Hello, I need to configure 1 HDMI and 1 DP external monitors for my laptop Dell G5 5590.
After reading the forum I have managed to see the background on both monitors.
I have done this with optimus-manager --switch nvidia
But now:
I can’t move the mouse to the second monitor
I can’t see the menu bar on the bottom of the first monitor
The following is my configuration:
#inxi -Gazy
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel ports: active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0380
Device-2: NVIDIA TU106BM [GeForce RTX 2070 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none off: HDMI-A-3,eDP-1
empty: DP-3 bus-ID: 01:00.0 chip-ID: 10de:1f50 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia gpu: i915,nvidia,nvidia-nvswitch display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 4480x2886 s-dpi: 96 s-size: 1185x764mm (46.65x30.08")
s-diag: 1410mm (55.51")
Monitor-1: DP-1 mapped: DP-0 pos: primary,bottom-l
model: Philips PHL 275E2F serial: <filter> built: 2022 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: not-matched mapped: DP-1-1 pos: primary,top-left res: 2560x1440
hz: 60 dpi: 109 size: 597x336mm (23.5x13.23") diag: 685mm (26.97")
modes: N/A
Monitor-3: not-matched mapped: HDMI-0 pos: middle-r res: 2560x1440 hz: 60
dpi: 109 size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2070 with Max-Q Design/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
$ optimus-manager --status
Optimus Manager (Client) version 1.4
Current GPU mode : nvidia
GPU mode requested for next login : no change
GPU at startup : nvidia
Temporary config path: no
post output from:
inxi -Fazy
mhwd -l
mgazzin:
Dell G5 5590
Might consider this Dell G5 5590-9340 - ArchWiki
$ inxi -Fazy
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=690cde85-547f-4e22-9b48-1c90b2ae589c rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0D2DM3 v: A00 serial: <superuser required> UEFI: Dell
v: 1.15.3 date: 06/04/2021
ID-1: BAT0 charge: 56.9 Wh (100.0%) condition: 56.9/90.0 Wh (63.3%)
volts: 12.6 min: 11.4 model: BYD DELL 6YV0V94 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 799 10: 800 11: 800 12: 800 bogomips: 62431
Type: l1tf
Display: x11 server: X.Org v: 21.1.3 compositors: 1: xfwm v: 4.16.1
2: marco driver: X: loaded: modesetting,nvidia
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
modes: N/A
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: GN Netcom Jabra EVOLVE Link MS type: USB
driver: jabra,snd-usb-audio,usbhid bus-ID: 1-1.3:6 chip-ID: 0b0e:0305
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-126317442d71 state: down mac: <filter>
IF-ID-2: br-39ac8ac239cb state: down mac: <filter>
IF-ID-3: br-40ad09582709 state: down mac: <filter>
IF-ID-4: br-5d6f228d3eab state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-94f83a267e39 state: down mac: <filter>
IF-ID-6: br-b3ac9654bb4b state: down mac: <filter>
IF-ID-7: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-8: docker0 state: down mac: <filter>
IF-ID-9: veth4a2e2d8 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.88 TiB used: 435.69 GiB (22.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Ultra
size: 57.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.44 TiB size: 1.42 TiB (98.36%) used: 435.61 GiB (30.1%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 76.1 MiB (11.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.76 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 62.0 C pch: 73.0 C mobo: N/A gpu: nvidia
temp: 64 C
Processes: 368 Uptime: 0m wakeups: 3 Memory: 15.44 GiB
used: 2.77 GiB (17.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 alt: 10 clang: 13.0.1 Packages: pacman: 1747 lib: 453 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
$ mhwd -l
> 0000:01:00.0 (0300:10de:1f50) Display controller nVidia Corporation:
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0380:8086:3e9b) Display controller Intel Corporation:
What do you think @brahma ?
Thanks @bogdancovaciu , before I having this issue I had one external HDMI 27 inches monitor.
I did not have any issue.
Now I have two 27 inches external monitors, one connected to HDMI and the other one connected to the DP port.
The documentation is good but it does not mention configuration with two monitors.
you can create the file in x11 as is mentioned in the bogdans link:
sudo nano /etc/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
put inside it this:
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
Option "PrimaryGPU" "yes"
ModulePath "/usr/lib/nvidia/xorg"
ModulePath "/usr/lib/xorg/modules"
EndSection
save the file with ctrl+x
run this command: sudo mkinitcpio -P
then reboot and check if it helped
Done.
I am getting:
[FAILED] Failed to start Light Display Manager
so you stuck at black screen?
Sorry my bad, there was a typo in .conf file. Now it boots but it does not solve the problem.
so remove the file with:
sudo rm /etc/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
run again: sudo mkinitcpio -P
post also output from:
xrandr -q
ok!
$ xrandr -q
Screen 0: minimum 8 x 8, current 4480 x 2886, maximum 32767 x 32767
HDMI-0 connected 2560x1440+1920+1440 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x1440 59.91
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 connected primary 1920x1080+0+1806 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-1-1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+ 74.97
1920x1080 74.97 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1280x1440 59.91
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x720 60.00 50.00 59.94
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
2560x1440 (0x1bd) 241.500MHz +HSync +VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
1920x1080 (0x1be) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1c0) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1280x1440 (0x1c3) 156.000MHz -HSync +VSync
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.45KHz
v: height 1440 start 1443 end 1453 total 1493 clock 59.91Hz
1680x1050 (0x1c1) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x1c4) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c5) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x1c2) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x960 (0x1c6) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x720 (0x1c7) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c9) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x1ca) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1cb) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1cc) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1ce) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1cd) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1cf) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1d0) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x1d1) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d2) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d3) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d5) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
Now I can only work on DP-1-1 and I can see HDMI-0. I do not use DP-0 because the lid of my laptop is closed.
and in system settings/ display and monitor, are there some options to set up your screens as you desire?
Yes I can choose resolution, scale, rotation, etc.
But the problem are still:
The mouse does not move to the second monitor. So I can use only the first.
I can’t see the LDM menu bar that normally it is on the bottom of the screen
check this link , maybe it will be helpfull
OK! I just needed to arrange the monitor one beside the other and now it is working.
The issue is fixed. Thank you very much!
