this problem is weird
what if i uninstall pipewire?
KDE requires pipewire base package so uninstalling is not possible for this DE
But the pipewire systemd socket and service can be disabled to continue using PulseAudio without interference
systemctl --user mask --now pipewire.socket && systemctl --user stop pipewire.service
Or install manjaro-pipewire metapackage to install the additional dependency files for Pipewire and remove PulseAudio packages
i did the command, now what.
If you have disabled pipewire service inxi -Ax should confirm that only PulseAudio is now running
and Pipewire cannot cause any problem with the audio codec
Sound Server-4: PipeWire v: 0.3.25 running: no
it is like this. No difference tho.
Please post response to this command to check if the PulseAudio profile for the HDMI output is now shown as available
LANG=C pacmd list-cards
and this to show ALSA audio controls
amixer -c0
Since you have a nvidia maybe you need to do this,can you open the file in /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules and put a # before the word ACTION afther the text Remove nvidia audio devices? like this
# Remove NVIDIA Audio devices, if present
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
Save that file and reboot the system,the HDMI audio should work now.
already did that
The PulseAudio Profiles for output:hdmi-stereo-extra1 is still shown as - available: no
PulseAudio will avoid sending an audio stream to an audio output that appears to be unavailable
I suggest you try turning off the Auto-Mute Mode setting in ALSA
amixer -c0 sset 'Auto-Mute Mode' Disabled
But if output:hdmi-stereo-extra1 is still shown as - available: no
try clearing PulseAudio user settings in home folder
rm ~/.config/pulse/cookie ~/.config/pulse/*.tdb
and reboot system so PulseAudio can create new versions of these files
it’s like this now
HDMI 2 switches from “avaiable: no” to “avaible: unknown” and when i try to do a speaker-test on the corresponding device (card 0, device 7) it plays static from the tv speaker.
That’s something!
OK! I was able to get HMDI audio working! Had to reboot my PC. I think that the solution is disabling Auto-Mute and commenting that line in the mhwd-prime-powermanagment.rules config.
