HDMI does not sound, but headphones do
I just installed the latest version of the Manjaro system on my desktop yesterday, and I connected it to an external monitor using an HDMI cable. While testing the sound system, I found a problem. When I plugged in the headphones, I could hear sound from the headphones, and when I unplugged them, no sound could come out.
My manjaro system version:
Kernel: Linux 5.15.60-1-MANJARO
Architecture: x86-64
Hardware Vendor: ASUS
Hardware Model: System Product Name
Firmware Version: 0305
I’ve searched for related posts, but I still don’t know how to fix it.
The aplay -l output:
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [AG273QG3R3B]
  Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 0: ALCS1200A Analog [ALCS1200A Analog]
  Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 1: ALCS1200A Digital [ALCS1200A Digital]
  Subdevices: 0/1
The sudo dmesg | grep snd output:
[    3.493233] snd_hda_intel 0000:07:00.1: enabling device (0000 -> 0002)
[    3.493355] snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
[    3.493506] snd_hda_intel 0000:07:00.6: enabling device (0000 -> 0002)
[    3.644369] snd_hda_codec_realtek hdaudioC1D0: ALCS1200A: SKU not ready 0x00000000
[    3.645276] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALCS1200A: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    3.645279] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.645280] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.645282] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.645283] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[    3.645284] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.645285] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    3.645286] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    3.645287] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    4.362999] snd_hda_intel 0000:07:00.1: bound 0000:07:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
The pacmd list-sinks output:
1 sink(s) available.
  * index: 12
	driver: <module-alsa-card.c>
	flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9037
	volume: front-left: 45220 /  69% / -9.67 dB,   front-right: 45220 /  69% / -9.67 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 13
	sample spec: s16le 2ch 44100Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
	card: 1 <alsa_card.pci-0000_07_00.6>
	module: 7
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALCS1200A Digital"
		alsa.id = "ALCS1200A Digital"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "1"
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.long_card_name = "HD-Audio Generic at 0xfcc80000 irq 80"
		device.bus_path = "pci-0000:07:00.6"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.6/sound/card1"
		device.bus = "pci"
		device.vendor.id = "1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.product.id = "15e3"
		device.product.name = "Family 17h/19h HD Audio Controller"
		device.string = "iec958:1"
		device.buffering.buffer_size = "352768"
		device.buffering.fragment_size = "176384"
		device.access_mode = "mmap+timer"
		device.profile.name = "iec958-stereo"
		device.profile.description = "Digital Stereo (IEC958)"
		device.description = "Family 17h/19h HD Audio Controller Digital Stereo (IEC958)"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	ports:
		iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
	active port: <iec958-stereo-output>
I have struggled with this the whole afternoon. Can someone be kind enough to help me out?
Welcome to Manjaro forum
PulseAudio data is showing only one sink (output) available for Card 1
Card 1 is set to use Profile iec958-stereo-output: Digital Output (S/PDIF)
in ALSA – device 1: ALCS1200A Digital [ALCS1200A Digital]
so audio playback is trying to use either orange SPDIF jack or digital optical output
Please post response to this command to show all profiles for both cards
pactl list cards
I expect Card 0 for HDMI output to monitor is set to Active Profile: off
But also to show which Profile to use for connection to the monitor speakers
and analog Profiles available for Card 1 for headphone jack
Thanks for your reply. The pactl list cards output:
Card #0
	Driver: module-alsa-card.c
	Owner Module: 6
	Properties:
		alsa.card = "0"
		alsa.long_card_name = "HD-Audio Generic at 0xfcc88000 irq 79"
		device.bus_path = "pci-0000:07:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.1/sound/card0"
		device.bus = "pci"
		device.vendor.id = "1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		device.product.id = "1637"
		device.product.name = "Renoir Radeon High Definition Audio Controller"
		device.string = "0"
		device.description = "Renoir Radeon High Definition Audio Controller"
	Profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 38468, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:hdmi-stereo-extra1
	Ports:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, available)
			Properties:
				device.product.name = "AG273QG3R3B"
			Part of profile(s): output:hdmi-stereo-extra1
Card #1
	Owner Module: 7
	Properties:
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
		device.description = "Family 17h/19h HD Audio Controller"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
		output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
		output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
		output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
		output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
		output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 38268, available: yes)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
		output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
		output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
	Active Profile: output:iec958-stereo+input:analog-stereo
	Ports:
		analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
		analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
			Properties:
		analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
		analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
			Properties:
		iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
What does this mean? Could you please give a bit more explanation? Looks like very similar to No speakers out of laptop but headphones work
See here for instructions on configuration of the sound devices: How do I permanently set the default audio device in Manjaro xfce with Pipewire? - #12 by Mirdarthos
Responses for both cards were not as expected
Card 0 for HDMI is usually off when OS is first installed
but response shows it is configured to use output output:hdmi-stereo-extra1
and this output is available: yes) and connected to monitor AG273QG3R3B
Audio to monitor speakers should be working, but PulseAudio is using Card 1 as default-sink for audio playback (pacmd list-sinks uses an asterisk * to indicate default sink)
Changing the default sink should get audio playback to monitor speakers working
pactl set-default-sink alsa_output.pci-0000_07_00.1.hdmi-stereo-extra1
Card 1 is using digital output iec958-stereo because it is the only one shown as: available:yes)
All other Profiles for analog-stereo or analog-surround... are shown as available: no)
Please post more information about ALSA settings for Card 1
amixer --card=1
