Navi 10 HDMI Audio HDMI1 Output
Owner Module: 6
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_03_00.1.HiFi__hw_HDMI_3__sink
Latency: 0 usec, configured 1837333 usec
Properties:
device.description = "Monitor of Navi 10 HDMI Audio HDMI1 Output"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Sink Input #2
Driver: protocol-native.c
Owner Module: 15
Client: 8
Sink: 4
Sample Specification: float32le 2ch 48000Hz
Format: pcm, format.sample_format = "\"float32le\"" format.rate = "48000" format.channels = "2" format.channel_map = "\"front-left,front-right\""
Corked: no
Mute: no
balance 0.00
Buffer Latency: 96520 usec
Sink Latency: 74617 usec
Resample method: copy
Properties:
media.name = "AudioStream"
application.name = "Firefox"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.process.id = "1760"
application.process.user = "admin"
application.process.host = "Dell-G5-5505"
application.process.binary = "firefox"
application.language = "C"
window.x11.display = ":0"
application.process.machine_id = "c2ce9b9c0f304d8385f97739b2a77cdf"
application.process.session_id = "2"
application.icon_name = "firefox"
module-stream-restore.id = "sink-input-by-application-name:Firefox"
Client #0
Driver: module-systemd-login.c
Owner Module: 22
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #3
Driver: module-x11-xsmp.c
Owner Module: 28
Properties:
application.name = "XSMP Session on KDE as 10a6e1d1ce000161302680000000013740008"
xsmp.vendor = "KDE"
xsmp.client.id = "10a6e1d1ce000161302680000000013740008"
Client #4
Owner Module: 15
Properties:
application.name = "QPulse"
application.process.id = "1390"
application.process.binary = "plasmashell"
Client #6
Owner Module: 15
Properties:
window.x11.screen = "0"
Client #7
Owner Module: 15
Properties:
application.name = "Thunderbird"
application.process.id = "1685"
application.process.binary = "thunderbird"
application.icon_name = "thunderbird"
Client #8
Owner Module: 15
Properties:
Client #9
Owner Module: 15
Properties:
application.version = "85.0.1"
Client #11
Owner Module: 15
Properties:
application.name = "pactl"
application.process.id = "5732"
application.process.binary = "pactl"
Card #0
Owner Module: 6
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
device.description = "Navi 10 HDMI Audio"
Profiles:
HiFi: Play HiFi quality Music (sinks: 2, sources: 0, priority: 8000, available: yes)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: HiFi
Ports:
[Out] HDMI2: HDMI2 Output (type: HDMI, priority: 1200, latency offset: 0 usec, not available)
Part of profile(s): HiFi
[Out] HDMI1: HDMI1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, available)
Properties:
device.product.name = "TOSHIBA-TV"
Card #1
Owner Module: 7
Properties:
alsa.card = "2"
alsa.long_card_name = "HD-Audio Generic at 0xd04c8000 irq 102"
device.bus_path = "pci-0000:07:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.1/sound/card2"
device.bus = "pci"
device.product.id = "1637"
device.string = "2"
device.description = "HD-Audio Generic"
Profiles:
HiFi: Play HiFi quality Music (sinks: 1, sources: 0, priority: 8000, available: no)
Active Profile: off
Ports:
[Out] HDMI1: HDMI1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, not available)
Card #2
Owner Module: 9
Properties:
alsa.card = "3"
device.bus = "pci"
device.string = "3"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller"
Profiles:
HiFi: Play HiFi quality Music (sinks: 1, sources: 2, priority: 8000, available: yes)
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone Mic, not available)
[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
[In] Headset: Headset Mono Microphone (type: Headset, priority: 300, latency offset: 0 usec, availability group: Headphone Mic, not available)
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Headphone Mic, not available)
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 6 Feb 11 08:07 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 7 Feb 11 08:04 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 12 Feb 11 08:00 /dev/snd/pcmC3D0c
crw-rw----+ 1 root audio 116, 2 Feb 11 08:00 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 11 Feb 11 08:00 /dev/snd/pcmC3D0p
crw-rw----+ 1 root audio 116, 4 Feb 11 08:00 /dev/snd/pcmC2D3p
crw-rw----+ 1 root audio 116, 15 Feb 11 07:59 /dev/snd/controlC3
crw-rw----+ 1 root audio 116, 14 Feb 11 07:59 /dev/snd/hwC3D0
crw-rw----+ 1 root audio 116, 13 Feb 11 07:59 /dev/snd/pcmC3D2c
crw-rw----+ 1 root audio 116, 10 Feb 11 07:59 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 8 Feb 11 07:59 /dev/snd/controlC2
crw-rw----+ 1 root audio 116, 9 Feb 11 07:59 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 5 Feb 11 07:59 /dev/snd/hwC2D0
crw-rw----+ 1 root audio 116, 3 Feb 11 07:59 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 33 Feb 11 07:59 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Feb 11 07:59 /dev/snd/seq
/dev/snd/by-path:
total 0
lrwxrwxrwx 1 root root 12 Feb 11 07:59 pci-0000:07:00.6 -> ../controlC3
drwxr-xr-x 2 root root 120 Feb 11 07:59 .
drwxr-xr-x 3 root root 380 Feb 11 07:59 ..
lrwxrwxrwx 1 root root 12 Feb 11 07:59 pci-0000:03:00.1 -> ../controlC1
lrwxrwxrwx 1 root root 12 Feb 11 07:59 pci-0000:07:00.1 -> ../controlC2
lrwxrwxrwx 1 root root 12 Feb 11 07:59 pci-0000:07:00.5-platform-acp_pdm_mach.0 -> ../controlC0
________________
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 1428 admin mem CHR 116,6 536 /dev/snd/pcmC1D3p
pulseaudi 1428 admin 16u CHR 116,10 0t0 543 /dev/snd/controlC1
pulseaudi 1428 admin 17u CHR 116,3 0t0 475 /dev/snd/controlC0
pulseaudi 1428 admin 18u CHR 116,10 0t0 543 /dev/snd/controlC1
pulseaudi 1428 admin 28u CHR 116,8 0t0 539 /dev/snd/controlC2
pulseaudi 1428 admin 30u CHR 116,3 0t0 475 /dev/snd/controlC0
pulseaudi 1428 admin 31u CHR 116,8 0t0 539 /dev/snd/controlC2
pulseaudi 1428 admin 32u CHR 116,15 0t0 565 /dev/snd/controlC3
pulseaudi 1428 admin 33u CHR 116,3 0t0 475 /dev/snd/controlC0
pulseaudi 1428 admin 34u CHR 116,15 0t0 565 /dev/snd/controlC3
pulseaudi 1428 admin 39u CHR 116,15 0t0 565 /dev/snd/controlC3
pulseaudi 1428 admin 46u CHR 116,15 0t0 565 /dev/snd/controlC3
pulseaudi 1428 admin 52u CHR 116,15 0t0 565 /dev/snd/controlC3
pulseaudi 1428 admin 61u CHR 116,6 0t0 536 /dev/snd/pcmC1D3p
________________
> jacks_do
card=0
card=1
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
; type=BOOLEAN,access=r-------,values=1
: values=on
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
card=2
: values=off
card=3
numid=18,iface=CARD,name='Headphone Mic Jack'
: values=off
numid=17,iface=CARD,name='Headset Mic Phantom Jack'
: values=on
numid=19,iface=CARD,name='Speaker Phantom Jack'
: values=on
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
usbstream:CARD=acp
acp
USB Stream Output
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, HDMI 1
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Generic_1
HD-Audio Generic, ALC3254 Analog
Default Audio Device
front:CARD=Generic_1,DEV=0
Front output / input
surround21:CARD=Generic_1,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=acp
acp,
usbstream:CARD=acp
acp
USB Stream Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
HD-Audio Generic
USB Stream Output
HD-Audio Generic
USB Stream Output
________________
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Thu Feb 11 07:11:22 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Dell Inc.
Product Name: G5 5505
Product Version: 1.5.0
Firmware Version: 1.5.0
System SKU: 09F5
Board Vendor: Dell Inc.
Board Name: 0JT83K
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/AMD0005:00/status 15
/sys/bus/acpi/devices/AMDI0010:03/status 15
/sys/bus/acpi/devices/AMDI0030:00/status 15
/sys/bus/acpi/devices/DELL09F5:00/status 15
/sys/bus/acpi/devices/DELLABCE:00/status 15
/sys/bus/acpi/devices/DLLK09F5:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 1
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:25/status 15
/sys/bus/acpi/devices/device:26/status 15
/sys/bus/acpi/devices/device:27/status 15
!!Kernel Information
Kernel release: 5.10.15-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.15-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_acp3x_rn
snd_hda_intel
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [acp ]: acp - acp
1 [HDMI ]: HDA-Intel - HDA ATI HDMI
2 [Generic ]: HDA-Intel - HD-Audio Generic
3 [Generic_1 ]: HDA-Intel - HD-Audio Generic
!!PCI Soundcards installed in the system
03:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
Subsystem: Dell Device [1028:09f5]
07:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1637]
07:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
!!Loaded sound module options
!!Module: snd_acp3x_rn
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x5]: PCM AC3
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Device: name="HDMI 0", type="HDMI", device=3
Converter: stream=2, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Converter: stream=0, channel=0
Digital:
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=1
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0e
Address: 0
Default PCM:
bits [0x2]: 16
formats [0x1]: PCM
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Digital:
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Codec: Realtek ALC3254
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0295
Subsystem Id: 0x102809f5
Revision Id: 0x100002
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x11 0x11]
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Device: name="ALC3254 Analog", type="Audio", device=0
Amp-Out vals: [0x34 0x34]
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0xa2 0xa2]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC3254 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00000020: IN
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x0000001c: OUT HP Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 2
0x02* 0x03
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 3
0x02* 0x03 0x06
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Headset Mic Boost Volume", index=0, device=0
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Misc = NO_PRESENCE
Pin-ctls: 0x24: IN VREF_80
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Mic Boost Volume", index=0, device=0
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40400001: [N/A] SPDIF Out at Ext N/A
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=104
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x04211030: [Jack] HP Out at Ext Right
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x02 0x03*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x19 0x1a 0x1b 0x1d 0x13
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 5
0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 3
0x12* 0x13 0x18
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 3: Generic_1 [HD-Audio Generic], device 0: ALC3254 Analog [ALC3254 Analog]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
card 0: acp [acp], device 0: DMIC capture dmic-hifi-0 []
Subdevices: 1/1
Subdevices: 1/1
card 3: Generic_1 [HD-Audio Generic], device 2: ALC3254 Alt Analog [ALC3254 Alt Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card acp
Card hw:0 'acp'/'DellInc.-G55505-1.5.0-0JT83K'
Mixer name : ''
Components : ''
Controls : 0
Simple ctrls : 0
!!-------Mixer controls for card HDMI
Card hw:1 'HDMI'/'HDA ATI HDMI at 0xd0880000 irq 101'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100700'
Controls : 14
Simple ctrls : 2
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [off]
!!-------Mixer controls for card Generic
Card hw:2 'Generic'/'HD-Audio Generic at 0xd04c8000 irq 102'
Controls : 7
Simple ctrls : 1
!!-------Mixer controls for card Generic_1
Card hw:3 'Generic_1'/'HD-Audio Generic at 0xd04c0000 irq 103'
Mixer name : 'Realtek ALC3254'
Components : 'HDA:10ec0295,102809f5,00100002'
Controls : 22
Simple ctrls : 11
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 52 [60%] [-26.25dB] [on]
Front Right: Playback 52 [60%] [-26.25dB] [on]
Simple mixer control 'Headphone Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 17 [20%] [-52.50dB] [on]
Front Right: Playback 17 [20%] [-52.50dB] [on]
Simple mixer control 'Mic Mute-LED Mode',0
Capabilities: enum
Items: 'On' 'Off' 'Follow Capture' 'Follow Mute'
Item0: 'Follow Mute'
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 34 [54%] [8.25dB] [off]
Front Right: Capture 34 [54%] [8.25dB] [off]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Headset Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Headset Mic' 'Headphone Mic'
Item0: 'Headset Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
!!Alsactl output
--startcollapse--
state.acp {
control {
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value '10000d006a82005f000000000000000052620501544f53484942412d5456097f070f7f071507503e1fc04d02005706006754005f54010000'
comment {
access 'read volatile'
type BYTES
count 56
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 3
value.1 4
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.14 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Generic {
control.1 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.7 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Generic_1 {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 52
value.1 52
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2625
dbvalue.1 -2625
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 17
value.1 17
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -5250
dbvalue.1 -5250
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Input Source'
value 'Headset Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Headset Mic'
item.1 'Headphone Mic'
control.7 {
iface MIXER
name 'Input Source'
index 1
value 'Headset Mic'
comment {
access 'read write'
type ENUMERATED
count 1
control.8 {
iface MIXER
name 'Capture Volume'
value.0 34
value.1 34
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 825
dbvalue.1 825
control.9 {
iface MIXER
name 'Capture Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.10 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.11 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Headset Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.13 {
iface MIXER
name 'Headphone Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.14 {
iface MIXER
name 'Mic Mute-LED Mode'
value 'Follow Mute'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 On
item.1 Off
item.2 'Follow Capture'
item.3 'Follow Mute'
control.15 {
iface MIXER
name 'Master Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.16 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.17 {
iface CARD
name 'Headset Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.18 {
iface CARD
name 'Headphone Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.19 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.20 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.21 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.22 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_cpufreq
acpi_tad
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
alienware_wmi
amdgpu
bluetooth
bnep
btbcm
btintel
btrtl
btusb
cbc
ccp
cec
cfg80211
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dcdbas
dell_laptop
dell_rbtn
dell_smbios
dell_wmi
dell_wmi_descriptor
dm_crypt
dm_mod
drm
drm_kms_helper
ecc
ecdh_generic
edac_mce_amd
encrypted_keys
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
gpu_sched
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_piix4
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libarc4
libphy
loop
mac80211
mac_hid
mbcache
mdio_devres
mousedev
pinctrl_amd
psmouse
r8169
rapl
realtek
rfcomm
rfkill
rng_core
serio_raw
sg
snd
snd_acp3x_pdm_dma
snd_acp3x_rn
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pci_acp3x
snd_pcm
snd_pcm_dmaengine
snd_rn_pci_acp3x
snd_soc_core
snd_soc_dmic
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
trusted
ttm
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
vfat
video
wmi
wmi_bmof
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x585600f0
0x09 0x585600f0
0x0b 0x585600f0
0x0d 0x585600f0
0x0f 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
/sys/class/sound/hwC2D0/init_pin_configs:
0x03 0x185600f0
0x05 0x585600f0
0x07 0x585600f0
0x09 0x585600f0
0x0b 0x585600f0
0x0d 0x585600f0
/sys/class/sound/hwC2D0/driver_pin_configs:
/sys/class/sound/hwC2D0/user_pin_configs:
/sys/class/sound/hwC2D0/init_verbs:
/sys/class/sound/hwC2D0/hints:
/sys/class/sound/hwC3D0/init_pin_configs:
0x12 0x40000000
0x13 0x411111f0
0x14 0x90170110
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40400001
0x1e 0x411111f0
0x21 0x04211030
/sys/class/sound/hwC3D0/driver_pin_configs:
0x19 0x01a1913c
0x1b 0x01a1913d
/sys/class/sound/hwC3D0/user_pin_configs:
/sys/class/sound/hwC3D0/init_verbs:
/sys/class/sound/hwC3D0/hints:
!!ALSA/HDA dmesg
