I’m trying to get bochs running with the gdb stub feature installed, so that I can debug a kernel I’m writing from gdb. First, I tried the bochs-gdb package on the AUR, but that complained that error: Linux kernel 2.4, 2.6 or 3.x is required for PCI host device mapping. So then, I tried downloading the bochs source and configuring the makefile with:
./configure --enable-gdb-stub --enable-pci --enable-cpu-level=6
But after doing that and then building bochs, I get the error:
Event type: PANIC
Device: [XGUI ]
Message: Unknown x11 option 'gui_debug'
So, how can I get this working? On the Bochs website it says to do pretty much just what I did, and that’s not working.
bochs-gdbAUR 2.6.8 was released in 2015. The current version is 2.6.11 released last week.
I just submitted a request to orphan the package and it was auto-accepted, feel free to adopt it and update it.
Thanks for the suggestion, I tried something similar to this earlier but it led to the same
Unkown x11 option `gui_debug`
error that I described in my question.
Okay, so I’ve solved it, and feel like a bit of an idiot, but I’m posting the solution here in case someone else misses it as I did. When bochs said
Event type: PANIC
Device: [XGUI ]
A PANIC has occurred. Do you want to:
cont - continue execution
alwayscont - continue execution, and don't ask again.
This affects only PANIC events from device [XGUI ]
die - stop execution now
abort - dump core
debug - hand control to gdb
Choose one of the actions above: [die] cont
I took that to mean it crashed. But, it hadn’t crashed. If I simply type cont, it progresses and allows me to connect to it in gdb.
Updating the package sounds fun, I’ll look into that
