I have Manjaro 21.26 xfce installed on my home pc. All off a sudden on boot I get error messages like these: *dependency failed for /UMV" and “dependency failed for local file systems”. I’m guessing hard drive failure. I’ve got 2 SSD’s installed and one 2TB sata HHD.
Any suggestions on how to find the problem drive? I have timeshift iinstalled but can’t get to it.
If you cant boot into the system boot into any Manjaro install media. Trying to mount the problem drive in a file manager should give an error, if it shows up at all.
You should also be able to edit the /etc/fstab file to remove the bad drive, if it isnt the system drive.
