Is it possible to get hardware acceleration on firefox or chrome with a nvidia gpu and nvidia proprietary drivers? I can not enable va-api.
Yes it is. You need to have nvidia-utils package according to the arch wiki. What is the output of vainfo and vdpauinfo?
yes I have nvidia-utils. vainfo returns error -1.
vdpauinfo 127 ✘ 24s
display: :1 screen: 0
API version: 1
Information string: NVIDIA VDPAU Driver Shared Library 495.46 Wed Oct 27 16:20:01 UTC 2021
Video surface:
name width height types
420 8192 8192 NV12 YV12
422 8192 8192 UYVY YUYV
444 8192 8192 NV24 YV24
420_16 8192 8192 P010 P016
422_16 8192 8192 UYVY YUYV
444_16 8192 8192 Y_U_V_444_16
Decoder capabilities:
name level macbs width height
MPEG1 0 65536 4096 4096
MPEG2_SIMPLE 3 65536 4096 4096
MPEG2_MAIN 3 65536 4096 4096
H264_BASELINE 51 65536 4096 4096
H264_MAIN 51 65536 4096 4096
H264_HIGH 51 65536 4096 4096
VC1_SIMPLE 1 8190 2048 2048
VC1_MAIN 2 8190 2048 2048
VC1_ADVANCED 4 8190 2048 2048
MPEG4_PART2_SP 3 8192 2048 2048
MPEG4_PART2_ASP 5 8192 2048 2048
DIVX4_QMOBILE 0 8192 2048 2048
DIVX4_MOBILE 0 8192 2048 2048
DIVX4_HOME_THEATER 0 8192 2048 2048
DIVX4_HD_1080P 0 8192 2048 2048
DIVX5_QMOBILE 0 8192 2048 2048
DIVX5_MOBILE 0 8192 2048 2048
DIVX5_HOME_THEATER 0 8192 2048 2048
DIVX5_HD_1080P 0 8192 2048 2048
H264_CONSTRAINED_BASELINE 51 65536 4096 4096
H264_EXTENDED 51 65536 4096 4096
H264_PROGRESSIVE_HIGH 51 65536 4096 4096
H264_CONSTRAINED_HIGH 51 65536 4096 4096
H264_HIGH_444_PREDICTIVE 51 65536 4096 4096
VP9_PROFILE_0 1 262144 8192 8192
VP9_PROFILE_1 --- not supported ---
VP9_PROFILE_2 1 262144 8192 8192
VP9_PROFILE_3 --- not supported ---
HEVC_MAIN 153 262144 8192 8192
HEVC_MAIN_10 153 262144 8192 8192
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 153 262144 8192 8192
HEVC_MAIN_444 --- not supported ---
HEVC_MAIN_444_10 --- not supported ---
HEVC_MAIN_444_12 --- not supported ---
Output surface:
name width height nat types
B8G8R8A8 32768 32768 y Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
R10G10B10A2 32768 32768 y Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
Bitmap surface:
name width height
R8G8B8A8 32768 32768
B10G10R10A2 32768 32768
A8 32768 32768
Video mixer:
feature name sup
DEINTERLACE_TEMPORAL y
DEINTERLACE_TEMPORAL_SPATIAL y
INVERSE_TELECINE y
NOISE_REDUCTION y
SHARPNESS y
LUMA_KEY y
HIGH QUALITY SCALING - L1 y
HIGH QUALITY SCALING - L2 -
HIGH QUALITY SCALING - L3 -
HIGH QUALITY SCALING - L4 -
HIGH QUALITY SCALING - L5 -
HIGH QUALITY SCALING - L6 -
HIGH QUALITY SCALING - L7 -
HIGH QUALITY SCALING - L8 -
HIGH QUALITY SCALING - L9 -
parameter name sup min max
VIDEO_SURFACE_WIDTH y 1 8192
VIDEO_SURFACE_HEIGHT y 1 8192
CHROMA_TYPE y
LAYERS y 0 4
attribute name sup min max
BACKGROUND_COLOR y
CSC_MATRIX y
NOISE_REDUCTION_LEVEL y 0.00 1.00
SHARPNESS_LEVEL y -1.00 1.00
LUMA_KEY_MIN_LUMA y
LUMA_KEY_MAX_LUMA y
Run these commands and share full output:
export VDPAU_DRIVER=nvidia
vainfo
export VDPAU_DRIVER=nvidia ✔
~ vainfo ✔
vaInitialize failed with error code -1 (unknown libva error),exit
export LIBVA_DRIVER_NAME=vdpau
vainfo
See this if it doesn’t work:
https://wiki.archlinux.org/title/Hardware_video_acceleration#Configuring_VA-API
same error
i have tried LIBVA_DRIVER_NAME=vdpau in /etc/environment & tried LIBVA_DRIVERS_PATH=/usr/lib/dri/nouveau_dri.so
not working
@Mirdarthos any idea?
None, whatsoever.
Edit:
It seems vainfo is part of the libva-utils package:
$ vainfo
zsh: correct 'vainfo' to 'aainfo' [nyae]? n
find-the-command: "vainfo" is not found locally, searching in repositories...
"vainfo" may be found in package "community/libva-utils"
What would you like to do?
1) install 2) info 3) list files 4) list files (paged)
Action (0 to abort): 0
So check that it’s installed:
$ pamac search libva-utils
libva-utils 2.13.0-1 community
Intel VA-API Media Applications and Scripts for libva
And if not, install it with:
pamac install libva-utils
And see if that helps. I honestly don’t know.
I’m out of my dept and guessing at this point.
Yes I already have that installed.
What report the settings of Firefox itself ?
Compositing is set to WebRender. Now I have to enable va-api
what is the output of inxi -G?
Do you use X11 or Wayland ?
inxi -G ✔
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 495.46
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
Display: x11 server: X.org 1.21.1.3 driver: loaded: nvidia
Using x11
First of all: Firefox doesn’t support VAAPI-VDPAU driver as this one is really old and doesn’t support technologies requested by FF.
There’s new driver that’s written for Firefox and maps VAAPI to NVDEC.
Just install AUR (en) - nvidia-vaapi-driver-git and set all things that are listed on GitHub page. Only 470 series drivers and above are supported.
It says, “It’s currently in early development, so don’t expect it to work well”. So I will use this later.
Is this also the case with Google Chrome regarding hardware acceleration?
Well you don’t have any alternatives for Firefox atm, only software or this. I’m using it fine for two weeks already without any major problems.
I don’t know much about how Chrome does this but I think for Chrome you should stick to VDPAU driver, this one doesn’t support it though the author is considering adding it’s support in future.
Wow… I’ll give it a try then
