Hi all, I’m having some issues with OBS Studio and I don’t know if it’s an OBS problem or a Manjaro problem.
Fair warning; I’m reasonably novice when it comes to the command line.
Trying to run OBS from the CL yields this:
~ obs studio
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale ‘en-GB’
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
warning: [Safe Mode] Unclean shutdown detected!
info: [Safe Mode] User has launched in Safe Mode.
info: Command Line Arguments: studio
info: Using EGL/X11
info: CPU Name: AMD Ryzen 7 2700X Eight-Core Processor
info: CPU Speed: 2724.283MHz
info: Physical Cores: 8, Logical Cores: 16
info: Physical Memory: 32044MB Total, 25134MB Free
info: Kernel Version: Linux 6.1.62-1-MANJARO
info: Distribution: “Manjaro Linux” Unknown
info: Desktop Environment: KDE (KDE)
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.6.0 (runtime), 6.6.0 (compiled)
info: Portable mode: false
warning: Safe Mode enabled.
info: OBS 30.0.0-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL…
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 3070/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 535.129.03, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load ‘en-US’ text for module: ‘decklink-captions.so’
warning: Failed to load ‘en-US’ text for module: ‘decklink-output-ui.so’
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module ‘decklink.so’
warning: Skipping module ‘frontend-tools’, not on safe list
info: [pipewire] Available captures:
info: [pipewire] - Desktop capture
info: [pipewire] - Window capture
warning: v4l2loopback not installed, virtual camera disabled
info: NVENC supported
zsh: segmentation fault (core dumped) obs studio
Is anyone able to decipher this gobbledegook for me, please?
Thanks in advance.
