Having updated, GRUB menu now appears at boot with a five second timer and duplicate entries
Having updated, I notice that when I boot up the machine the Grub menu now appears at boot with five second timer. How do I change it back so that at boot the menu is bypassed unless I interrupt by holding down the shift key?
UPDATE: Oh, and I also notice that I have some duplicate Grub entries now.
I have no why these entries suddenly appeared. Would that explain the sudden timer issue? Any help would be appreciated!
The grub settings are in /etc/default/grub.
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
Please don’t forget to update the grub configuration after changes made:
sudo update-grub
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader
I’d change this, but that’s what is already set in /etc/default/grub
I did do a sudo update-grub and rebooted to be sure.
Any other ideas? It seems very very strange that this GRUB_TIMEOUT_STYLE=hidden seems to be ignored right now.
It is if you have more than manjaro installed (dual-boot, etc).
This has been the case for a long time.
I’m guessing that whatever problem you have with multiple entries is causing them to be recognized as multiple operating systems and thus the forced menu.
It appears this may have something to do with your encryption setup as the ‘second’ manjaro is a a luks path.
I’ve used the same setup for a few years now, and this only cropped up after the most recent Manjaro update. I have only one OS on this machine.
Did you not read the whole thing?
Yes I read that. What process manages that for grub? Is it os-prober? I only have two partitions on my drive, a EFI boot partition, and an encrypted btrfs partition which contains Manjaro and my data.
A few other people seem to have had this problem after a recent update. The only thing that seems to be a consistent factor is the use of BTRFS as the file system.
Here is my inxi report:
  Kernel: 6.6.74-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=4a0cc8d5-31af-455f-ae55-faadde0e3603 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=2a9099ad-5c2d-43f8-bd02-80c790d1cdfc:luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc
    root=/dev/mapper/luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc splash
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker,xfce4-screensaver vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
    v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.P0 date: 07/15/2024
  System RAM: total: 32 GiB available: 31.26 GiB used: 8.48 GiB (27.1%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 32 GiB speed: 2667 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: CL18-22-22 D4-3600 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: no module installed
  Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 3601 min/max: 2200/4672 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3601 2: 3601 3: 3601
    4: 3601 5: 3601 6: 3601 7: 3601 8: 3601 9: 3601 10: 3601 11: 3601 12: 3601
    13: 3601 14: 3601 15: 3601 16: 3601 17: 3601 18: 3601 19: 3601 20: 3601
    21: 3601 22: 3601 23: 3601 24: 3601 bogomips: 182456
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Sapphire NITRO+ driver: amdgpu v: kernel
    arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 2f:00.0 chip-ID: 1002:731f
    class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.15 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DisplayPort-0 model: LG (GoldStar) HDR 4K
    serial: <filter> built: 2020 res: mode: 3840x2160 hz: 60 scale: 100% (1)
    dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.278
    y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x480, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 19.1.7 DRM 3.54 6.6.74-1-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no
    x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  Device-4: Medeli USB Audio Device driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:3
    chip-ID: 0a67:11c0 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.6.74-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp39s0 state: down mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp41s0 state: up mac: <filter>
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-2: virbr0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0aa7
    class-ID: e001
  Device-1: luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc maj-min: 254:0
    type: LUKS dm: dm-0 size: 931.21 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
  Local Storage: total: 931.51 GiB used: 426.39 GiB (45.8%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 30.9 C scheme: GPT
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SE-S084D rev: TS02
    dev-links: cdrom
  ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
    used: 426.39 GiB (45.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc label: N/A
    uuid: 4a0cc8d5-31af-455f-ae55-faadde0e3603
    used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 65C6-DD33
  ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-4: /var/cache raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-5: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  Device-1: 1-1:2 info: SINO WEALTH Gaming KB type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
  Device-2: 1-2:3 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-3: 1-4:4 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-4: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: MediaTek Samsung SE-S084 Super WriteMaster Slim
    External DVD writer type: mass storage driver: usb-storage interfaces: 1
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
    chip-ID: 0e8d:1836 class-ID: 0802 serial: <filter>
  Device-2: 5-3:3 info: Medeli USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 5-4:4 info: Primax 0Y357C PMX-MMOCZUL (B) [Dell Laser Mouse]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 0461:4d51 class-ID: 0301
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 46.5 C mobo: N/A gpu: amdgpu temp: 35.0 C
    mem: 34.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1530 pm: pacman pkgs: 1483 libs: 497 tools: pamac pm: rpm pkgs: 0
    pm: flatpak pkgs: 41 pm: snap pkgs: 6
    1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 546
  1: cpu: 103% command: brave pid: 2897 mem: 3991.3 MiB (12.4%)
  2: cpu: 100% command: ps pid: 3523 mem: 3.94 MiB (0.0%)
  3: cpu: 19.8% command: brave pid: 2950 mem: 391.7 MiB (1.2%)
  4: cpu: 17.3% command: brave pid: 2555 mem: 516.4 MiB (1.6%)
  5: cpu: 10.8% command: brave pid: 2761 mem: 275.0 MiB (0.8%)
  Memory top: 5 of 546
  1: mem: 3991.3 MiB (12.4%) command: brave pid: 2897 cpu: 103%
  2: mem: 516.4 MiB (1.6%) command: brave pid: 2555 cpu: 17.3%
  3: mem: 391.7 MiB (1.2%) command: brave pid: 2950 cpu: 19.8%
  4: mem: 310.1 MiB (0.9%) command: brave pid: 2750 cpu: 5.5%
  5: mem: 302.4 MiB (0.9%) command: Xorg pid: 1412 cpu: 4.3%
  Processes: 546 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.37
fdisk
Disk model: WD_BLACK SN770 1TB
Disklabel type: gpt
Disk identifier: 15860E88-442C-4E12-A980-4554C2486B2F
Device          Start        End    Sectors   Size Type
/dev/nvme0n1p1   4096     618495     614400   300M EFI System
/dev/nvme0n1p2 618496 1953520064 1952901569 931.2G Linux filesystem
Disk /dev/mapper/luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc: 931.21 GiB, 999883506176 bytes, 1952897473 sectors
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop1: 55.36 MiB, 58052608 bytes, 113384 sectors
Disk /dev/loop2: 164.82 MiB, 172830720 bytes, 337560 sectors
Disk /dev/loop3: 91.69 MiB, 96141312 bytes, 187776 sectors
Disk /dev/loop4: 44.44 MiB, 46596096 bytes, 91008 sectors
Disk /dev/loop5: 44.3 MiB, 46448640 bytes, 90720 sectors
sudo blkid
/dev/nvme0n1p1: UUID="65C6-DD33" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="fe0fc278-7b72-46e2-bbcb-e139a9df2fd6"
/dev/nvme0n1p2: UUID="2a9099ad-5c2d-43f8-bd02-80c790d1cdfc" TYPE="crypto_LUKS" PARTLABEL="root" PARTUUID="cff11479-a38a-4ccb-9c1a-f0908bf38d89"
/dev/loop4: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop2: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/mapper/luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc: UUID="4a0cc8d5-31af-455f-ae55-faadde0e3603" UUID_SUB="f30009e0-c7db-4725-a6c2-b1f4c9f8b200" BLOCK_SIZE="4096" TYPE="btrfs"
/dev/loop5: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop3: BLOCK_SIZE="131072" TYPE="squashfs"
It’s not such a good idea to attach your issue to another one
which has been marked as solved in the meantime, too.
Better to create your own thread with your own description of your own problem.
I was just coming back here to do that. Didn’t mean to hijack the thread. Thank you.
Not a problem.
It was just meant as a reminder.
This is unrelated, but we suggest to provide swap.
Did you ever roolback with timeshift ?
Please describe your problem as precisely as possible. It may not be the same reason as in the other threads.
:footprints:
Re
I have 32gb of ram and have never had a problem, but will take under advisement.
To the best of my knowledge, I’ve never restored a timeshift snapshot.
Prior to the 2025-02-04 update, I was able to do the following:
  1. Power on the computer
  2. Enter my LUKS encryption password
  3. Watch the machine boot and then log in.
After the 2025-02-04 update, the grub menu now appears with a five second timer. This, even though my /etc/default/grub.cfg has
And now I have the following menu items:
The second entry with the luks identifier was not there before.
There was one more thing which happened during my the 2025-0204 update, I noticed that an error was generated (no idea if this is related to the grub issue at all)
[2025-02-06T13:51:18-0600] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2025-02-06T13:52:48-0600] [ALPM-SCRIPTLET] Job for user@1000.service failed because the control process exited with error code.
[2025-02-06T13:52:48-0600] [ALPM-SCRIPTLET] See "systemctl status user@1000.service" and "journalctl -xeu user@1000.service" for details.
I executed the suggested journalctl command and got this;
Feb 06 13:56:17 Orangekarat gvfsd-trash[2375]: GFileInfo created without standard::name
Feb 06 13:56:17 Orangekarat gvfsd-trash[2375]: file ../glib/gio/gfileinfo.c: line 1698 (g_file_info_get_name): should not be reached
I’d like to to the latest update to 2025-02-16, but I’m kind paranoid given these errors.
Bear in mind that the latest update might actually fix the issue?
You could always change the timer in /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=1f0a6d4b-4dcd-491e-8a2b-b1769e2dc706"
GRUB_CMDLINE_LINUX=""
or un-comment the two entries:
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
There was this other thread that is essentially the same.
As mentioned here already that the menu is forced because of the extra entries …
This other thread found the reason for them
I have never restored a snapshot before, but I tried that solution anyway and it did not work.
Did you find a solution for GRUB?
It looks like no solution has been found for many days.
I had switched from GRUB to Limine to get better BTRFS support with LUKS2 and to fix all GRUB related issues. So far I have no problems.
Manjaro forces you to use LUKS1 because of GRUB.
Recently, I figured out that I wasn’t running on the latest 6.12 LTS kernel. I usually have the latest two LTS kernals available. I had 6.1 and 6.6 installed. I added the 6.12 LTS kernal and rebooted. Same issue with the grub menu appearing with the additional entries.
BUT then I removed the 6.1 LTS kernal (leaving me with 6.12 LTS and 6.6 LTS). I rebooted again. No grub menu appeared! I rebooted once more and escaped to the grub menu and, lo, the additional entries were gone and all is as it was before.
It seems that the removel of the 6.1 LTS kernal somehow fixed this problem. Would love to know what happened!
