Hi,
i need a driver for my Dell 1320c printer. The Xerox C525A driver works for me under ubuntu. With manjaro, the AUR (AUR (en) - xerox-c525a) does not work.
I’ve tried to manually download the rpm from the Xerox website (called Fuji_Xerox-DocuPrint_C525_A_AP-1.0-1.i386.rpm). Then i modified the PKGBUILD from AUR (en) - xerox-c525a
# Maintainer: Martin Müllenhaupt <mm+aur@netlair.de>
pkgname="xerox-c525a"
pkgver="1.0"
pkgrel="1"
pkgdesc="CUPS driver for the Fuji Xerox DocuPrint C525 A and Dell 1320C printer"
url="http://onlinesupport.fujixerox.com"
license=('custom')
arch=('i686' 'x86_64')
depends_x86_64=('lib32-libcups')
makedepends=('rpmextract')
sha256sums=('4bd7ac464527336c4feb9a1fbbd798e532fb87a6eb1e0e25717cce1909721d51')
#source=(
# http://www.fujixeroxprinters.com/downloads/uploaded/dpc525a_linux_.0.0.tar_81c2.zip
package() {
rpm2cpio "./Fuji_Xerox-DocuPrint_C525_A_AP-1.0-1.i386.rpm" | bsdtar -vxf - -C ${pkgdir}
Then i ran makepkg -si
[marvin@t5600 xerox-c525a]$ makepkg -si
==> Making package: xerox-c525a 1.0-1 (Mi 30 Sep 2020 23:38:41 CEST)
==> Installing missing dependencies...
resolving dependencies...
warning: dependency cycle detected:
warning: lib32-keyutils will be installed before its lib32-krb5 dependency
Packages (14) lib32-e2fsprogs-1.45.6-1 lib32-gmp-6.2.0-1 lib32-gnutls-3.6.15-1 lib32-keyutils-1.6.3-1 lib32-krb5-1.18.2-1 lib32-libidn2-2.3.0-1 lib32-libjpeg-turbo-2.0.5-1 lib32-libldap-2.4.50-1 lib32-libpng-1.6.37-3
lib32-libtiff-4.1.0-1 lib32-libunistring-0.9.10-1 lib32-nettle-3.6-1 lib32-openssl-1:1.1.1.g-1 lib32-libcups-2.3.3-1
Total Download Size: 5,14 MiB
Total Installed Size: 15,21 MiB
:: Retrieving packages...
lib32-e2fsprogs-1.45.6-1-x86_64 224,3 KiB 543 KiB/s 00:00 [######################################################################################] 100%
lib32-openssl-1:1.1.1.g-1-x86_64 1367,4 KiB 1640 KiB/s 00:01 [######################################################################################] 100%
lib32-libldap-2.4.50-1-x86_64 194,5 KiB 1118 KiB/s 00:00 [######################################################################################] 100%
lib32-keyutils-1.6.3-1-x86_64 8,7 KiB 0,00 B/s 00:00 [######################################################################################] 100%
lib32-krb5-1.18.2-1-x86_64 897,5 KiB 925 KiB/s 00:01 [######################################################################################] 100%
lib32-libjpeg-turbo-2.0.5-1-x86_64 257,9 KiB 921 KiB/s 00:00 [######################################################################################] 100%
lib32-libtiff-4.1.0-1-x86_64 178,7 KiB 638 KiB/s 00:00 [######################################################################################] 100%
lib32-libpng-1.6.37-3-x86_64 129,7 KiB 480 KiB/s 00:00 [######################################################################################] 100%
lib32-gmp-6.2.0-1-x86_64 283,7 KiB 414 KiB/s 00:01 [######################################################################################] 100%
lib32-nettle-3.6-1-x86_64 304,1 KiB 441 KiB/s 00:01 [######################################################################################] 100%
lib32-libunistring-0.9.10-1-x86_64 365,7 KiB 337 KiB/s 00:01 [######################################################################################] 100%
lib32-libidn2-2.3.0-1-x86_64 58,7 KiB 441 KiB/s 00:00 [######################################################################################] 100%
lib32-gnutls-3.6.15-1-x86_64 741,5 KiB 400 KiB/s 00:02 [######################################################################################] 100%
lib32-libcups-2.3.3-1-x86_64 246,0 KiB 451 KiB/s 00:01 [######################################################################################] 100%
(14/14) checking keys in keyring [######################################################################################] 100%
(14/14) checking package integrity [######################################################################################] 100%
(14/14) loading package files [######################################################################################] 100%
(14/14) checking for file conflicts [######################################################################################] 100%
(14/14) checking available disk space [######################################################################################] 100%
( 1/14) installing lib32-e2fsprogs [######################################################################################] 100%
( 2/14) installing lib32-openssl [######################################################################################] 100%
Optional dependencies for lib32-openssl
ca-certificates [installed]
( 3/14) installing lib32-libldap [######################################################################################] 100%
( 4/14) installing lib32-keyutils [######################################################################################] 100%
( 5/14) installing lib32-krb5 [######################################################################################] 100%
( 6/14) installing lib32-libjpeg-turbo [######################################################################################] 100%
( 7/14) installing lib32-libtiff [######################################################################################] 100%
( 8/14) installing lib32-libpng [######################################################################################] 100%
( 9/14) installing lib32-gmp [######################################################################################] 100%
(10/14) installing lib32-nettle [######################################################################################] 100%
(11/14) installing lib32-libunistring [######################################################################################] 100%
(12/14) installing lib32-libidn2 [######################################################################################] 100%
(13/14) installing lib32-gnutls [######################################################################################] 100%
(14/14) installing lib32-libcups [######################################################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
Packages (1) rpmextract-1.0-9
Total Download Size: 0,00 MiB
Total Installed Size: 0,00 MiB
rpmextract-1.0-9-any 2,4 KiB 0,00 B/s 00:00 [######################################################################################] 100%
(1/1) checking keys in keyring [######################################################################################] 100%
(1/1) checking package integrity [######################################################################################] 100%
(1/1) loading package files [######################################################################################] 100%
(1/1) checking for file conflicts [######################################################################################] 100%
(1/1) checking available disk space [######################################################################################] 100%
(1/1) installing rpmextract [######################################################################################] 100%
==> Retrieving sources...
==> Extracting sources...
==> Entering fakeroot environment...
==> Starting package()...
no package supplied
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "xerox-c525a"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: xerox-c525a 1.0-1 (Mi 30 Sep 2020 23:39:05 CEST)
==> Installing package xerox-c525a with pacman -U...
loading packages...
Packages (1) xerox-c525a-1.0-1
(1/1) installing xerox-c525a
But when i checked
[marvin@t5600 Downloads]$ sudo pacman -Q xerox-c525a
xerox-c525a 1.0-1
[marvin@t5600 Downloads]$ sudo pacman -Ql xerox-c525a
it seems like nothing was actually installed.
Can you tell me, what went wrong?
