Muppi
30 October 2022 16:23
1
Hi. I am trying to install a wifi driver for my RTL 8111/8168/8411 PCI ExpressGigabit Ethernet controller. Which driver should I install? Manjaro Setting Manager says that the driver is not installed.
EDIT 1
$ inxi -Fazy
Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cf7638e3-8ab3-4540-b82f-953925460698 rw quiet apparmor=1
Desktop: i3 v: 4.21 info: i3bar vt: 1 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 5603
date: 10/14/2020
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1458 high: 1755 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1231 2: 1755
3: 1602 4: 1246 bogomips: 28759
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 47.0 C
Display: server: X.Org v: 21.1.4 compositor: Picom v: git-7e568 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: CP-UEM-22AH serial: <filter>
built: 2022 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.72-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK PRIME
B450M-A driver: snd_hda_intel bus-ID: 1-8:3 v: kernel chip-ID: 08bb:2902
pcie: class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8179 class-ID: 0280
vendor: ASUSTeK PRIME B450M-A driver: N/A modules: r8169, r8168 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
Local Storage: total: 953.87 GiB used: 241.11 GiB (25.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: 1TB EVM SSD
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 8B0 scheme: MBR
ID-1: / raw-size: 953.86 GiB size: 937.82 GiB (98.32%) used: 120.55 GiB
(12.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 47.2 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 234 Uptime: 1h 32m wakeups: 0 Memory: 5.72 GiB used: 2.22 GiB
(38.8%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1368 pm: pacman pkgs: 1365
libs: 393 tools: pamac,yay pm: flatpak pkgs: 3 Shell: Zsh v: 5.9
running-in: kitty inxi: 3.3.22
Do you have a problem with it?
However, the device you mention is not a WiFi device but ethernet.
Please provide the properly formatted output of inxi -Fazy
Muppi
30 October 2022 16:41
3
Thanks for the quick response
$ inxi -Fazy
date: 10/14/2020
desc: 1x4 MiB
prctl and seccomp
class-ID: 0200
Seems like everything is well. What is your issue?
This one is up:
And you ethernet is down:
I see you install additionally r8168
While r8169
is included in the kernel and should work.
You get 0.375 MB/s ? Really?
Just a guess but:
Iphone → 35 Mbps → 4.375 MB/s
Manjaro → 3 MB/s → 24 Mbps
So ~54Mbps in total if both run with 802.11g on the same network.
Muppi
31 October 2022 11:34
7
Should I enable my ethernet?
How do I uninstall r8169?
Yesterday I was getting 3 MB/s but now I am getting 84 Mb/s/ And similar reading on my IPhone. Any reason why this is happening. I had restarted my computer multiple times yesterday.
Upps other way around… it is r8168 and r8169 is included in the kernel
Normally with Manjaro Settings (GUI) or mhwd:
sudo mhwd --remove pci network-r8168
And reboot or just load the driver:
# Unload the driver
sudo modprobe -rv r8168
# Load the driver
sudo modprobe -v r8169
Check if it is in use:
inxi -Nazy
Bad signal? Too many interferences?
It’s still not clear if you’re using a cable connection or wifi.
Agree with @mithrial :
The OP is trying to install a wifi driver for an ethernet controller… weird. Does he know the difference between lan and wireless lan?
Anyway… wifi is working
Muppi
31 October 2022 12:27
12
Do I need a seperate driver for my wifi card?
Muppi
31 October 2022 16:12
14
So everything is fine? If yes, then why is my WiFi unstable?
Only thing what could make it “unstable” is the power saving mode of the card what can be disabled. Other than that it is the router.
Maybe try this:
sudo systemctl stop NetworkManager
sudo modprobe -rv rtl8188ee
sudo modprobe -v rtl8188ee fwlps=0 aspm=0 swenc=1
sudo systemctl start NetworkManager && journalctl --boot 0 --unit NetworkManager --follow
That is only temporary and not permanent.
Muppi
1 November 2022 02:40
16
Thanks! That works. Any way that I can always run this on startup? or maybe in my xinitrc.
echo "options rtl8188ee fwlps=0 aspm=0 swenc=1" | sudo tee /etc/modprobe.d/rtl8188ee.conf
That creates a config file which will load the driver with that specific options on startup.
system
Closed
3 November 2022 18:31
19
