I did update and I’ve read that many people have had issues with sound drivers after the 5.15 stable update. I’ve since reverted to 5.15.76-1 and still have no audio from my speakers or headphones. Audio is playing fine through the HDMI/DisplayPort on my Nvidia card however.
sudo pulseaudio -vv:
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: [pulseaudio] core-util.c: Successfully gained nice level -11.
I: [pulseaudio] main.c: This is PulseAudio 16.1
I: [pulseaudio] main.c: Page size is 4096 bytes
I: [pulseaudio] main.c: Machine ID is 62f9f17fae5541d69ce689083c34a27e.
I: [pulseaudio] main.c: Session ID is 2.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/carneyjs/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulseaudio/modules.
I: [pulseaudio] main.c: Running in system mode: no
I: [pulseaudio] main.c: System supports high resolution timers
I: [pulseaudio] cpu-x86.c: CPU flags: CMOV MMX SSE SSE2 SSE3 SSSE3 SSE4_1 SSE4_2 MMXEXT
I: [pulseaudio] svolume_mmx.c: Initialising MMX optimized volume functions.
I: [pulseaudio] remap_mmx.c: Initialising MMX optimized remappers.
I: [pulseaudio] svolume_sse.c: Initialising SSE2 optimized volume functions.
I: [pulseaudio] remap_sse.c: Initialising SSE2 optimized remappers.
I: [pulseaudio] sconv_sse.c: Initialising SSE2 optimized conversions.
I: [pulseaudio] svolume_orc.c: Initialising ORC optimized volume functions.
I: [pulseaudio] database.c: Successfully opened 'device-volumes' database file '/home/carneyjs/.config/pulse/62f9f17fae5541d69ce689083c34a27e-device-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-device-restore" (index: #0; argument: "").
I: [pulseaudio] database.c: Successfully opened 'stream-volumes' database file '/home/carneyjs/.config/pulse/62f9f17fae5541d69ce689083c34a27e-stream-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-stream-restore" (index: #1; argument: "").
I: [pulseaudio] database.c: Successfully opened 'card-database' database file '/home/carneyjs/.config/pulse/62f9f17fae5541d69ce689083c34a27e-card-database.tdb'.
I: [pulseaudio] module.c: Loaded "module-card-restore" (index: #2; argument: "").
I: [pulseaudio] module.c: Loaded "module-augment-properties" (index: #3; argument: "").
I: [pulseaudio] module.c: Loaded "module-switch-on-port-available" (index: #4; argument: "").
I: [pulseaudio] (alsa-lib)parser.c: Unable to find the top-level configuration file '/usr/share/alsa/ucm2/ucm.conf'.
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:0 use case configuration -2
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HDA NVidia use case configuration -2
I: [pulseaudio] alsa-ucm.c: UCM not available for card HDA NVidia
I: [pulseaudio] alsa-util.c: Error opening PCM device front:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround40:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround51:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:0: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-0.conf
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-1.conf
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='hdmi:0,1': Invalid argument
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,1: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-2.conf
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='hdmi:0,2': Invalid argument
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,2: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-3.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,3: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-4.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,4: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-5.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,5: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-6.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,10: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hw:0: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_10_00.1.
I: [pulseaudio] card.c: alsa_card.pci-0000_10_00.1: active_profile: output:hdmi-stereo-extra1
I: [pulseaudio] module-card-restore.c: Profile '' was previously automatically selected for card alsa_card.pci-0000_10_00.1.
I: [pulseaudio] card.c: Created 0 "alsa_card.pci-0000_10_00.1"
I: [pulseaudio] alsa-util.c: Trying to disable ALSA period wakeups, using timers only
I: [pulseaudio] alsa-util.c: ALSA period wakeups disabled
I: [pulseaudio] alsa-sink.c: Successfully opened device hdmi:0,1.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Digital Stereo (HDMI 2)' (hdmi-stereo-extra1).
I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1: front-left: 65536 / 100%, front-right: 65536 / 100%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1: unmuted
I: [pulseaudio] sink.c: Created sink 0 "alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: alsa.resolution_bits = "16"
I: [pulseaudio] sink.c: device.api = "alsa"
I: [pulseaudio] sink.c: device.class = "sound"
I: [pulseaudio] sink.c: alsa.class = "generic"
I: [pulseaudio] sink.c: alsa.subclass = "generic-mix"
I: [pulseaudio] sink.c: alsa.name = "27S2R"
I: [pulseaudio] sink.c: alsa.id = "HDMI 1"
I: [pulseaudio] sink.c: alsa.subdevice = "0"
I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] sink.c: alsa.device = "7"
I: [pulseaudio] sink.c: alsa.card = "0"
I: [pulseaudio] sink.c: alsa.card_name = "HDA NVidia"
I: [pulseaudio] sink.c: alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 62"
I: [pulseaudio] sink.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] sink.c: device.bus_path = "pci-0000:10:00.1"
I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:10:00.1/sound/card0"
I: [pulseaudio] sink.c: device.bus = "pci"
I: [pulseaudio] sink.c: device.vendor.id = "10de"
I: [pulseaudio] sink.c: device.vendor.name = "NVIDIA Corporation"
I: [pulseaudio] sink.c: device.product.id = "10f1"
I: [pulseaudio] sink.c: device.product.name = "GP106 High Definition Audio Controller"
I: [pulseaudio] sink.c: device.string = "hdmi:0,1"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "352768"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "176384"
I: [pulseaudio] sink.c: device.access_mode = "mmap+timer"
I: [pulseaudio] sink.c: device.profile.name = "hdmi-stereo-extra1"
I: [pulseaudio] sink.c: device.profile.description = "Digital Stereo (HDMI 2)"
I: [pulseaudio] sink.c: device.description = "GP106 High Definition Audio Controller Digital Stereo (HDMI 2)"
I: [pulseaudio] sink.c: module-udev-detect.discovered = "1"
I: [pulseaudio] sink.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] source.c: Created source 0 "alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of GP106 High Definition Audio Controller Digital Stereo (HDMI 2)"
I: [pulseaudio] source.c: device.class = "monitor"
I: [pulseaudio] source.c: alsa.card = "0"
I: [pulseaudio] source.c: alsa.card_name = "HDA NVidia"
I: [pulseaudio] source.c: alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 62"
I: [pulseaudio] source.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] source.c: device.bus_path = "pci-0000:10:00.1"
I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:10:00.1/sound/card0"
I: [pulseaudio] source.c: device.bus = "pci"
I: [pulseaudio] source.c: device.vendor.id = "10de"
I: [pulseaudio] source.c: device.vendor.name = "NVIDIA Corporation"
I: [pulseaudio] source.c: device.product.id = "10f1"
I: [pulseaudio] source.c: device.product.name = "GP106 High Definition Audio Controller"
I: [pulseaudio] source.c: device.string = "0"
I: [pulseaudio] source.c: module-udev-detect.discovered = "1"
I: [pulseaudio] source.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] alsa-sink.c: Using 2.0 fragments of size 176384 bytes (999.91ms), buffer size is 352768 bytes (1999.82ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20.00ms
I: [pulseaudio] alsa-sink.c: Driver does not support hardware volume control, falling back to software volume control.
I: [pulseaudio] alsa-sink.c: Driver does not support hardware mute control, falling back to software mute control.
I: [alsa-sink-HDMI 1] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5.
I: [alsa-sink-HDMI 1] alsa-sink.c: Starting playback.
I: [pulseaudio] core.c: default_source: (unset) -> alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1.monitor
I: [pulseaudio] core.c: default_sink: (unset) -> alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-0 (3).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-1 (7).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-2 (8).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-3 (9).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-4 (10).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-5 (11).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-6 (12).
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #6; argument: "device_id="0" name="pci-0000_10_00.1" card_name="alsa_card.pci-0000_10_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:01.1/0000:10:00.1/sound/card0 (alsa_card.pci-0000_10_00.1) module loaded.
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:1 use case configuration -2
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HD-Audio Generic use case configuration -2
I: [pulseaudio] alsa-ucm.c: UCM not available for card HD-Audio Generic
I: [pulseaudio] alsa-util.c: Error opening PCM device front:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround40:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround51:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:1: No such file or directory
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:1'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,3: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,3: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,4: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,4: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,5: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,5: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,10: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hw:1: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_30_00.1.
I: [pulseaudio] card.c: alsa_card.pci-0000_30_00.1: active_profile: off
I: [pulseaudio] module-card-restore.c: Profile '' was previously automatically selected for card alsa_card.pci-0000_30_00.1.
I: [pulseaudio] card.c: Created 1 "alsa_card.pci-0000_30_00.1"
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #7; argument: "device_id="1" name="pci-0000_30_00.1" card_name="alsa_card.pci-0000_30_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:08.1/0000:30:00.1/sound/card1 (alsa_card.pci-0000_30_00.1) module loaded.
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:2 use case configuration -2
I: [pulseaudio] alsa-util.c: Error opening PCM device front:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround40:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround51:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:2
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,3: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,3: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,4: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,4: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,5: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,5: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:2,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:2,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:2,10: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hw:2: No such file or directory
E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="2" name="pci-0000_30_00.6" card_name="alsa_card.pci-0000_30_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:08.1/0000:30:00.6/sound/card2 (alsa_card.pci-0000_30_00.6) failed to load module.
I: [pulseaudio] module-udev-detect.c: Found 3 cards.
I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: "").
I: [pulseaudio] module.c: Loaded "module-jackdbus-detect" (index: #9; argument: "channels=2").
I: [pulseaudio] module.c: Loaded "module-bluetooth-policy" (index: #10; argument: "").
I: [pulseaudio] a2dp-codec-util.c: GStreamer initialisation done
I: [pulseaudio] module.c: Loaded "module-bluez5-discover" (index: #12; argument: "").
I: [pulseaudio] module.c: Loaded "module-bluetooth-discover" (index: #11; argument: "").
I: [pulseaudio] module.c: Loaded "module-dbus-protocol" (index: #13; argument: "").
I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #14; argument: "").
I: [pulseaudio] module.c: Loaded "module-gsettings" (index: #15; argument: "").
I: [pulseaudio] module-default-device-restore.c: No previous default sink setting, ignoring.
I: [pulseaudio] module-default-device-restore.c: No previous default source setting, ignoring.
I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #16; argument: "").
I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #17; argument: "").
I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #18; argument: "").
I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #19; argument: "").
I: [pulseaudio] module.c: Loaded "module-console-kit" (index: #20; argument: "").
I: [pulseaudio] client.c: Created 0 "Login Session 2"
I: [pulseaudio] core.c: exit_idle_time: 20 -> 0
I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #21; argument: "").
I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #22; argument: "").
I: [pulseaudio] module.c: Loaded "module-role-cork" (index: #23; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #24; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #25; argument: "").
W: [pulseaudio] cli-command.c: stat('/etc/pulse/default.pa.d'): No such file or directory
I: [pulseaudio] main.c: Daemon startup complete.
I: [pulseaudio] client.c: Created 1 "Native client (UNIX socket client)"
I: [pulseaudio] client.c: Created 2 "Native client (UNIX socket client)"
I: [pulseaudio] protocol-native.c: Got credentials: uid=1000 gid=1000 success=1
I: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1 idle for too long, suspending ...
I: [alsa-sink-HDMI 1] alsa-sink.c: Device suspended...
E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
I: [pulseaudio] main.c: Got signal SIGINT.
I: [pulseaudio] main.c: Exiting.
I: [pulseaudio] main.c: Daemon shutdown initiated.
I: [pulseaudio] module.c: Unloading "module-filter-apply" (index: #25).
I: [pulseaudio] module.c: Unloaded "module-filter-apply" (index: #25).
I: [pulseaudio] module.c: Unloading "module-filter-heuristics" (index: #24).
I: [pulseaudio] module.c: Unloaded "module-filter-heuristics" (index: #24).
I: [pulseaudio] module.c: Unloading "module-role-cork" (index: #23).
I: [pulseaudio] module.c: Unloaded "module-role-cork" (index: #23).
I: [pulseaudio] module.c: Unloading "module-position-event-sounds" (index: #22).
I: [pulseaudio] module.c: Unloaded "module-position-event-sounds" (index: #22).
I: [pulseaudio] module.c: Unloading "module-systemd-login" (index: #21).
I: [pulseaudio] client.c: Freed 0 "Login Session 2"
I: [pulseaudio] module.c: Unloaded "module-systemd-login" (index: #21).
I: [pulseaudio] module.c: Unloading "module-console-kit" (index: #20).
I: [pulseaudio] module.c: Unloaded "module-console-kit" (index: #20).
I: [pulseaudio] module.c: Unloading "module-suspend-on-idle" (index: #19).
I: [alsa-sink-HDMI 1] alsa-sink.c: Trying resume...
I: [alsa-sink-HDMI 1] alsa-util.c: Trying to disable ALSA period wakeups, using timers only
I: [alsa-sink-HDMI 1] alsa-util.c: ALSA period wakeups disabled
I: [alsa-sink-HDMI 1] alsa-sink.c: Time scheduling watermark is 20.00ms
I: [alsa-sink-HDMI 1] alsa-sink.c: Resumed successfully...
I: [pulseaudio] module.c: Unloaded "module-suspend-on-idle" (index: #19).
I: [pulseaudio] module.c: Unloading "module-intended-roles" (index: #18).
I: [pulseaudio] module.c: Unloaded "module-intended-roles" (index: #18).
I: [pulseaudio] module.c: Unloading "module-always-sink" (index: #17).
I: [pulseaudio] module.c: Unloaded "module-always-sink" (index: #17).
I: [pulseaudio] module.c: Unloading "module-default-device-restore" (index: #16).
I: [pulseaudio] module.c: Unloaded "module-default-device-restore" (index: #16).
I: [pulseaudio] module.c: Unloading "module-gsettings" (index: #15).
I: [pulseaudio] module.c: Unloaded "module-gsettings" (index: #15).
I: [pulseaudio] module.c: Unloading "module-native-protocol-unix" (index: #14).
I: [pulseaudio] client.c: Freed 1 "Plasma PA"
I: [pulseaudio] client.c: Freed 2 "Plasma PA"
I: [pulseaudio] module.c: Unloaded "module-native-protocol-unix" (index: #14).
I: [pulseaudio] module.c: Unloading "module-dbus-protocol" (index: #13).
I: [pulseaudio] module.c: Unloaded "module-dbus-protocol" (index: #13).
I: [pulseaudio] module.c: Unloading "module-bluez5-discover" (index: #12).
I: [pulseaudio] module.c: Unloaded "module-bluez5-discover" (index: #12).
I: [pulseaudio] module.c: Unloading "module-bluetooth-discover" (index: #11).
I: [pulseaudio] module.c: Unloaded "module-bluetooth-discover" (index: #11).
I: [pulseaudio] module.c: Unloading "module-bluetooth-policy" (index: #10).
I: [pulseaudio] module.c: Unloaded "module-bluetooth-policy" (index: #10).
I: [pulseaudio] module.c: Unloading "module-jackdbus-detect" (index: #9).
I: [pulseaudio] module.c: Unloaded "module-jackdbus-detect" (index: #9).
I: [pulseaudio] module.c: Unloading "module-alsa-card" (index: #7).
I: [pulseaudio] card.c: Freed 1 "alsa_card.pci-0000_30_00.1"
I: [pulseaudio] module.c: Unloaded "module-alsa-card" (index: #7).
I: [pulseaudio] module.c: Unloading "module-alsa-card" (index: #6).
I: [pulseaudio] core.c: default_sink: alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1 -> (unset)
I: [pulseaudio] core.c: default_source: alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1.monitor -> (unset)
I: [pulseaudio] sink.c: Freeing sink 0 "alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1"
I: [pulseaudio] source.c: Freeing source 0 "alsa_output.pci-0000_10_00.1.hdmi-stereo-extra1.monitor"
I: [pulseaudio] card.c: Freed 0 "alsa_card.pci-0000_10_00.1"
I: [pulseaudio] module.c: Unloaded "module-alsa-card" (index: #6).
I: [pulseaudio] module.c: Unloading "module-udev-detect" (index: #5).
I: [pulseaudio] module.c: Unloaded "module-udev-detect" (index: #5).
I: [pulseaudio] module.c: Unloading "module-switch-on-port-available" (index: #4).
I: [pulseaudio] module.c: Unloaded "module-switch-on-port-available" (index: #4).
I: [pulseaudio] module.c: Unloading "module-augment-properties" (index: #3).
I: [pulseaudio] module.c: Unloaded "module-augment-properties" (index: #3).
I: [pulseaudio] module.c: Unloading "module-card-restore" (index: #2).
I: [pulseaudio] module.c: Unloaded "module-card-restore" (index: #2).
I: [pulseaudio] module.c: Unloading "module-stream-restore" (index: #1).
I: [pulseaudio] module.c: Unloaded "module-stream-restore" (index: #1).
I: [pulseaudio] module.c: Unloading "module-device-restore" (index: #0).
I: [pulseaudio] module.c: Unloaded "module-device-restore" (index: #0).
I: [pulseaudio] main.c: Daemon terminated.
inxi -xxxACS:
Host: Jericho Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Info: 8-core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB
L3: 16 MiB
Speed (MHz): avg: 3133 high: 3688 min/max: 1400/4672 boost: enabled cores:
1: 2781 2: 2994 3: 3387 4: 3688 5: 3597 6: 2993 7: 2995 8: 2994 9: 2995
10: 2994 11: 2994 12: 2993 13: 2992 14: 2992 15: 3214 16: 3528
bogomips: 121414
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 10:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 30:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
aplay -lL:
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, 27S2R
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2 *
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
hdmi:CARD=NVidia,DEV=6
HDA NVidia, HDMI 6
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
hdmi:CARD=Generic_1,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
hdmi:CARD=Generic_1,DEV=1
HD-Audio Generic, HDMI 1
HDMI Audio Output
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
front:CARD=Generic
Front output / input
surround21:CARD=Generic
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
HD-Audio Generic
USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [27S2R ]
Subdevices: 0/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2 *]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
The problem card is the AMD Family 17h/19h HD Audio / card2 / pci-0000_30_00.6.
I’ve looked through many of the threads, recent and old, and haven’t figured it out. I would much appreciate any assistance you all could offer me.
