I recently lucked out on a hardware purchase. The earbugs I bought don’t really work with Linux/Manjaro. While I’m out on the market for new ones, the question I have here is somewhat different: where do you recommend checking before buying hardware? (in this case searching for device_name+linux didn’t return anything) For example I usually look at winehq or protondb before buying a game to get a sense of how compatible it is with Linux. Any similar resources you can recommend for hardware?
Hardware tend to be compatible with Linux when they follow public standards rather than trying to make their own.
Personally, if i need a special application in order to use the full potential of a new hardware, that’s usually a no-no… unless said application (or good enough equivalent) is available for Linux. It’s thanks to such availability that i can still enjoy a Roccat Kone XTD gaming mouse for instance.
