jne14
25 July 2022 00:56
1
I have trouble setting up vulkan. I get the following error:
vulkaninfo --summary INT ✘ ghc-8.10.7
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Could not get 'vkCreateInstance' via 'vk_icdGetInstanceProcAddr' for ICD libGLX_nvidia.so.0
ERROR: [Loader Message] Code 0 : vkCreateInstance: Found no drivers!
Cannot create Vulkan instance.
This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.
ERROR at /build/vulkan-tools/src/Vulkan-Tools-1.3.217/vulkaninfo/vulkaninfo.h:665:vkCreateInstance failed with ERROR_INCOMPATIBLE_DRIVER
I know I have to google the answer to dead but nothing fits my needs.
Zesko
25 July 2022 09:05
2
jne14:
If you are using NVIDIA GTX-1080 in your profile,
it seems Nvidia driver is not compatible with Vulkan.
Maybe downgrade is a solution. (I am not Nvidia user and can not help)
can you return
inxi -Fza
sudo mhwd -li
sudo kernel -li
jne14
26 July 2022 00:53
6
inxi -Fza
Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-rt-x86_64
root=UUID=9a1cbd41-4023-4bf8-9460-34ad31943232 rw quiet splash apparmor=1
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: 1: GDM
v: 42.0 2: LightDM v: 1.30.0 note: stopped Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Micro-Star product: GE62 7RD v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.325 date: 08/29/2018
ID-1: BAT1 charge: 30.0 Wh (70.4%) condition: 42.6/53.4 Wh (79.8%)
volts: 11.8 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3511 high: 3784 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 3539 2: 3784 3: 3404
4: 3580 5: 3438 6: 3434 7: 3447 8: 3463 bogomips: 44798
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI
driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-11:4
chip-ID: 5986:0683 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: vesa alternate: fbdev,nouveau,nv gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d6 built: 2015 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:24fb class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 9 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 340.67 GiB (29.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN256HMHQ-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 100Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi)
model: HTS721010A9E630 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: A3U0 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 80.81 GiB (34.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 43.0 C pch: 44.5 C mobo: N/A
Processes: 429 Uptime: 1d 20h 15m wakeups: 9 Memory: 15.55 GiB
used: 4.14 GiB (26.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1931
pacman: 1918 lib: 490 flatpak: 0 snap: 13 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.19
sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
mhwd-kernel -li
Currently running: 5.18.0-1-rt11-MANJARO (linux518)
* linux513
* linux515-rt
* linux518-rt
can you remove these kernel version is EOL
sudo mhwd-kernel -r linux513
you can add version kernel LTS ( 5.10 , 5.15 )
sudo mhwd-kernel -i linux510
why are you using kernel-rt version ?
jne14
26 July 2022 10:37
8
When I installed manjaro it picked the rt version my computer. I don’t know why it installed it
