Hardware problems
“At the moment there are acute problems with the connection to scanline…or to the scanner. It doesn’t matter which scan program is used. However, my printer is connected and works perfectly when printing.”
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
  • Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
If you encounter any error messages, please provide us with the full message output.
