Hi !
I’m doing some cleanup and have found an old Seagate HDD that won’t show up in fdisk nor gparted.
I can see it in the disks gui (screenshot) but i can’t interact with it.
# fdisk -l
Disk /dev/sda: 223,57 GiB, 240057409536 bytes, 468862128 sectors
Disk model: KINGSTON SA400S3
Disklabel type: dos
Disk identifier: 0x81032ea2
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 450402085 450400038 214,8G 83 Linux
/dev/sda2 450402086 468857024 18454939 8,8G 82 Linux swap / Solaris
Disk /dev/sdb: 1,82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: ST2000DM001-1ER1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 91D9BEFD-B9FF-4964-9173-262956BF5D63
Device Start End Sectors Size Type
/dev/sdb1 2048 3907028991 3907026944 1,8T Microsoft basic data
$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0c45:652f Microdia Backlit Gaming Keyboard
Bus 003 Device 005: ID 1d57:ad17 Xenta
Bus 003 Device 003: ID 05e3:0604 Genesys Logic, Inc. USB 1.1 Hub
Bus 003 Device 002: ID 5986:0299 Acer, Inc Lenovo Integrated Webcam
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 005: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
dmesg leads me to believe that this is an hardware error
# dmesg
[ 1859.528226] usb 2-4: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 1859.552807] usb 2-4: New USB device found, idVendor=152d, idProduct=1561, bcdDevice= 2.04
[ 1859.552810] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1859.552811] usb 2-4: Product: SABRENT
[ 1859.552812] usb 2-4: Manufacturer: SABRENT
[ 1859.552813] usb 2-4: SerialNumber: DB9876543214E
[ 1859.577300] scsi host10: uas
[ 1859.577921] scsi 10:0:0:0: Direct-Access SABRENT 0204 PQ: 0 ANSI: 6
[ 1865.518639] sd 10:0:0:0: [sdc] Unit Not Ready
[ 1865.518641] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.518643] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.519501] sd 10:0:0:0: [sdc] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1865.519502] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.519503] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.520394] sd 10:0:0:0: [sdc] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1865.520395] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.520396] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.520952] sd 10:0:0:0: [sdc] 0 512-byte logical blocks: (0 B/0 B)
[ 1865.520953] sd 10:0:0:0: [sdc] 0-byte physical blocks
[ 1865.521808] sd 10:0:0:0: [sdc] Test WP failed, assume Write Enabled
[ 1865.522109] sd 10:0:0:0: [sdc] Asking for cache data failed
[ 1865.522110] sd 10:0:0:0: [sdc] Assuming drive cache: write through
[ 1865.523003] sd 10:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of physical block size (0 bytes)
[ 1865.535383] sd 10:0:0:0: [sdc] Unit Not Ready
[ 1865.535387] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.535390] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.536269] sd 10:0:0:0: [sdc] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1865.536271] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.536274] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.537164] sd 10:0:0:0: [sdc] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1865.537166] sd 10:0:0:0: [sdc] Sense Key : Hardware Error [current]
[ 1865.537169] sd 10:0:0:0: [sdc] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1865.539770] sd 10:0:0:0: [sdc] Attached SCSI disk
Do you guys have any idea of something I could try to fix this, or have I gained a paperweight ?
Best,
