Hello, I have installed Manjaro on my brand new laptop, and I removed Windows as well. I am having trouble getting Manjaro working, so at the very least I need to reinstall Windows in order to do work. I have tried several methods for burning the Windows .iso file to a USB drive, but none of them have worked. I have checked the integrity of the .iso file and it checks out. I have to attend a webinar tomorrow and I would prefer to have Windows running by then.
This is where I got the iso file from:
https://www.microsoft.com/en-us/software-download/windows10ISO
These are the 3 methods I tried:
https://archived.forum.manjaro.org/t/howto-use-manjaro-to-create-a-bootable-windows-usb/92780
My inxi -Fza:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=8689b73c-bb2c-456d-9d95-0e8af9f323c4 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Laptop 15-eh0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87C5 v: 35.23 serial: <filter> UEFI: AMI v: F.03
date: 08/10/2020
ID-1: BAT0 charge: 40.6 Wh condition: 40.6/40.6 Wh (100%) volts: 12.9/11.3
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
cycles: 365
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 4 MiB
bogomips: 31958
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:1636 class ID: 0300
Device-2: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB
driver: uvcvideo bus ID: 1-3:2 chip ID: 30c9:000e class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.1 chip ID: 1002:1637 class ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x bus ID: 04:00.5 chip ID: 1022:15e2 class ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 02:00.0
chip ID: 8086:2723 class ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus ID: 1-4:3 chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 505.84 GiB used: 29.45 GiB (5.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: HPS0
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Memorex
model: USB Flash Drive size: 28.9 GiB block size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 25.45 GiB (5.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 58.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 254 Uptime: 29m wakeups: 917 Memory: 15.07 GiB
used: 2.03 GiB (13.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1142 lib: 371 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01```
