inxi --full --admin --filter --width ✔
Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=9f38c2ae-21ca-4215-822a-0e478276b220 ro quiet splash apparmor=1
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5013 date: 03/22/2024
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2535 high: 3599 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3400 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3598 10: 3599 11: 2879
12: 3597 13: 2200 14: 2200 15: 2200 16: 2200 17: 3596 18: 2200 19: 2876
20: 2929 21: 2200 22: 2875 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200
28: 2200 29: 2200 30: 2200 31: 2200 32: 3400 bogomips: 217721
affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Sceptre Y27 serial: <filter>
built: 2020 res: 2560x1440 hz: 165 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
navi21 LLVM 18.1.8 DRM 3.54 6.6.44-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 24.1.5-manjaro1.1
device-ID: 1002:73bf surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Best Buy INSIGNIA NS-CBM19
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 2034:0105 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 4.09 TiB used: 1.18 TiB (28.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.2 temp: 45.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00GGJB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 460.27 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 369.02 GiB (77.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 99.2 MiB (99.21%)
used: 31.9 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 51.9 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 4.51 GiB (14.4%)
Processes: 624 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 2009 pm: pacman pkgs: 1990 libs: 568 tools: gnome-software,pamac
pm: appimage pkgs: 0 pm: flatpak pkgs: 0 pm: snap pkgs: 19 Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.35
uname -r ✔
6.6.44-1-MANJARO
Hello, I am having trouble with random restarts while doing development in unity. I would also have brave, discord, blender, etc open. Sometimes just unity and brave. The system restarts and presents me with a hardware error message. The two screenshots I have are two separate instances. I believe I installed the cpu whilst running the 5.9 kernel. I’ve used 5.10, 5.14, 5.15, 6.1, and 6.6 since. They all have the same issue. The only work arounds are to:
- Go into my ASUS TUF Gaming WiFi X570 BIOS and switch from Normal to ASUS Optimal in easy mode, (Or Manually set core ratio to 40, same effect)
- OR Use a custom High-Performance profile I made in corectl (nevermind, this had no effect)
I want to get the full speed out of my cpu as all 32 threads do in fact get used when compiling and rendering (I don’t have cycles GPU support yet).
so I tried adding processor.max_cstate=5 amd_iommu=on rcu_nocbs=0_11 to my Kernel parameters as suggested. I just pressed ‘e’ in the grub menu and added it to the bottom. This did not help, I just had another crash after doing that yesterday. It’s been years since I’ve used windows on my main machine, and I don’t want to switch now, or use Ubuntu(gross)… What do I do?
Thanks in advance. ![]()
Edit2: I’m going to try to do this manually in /etc/default/grub, the correct way. I don’t know what I was thinking by doing it in the grub menu. Been a few years since I’ve added params. grub file at bottom.
Edit: I forgot the images ![]()
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 processor.max_cstate=5 amd_iommu=on rcu_nocbs=0_11"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically
GRUB_ROOT_FS_RO=true
GRUB_DISABLE_OS_PROBER=false
