I have installed manjaro and i connected my tv with hdmi cable.
it works fine but when i want to choose the output sound
Digital Stereo(HDMI) + Output Unavailable … N
is is a longer list all are Unavailable…
what is the problem?
Hello,we need for info,please see this
what info do you need tell me?
It is not the first time I use Manjaro, the last version I’ve used was in 2020 but
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
[khelpix@khelpix-flores ~]$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 1 associated providers: 1 name:modesetting
Provider 1: id: 0x26f cap: 0x2, Sink Output crtcs: 4 outputs: 5 associated providers: 1 name:NVIDIA-G0
[khelpix@khelpix-flores ~]$ nvidia-smi
Sat Jun 26 09:17:04 2021
| NVIDIA-SMI 465.31 Driver Version: 465.31 CUDA Version: 11.3 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 45C P8 9W / N/A | 54MiB / 5944MiB | 27% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 795 G /usr/lib/Xorg 53MiB |
-flores ~]$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog] Subdevices: 0/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4] Subdevices: 1/1 Subdevice #0: subdevice #0
s ~]$ pacman -Ss nvidia | grep installed core/mhwd-nvidia 465.31-1 [installed] core/mhwd-nvidia-390xx 390.143-1 [installed] extra/libvdpau 1.4-1 [installed] extra/linux510-nvidia 465.31-6 (linux510-extramodules) [installed] extra/nvidia-prime 1.0-4 [installed] extra/nvidia-utils 465.31-1 [installed] multilib/lib32-libvdpau 1.4-1 [installed] multilib/lib32-nvidia-utils 465.31-1 [installed]
I just link the thread where you can read how to format properly the code and put the only single line of code to give every info we need…
Anyway…
So this is laptop with Intel + Nvidia card right? try editing the file /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules and put a # after the line # Remove NVIDIA Audio devices, if present,should be like this
#ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x040300”, ATTR{remove}=“1”
save and reboot,the audio should work now.
■■■■ this is awesome, this was the solution ->>>>>>
sudo nano /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules
just set this
