Hi,
I’ve run into a problem with my HDD (Toshiba DT01ACA100) and after a couple of hours of googleing and checking forum posts here I’m now requesting help.
What’s the problem: my HDD is somehow aggressively going into standby and therefore spinning down. I installed the system on my SSD, but data is located on my HDD. As you can imagine, every time I am accessing a program (e.g. dolphin), the HDD needs to spin up again, slowing down my work A LOT. The spin down happens approximately after 30s idle time.
What I’ve tried:
hdparm
: setting both the standby timeout (-S flag) and setting the advanced power management feature (-B flag). -B flag is accepted and set to >127, however I somehow can’t set the -S flag. After executing e.g.hdparm -S 200
on the device, queueing it withhdparm -S
returns that no value is set. - using the gnome disk utility so set standby timeout and APM. GUI is telling me it is set, but queueing it with hdparm will give no value for -S (bad/missing standby-interval value).
- I disabled the “SATA power management” feature in my BIOS. I wasn’t able to locate any AHCI settings.
I migrated from Arch to Manjaro lately, on Arch this was not a problem at all. Anyway, loving Manjaro so far.
Output of dmesg
with a couple of start / stop activity.
[ 5409.422702] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5409.424029] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5409.424084] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5409.425538] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5409.425547] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5409.425710] ata3.00: configured for UDMA/133
[ 5409.425880] sd 2:0:0:0: [sda] Starting disk
[ 5418.021636] audit: type=1131 audit(1636713093.173:275): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5432.492075] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 5432.492466] sd 2:0:0:0: [sda] Stopping disk
[ 5581.402444] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5581.403642] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5581.403648] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5581.405110] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5581.405117] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5581.405244] ata3.00: configured for UDMA/133
[ 5581.405366] sd 2:0:0:0: [sda] Starting disk
[ 5631.048745] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 5631.049278] sd 2:0:0:0: [sda] Stopping disk
[ 5733.269384] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5733.270727] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5733.270740] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5733.272355] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 5733.272368] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 5733.272561] ata3.00: configured for UDMA/133
[ 5733.272844] sd 2:0:0:0: [sda] Starting disk
[ 5756.282064] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 5756.282395] sd 2:0:0:0: [sda] Stopping disk
[ 6009.419098] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6009.420476] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6009.420491] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6009.422236] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6009.422250] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6009.422480] ata3.00: configured for UDMA/133
[ 6009.422709] sd 2:0:0:0: [sda] Starting disk
[ 6032.478647] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6032.478981] sd 2:0:0:0: [sda] Stopping disk
[ 6079.012424] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6079.013804] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6079.013818] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6079.015381] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6079.015394] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6079.015600] ata3.00: configured for UDMA/133
[ 6079.015818] sd 2:0:0:0: [sda] Starting disk
[ 6102.085301] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6102.085663] sd 2:0:0:0: [sda] Stopping disk
[ 6120.139073] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6120.140442] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6120.140455] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6120.142107] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6120.142120] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6120.142320] ata3.00: configured for UDMA/133
[ 6120.142538] sd 2:0:0:0: [sda] Starting disk
[ 6143.185322] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6143.185670] sd 2:0:0:0: [sda] Stopping disk
[ 6570.425335] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6570.426721] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6570.426735] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6570.428424] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6570.428439] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6570.428605] ata3.00: configured for UDMA/133
[ 6570.428883] sd 2:0:0:0: [sda] Starting disk
[ 6599.773974] audit: type=1100 audit(1636714274.926:276): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="muellerl" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6599.777580] audit: type=1101 audit(1636714274.930:277): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="muellerl" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6599.778214] audit: type=1110 audit(1636714274.930:278): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6599.786310] audit: type=1105 audit(1636714274.940:279): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6599.792615] audit: type=1106 audit(1636714274.946:280): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6599.792848] audit: type=1104 audit(1636714274.946:281): pid=29887 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6625.715249] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6625.715612] sd 2:0:0:0: [sda] Stopping disk
[ 6631.095617] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6631.096939] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6631.096952] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6631.098577] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6631.098587] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6631.098819] ata3.00: configured for UDMA/133
[ 6631.099043] sd 2:0:0:0: [sda] Starting disk
[ 6675.745189] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6675.745534] sd 2:0:0:0: [sda] Stopping disk
[ 6681.168993] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6681.170336] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6681.170349] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6681.172003] ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
[ 6681.172017] ata3.00: ACPI cmd b1/c1:00:00:00:00:e0 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 6681.172230] ata3.00: configured for UDMA/133
[ 6681.172474] sd 2:0:0:0: [sda] Starting disk
[ 6703.991854] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 6703.992211] sd 2:0:0:0: [sda] Stopping disk
[ 6929.825216] audit: type=1100 audit(1636714604.980:282): pid=30287 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="muellerl" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6929.827675] audit: type=1101 audit(1636714604.980:283): pid=30287 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="muellerl" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6929.828058] audit: type=1110 audit(1636714604.980:284): pid=30287 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[ 6929.832577] audit: type=1105 audit(1636714604.986:285): pid=30287 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
inxi
output:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=1f198e94-109f-481a-9715-de7e67df55a5 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=59f8ef9f-0a3b-45c5-8666-41402912a9b3 udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: HP product: HP ProDesk 600 G4 MT v: N/A
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: HP model: 83EC v: KBC Version 07.D2.00 serial: <filter> UEFI: HP
v: Q02 Ver. 02.06.03 date: 02/15/2019
Device-1: hidpp_battery_2 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_3 model: Logitech Wireless Mouse MX Master 3
status: Discharging
RAM: total: 15.42 GiB used: 10.46 GiB (67.9%)
Info: 6-Core model: Intel Core i5-8600 bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA
cache: L2: 9 MiB bogomips: 37213
Speed: 900 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 1160
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
Device-2: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Hewlett-Packard
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c02 class-ID: 0300
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.4x13.5")
s-diag: 1252mm (49.3")
Monitor-1: DP-2 res: 2560x1440 hz: 75 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-4 res: 2560x1440 hz: 75 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-3: RODE Microphones RØDE NT-USB Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 19f7:0015
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.38 TiB used: 702.28 GiB (49.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC501 HFM512GDJTNG-8310A size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80002C00 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
type: HDD rpm: 7200 serial: <filter> rev: A8L0 scheme: GPT
Optical-1: /dev/sr0 vendor: hp HLDS model: DVDRW GUD1N rev: LD04
dev-links: cdrom
ID-1: / raw-size: 220.25 GiB size: 220.25 GiB (100.00%)
used: 121.08 GiB (55.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 1f198e94-109f-481a-9715-de7e67df55a5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 94 MiB (36.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 9EC9-1CEA
ID-3: /home raw-size: 220.25 GiB size: 220.25 GiB (100.00%)
ID-4: /run/media/muellerl/C raw-size: 250 GiB size: 250 GiB (100.00%)
used: 205.85 GiB (82.3%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: C uuid: 4C307FBB307FAA9A
ID-5: /run/media/muellerl/D raw-size: 931.39 GiB size: 931.39 GiB (100.00%)
used: 374.73 GiB (40.2%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: D
uuid: C408CD1C08CD0DFC
ID-6: /var/cache raw-size: 220.25 GiB size: 220.25 GiB (100.00%)
ID-7: /var/log raw-size: 220.25 GiB size: 220.25 GiB (100.00%)
ID-1: swap-1 type: partition size: 6.42 GiB used: 536.8 MiB (8.2%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 59f8ef9f-0a3b-45c5-8666-41402912a9b3
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: RODE Microphones RØDE NT-USB Mini type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 19f7:0015 class-ID: 0300
serial: <filter>
Hub-2: 1-9:6 info: Genesys Logic Hub ports: 2 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-9.2:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-10:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 317 Uptime: 2h 4m wakeups: 35 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 alt: 8 clang: 12.0.1 Packages:
pacman: 1468 lib: 382 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
I’m auto mounting the HDD, my fstab
, but the problem existed before I added it to fstab.
UUID="theUuid" /run/media/../D ntfs-3g defaults 0 0
I appreciate your help. Thanks in advance.
Regards
