Hello, I recently moved to manjaro and was having some issues with a TP Link t2u v3 with a RTL8811au chipset. So i bought a TP Link Tx55e pci-e wireless card with bluetooth capabilities and at first everything was working smoothly but after my sister used the wi fi to have a videocall everything started to go bad. I’m now having connectivity issues for around 5 minutes, I tried switching from 5GHz to 2.4GHz back and forth and sometimes this fixes the issue, but other times it does not.
Can someone help me or has had something similar?
I’m using kernel 6.8.9-3-MANJARO
This is what sudo dmesg | grep iwlwifi says:
[ 11.603172] Intel(R) Wireless WiFi driver for Linux
[ 11.603225] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 11.613573] iwlwifi 0000:04:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 11.613580] iwlwifi 0000:04:00.0: PCI dev 2725/0020, rev=0x420, rfid=0x10d000
[ 11.624488] iwlwifi 0000:04:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
[ 11.624832] iwlwifi 0000:04:00.0: loaded firmware version 86.fb5c9aeb.0 ty-a0-gf-a0-86.ucode op_mode iwlmvm
[ 12.155670] iwlwifi 0000:04:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 12.162638] iwlwifi 0000:04:00.0: WRT: Invalid buffer destination
[ 12.314311] iwlwifi 0000:04:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 12.314328] iwlwifi 0000:04:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 12.314338] iwlwifi 0000:04:00.0: WFPM_AUTH_KEY_0: 0x90
[ 12.314348] iwlwifi 0000:04:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 12.314772] iwlwifi 0000:04:00.0: loaded PNVM version e28bb9d7
[ 12.331116] iwlwifi 0000:04:00.0: Detected RF GF, rfid=0x10d000
[ 12.399609] iwlwifi 0000:04:00.0: base HW address: f0:b6:1e:93:45:40
[ 12.415263] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[ 13.284954] iwlwifi 0000:04:00.0: WRT: Invalid buffer destination
[ 13.437373] iwlwifi 0000:04:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 13.437399] iwlwifi 0000:04:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 13.437415] iwlwifi 0000:04:00.0: WFPM_AUTH_KEY_0: 0x90
[ 13.437433] iwlwifi 0000:04:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 13.531123] iwlwifi 0000:04:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 13.584138] iwlwifi 0000:04:00.0: WRT: Invalid buffer destination
[ 13.736802] iwlwifi 0000:04:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 13.736824] iwlwifi 0000:04:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 13.736840] iwlwifi 0000:04:00.0: WFPM_AUTH_KEY_0: 0x90
[ 13.736856] iwlwifi 0000:04:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Feel free to ask me anything, I will do my best to provide the data
This si inxi -Fxxxz
Kernel: 6.8.9-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B365M DS3H v: x.x
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: F5 date: 08/13/2019
Thank you for your help
