Recently installed Manjaro and everything is flawless, but HDMI Audio isn’t working.
I’ve got the latest stable and reccomended kernel with the latest NVIDIA propietary drivers.
Specs: i7 6700HQ; GTX 950M; 8GB RAM
Please post the output of inxi -Aazy.
Here it is:
Having both PipeWire and PulseAudio running is a bit strange, but in any case, what’s the output of head -n99 /etc/udev/rules.d/*?
See this.
it’s already there tho
Huh, I missed that entirely. I assume you have rebooted since making that change?
Yup. Rebooted at least 3 times
Interesting, please start sudo udevadm monitor, then run echo 1 | sudo tee /sys/bus/pci/rescan, then post the output of udevadm.
in another terminal?
Yes, udevadm should be running when you run the other command, don’t stop it.
there’s no output.
Please put # in front of the other two lines that begin with ACTION=="add", then reboot, run lspci -d 10de: -nn and post the output.
what if i uninstall pipewire?
I would be surprised if that did anything because the PCI device is not present for some reason, so I think the problem is on a lower level. I don’t think PipeWire has anything to do with it. But you can try, we’ll see.
if I do aplay -l it shows a lot of intel stuff.
Do you want a screenshot?
So, i tried doing a speaker-test on all of the devices and 1 of them worked! But it only played static.
That’s probably the built-in audio device that you can even see in the output of inxi -Aazy.
What do you mean? HDMI audio worked?
