I’m using a ASUS notebook (MD570D). Only hadrware change is the SDD, which I replaced for a M.2 type. Was working like a charm, but now some configurations of the system don’t load properly at startup. Sometimes I get a desktop with no icons, just some windows opened and no controls over the windows. It usually solves when I reboot, but it doesn’t suck any less because of it. I was kind of trying to figure out a way of repairing it. Any way, here some data that mey help. Any additional info needed, please do not exitate to hesitate to ask!
==== Commands and provided data =====
inxi -Fxza --no-host
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5. 8-x86_64 root=UUID=815e8a9e-a662-446b-8343-b256e9b35c11 rw quiet apparmor=1
security=apparmor resume=UUID=2e2ac8ff-456b-448c-8c20-539f8a556c59 udev. log_priority=3
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570DD_X570DD v: 1.0 serial: <filter
Mobo: ASUSTeK model: X570DD v: 1.0 serial: <filterUEFI: American Megatrends v: X570DD.302 date: 10/24/2019
Battery: ID-1: BAT0 charge: 43.4 Wh condition: 43.4/48.1 Wh (90%) volts: 11.7/11.7 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: Not charging cycles: 23
CPU: Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33550
Speed: 2613 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1465 2: 1480 3: 1394 4: 1274 5: 1271
6: 1324 7: 1325 8: 1279
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK driver: nvidia v: 450.80.02
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c92
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:15d8
Device-3: IMC Networks USB2.0 Hub type: USB driver: uvcvideo bus ID: 3-2.2:4 chip ID: 13d3:5a05 serial: <filter
Display: x11 server: X. Org 1.20.9 compositor: kwin_x11 driver: amdgpu,nvidia FAILED: ati
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2") s-diag: 581mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.18-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.2.1 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f000 bus ID: 02:00.0 chip ID: 8086:24fd
IF: wlp2s0 state: up mac: <filter
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter
IF-ID-1: br-fd990bdcb3c7 state: up speed: 10000 Mbps duplex: unknown mac: <filter
IF-ID-2: docker0 state: down mac: <filter
IF-ID-3: veth48c90b7 state: up speed: 10000 Mbps duplex: full mac: <filter
IF-ID-4: veth60477e8 state: up speed: 10000 Mbps duplex: full mac: <filter
IF-ID-5: vethaaa7612 state: up speed: 10000 Mbps duplex: full mac: <filter
Drives: Local Storage: total: 1.38 TiB used: 118.59 GiB (8.4%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8100NP size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filterrev: VB411D48 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-80Z10T2 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filterrev: 1A04 scheme: MBR
Partition: ID-1: / raw size: 50.28 GiB size: 49.24 GiB (97.93%) used: 27.25 GiB (55.3%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /home raw size: 214.60 GiB size: 210.23 GiB (97.96%) used: 42.60 GiB (20.3%) fs: ext4 dev: /dev/nvme0n1p5
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 15.62 GiB used: 167.1 MiB (1.0%) priority: -2 dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 68.0 C mobo: N/A gpu: amdgpu temp: 68.0 C
Fan Speeds (RPM): cpu: 3400
Info: Processes: 366 Uptime: 9h 44m Memory: 13.68 GiB used: 9.93 GiB (72.6%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1342 lib: 370 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.08
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-450xx-prime 2020.10.04 false PCI
