Hello
I’ve been trying to get HW acceleration to work on an AMD Ryzen 5700G. I’m using the open source drivers, which i also reinstalled, along with the VDPAU and VAAPI packages. Firefox, VLC and Handbrake all can’t use hardware acceleration. Is it normal for this iGPU not to support so many codecs?
vdpauinfo output:
display: :0.0 screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name width height types
420 16384 16384 NV12 YV12
422 16384 16384 UYVY YUYV
444 16384 16384 Y8U8V8A8 V8U8Y8A8
420_16 16384 16384
422_16 16384 16384
444_16 16384 16384
Decoder capabilities:
name level macbs width height
MPEG1 --- not supported ---
MPEG2_SIMPLE 3 65536 4096 4096
MPEG2_MAIN 3 65536 4096 4096
H264_BASELINE --- not supported ---
H264_MAIN --- not supported ---
H264_HIGH --- not supported ---
VC1_SIMPLE --- not supported ---
VC1_MAIN --- not supported ---
VC1_ADVANCED --- not supported ---
MPEG4_PART2_SP 3 65536 4096 4096
MPEG4_PART2_ASP 5 65536 4096 4096
DIVX4_QMOBILE --- not supported ---
DIVX4_MOBILE --- not supported ---
DIVX4_HOME_THEATER --- not supported ---
DIVX4_HD_1080P --- not supported ---
DIVX5_QMOBILE --- not supported ---
DIVX5_MOBILE --- not supported ---
DIVX5_HOME_THEATER --- not supported ---
DIVX5_HD_1080P --- not supported ---
H264_CONSTRAINED_BASELINE --- not supported ---
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
VP9_PROFILE_0 --- not supported ---
VP9_PROFILE_1 --- not supported ---
VP9_PROFILE_2 --- not supported ---
VP9_PROFILE_3 --- not supported ---
HEVC_MAIN --- not supported ---
HEVC_MAIN_10 --- not supported ---
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported ---
HEVC_MAIN_444_10 --- not supported ---
HEVC_MAIN_444_12 --- not supported ---
AV1_MAIN --- not supported ---
AV1_HIGH --- not supported ---
AV1_PROFESSIONAL --- not supported ---
vainfo output:
Trying display: wayland
Trying display: x11
vainfo: VA-API version: 1.17 (libva 2.17.1)
vainfo: Driver version: Mesa Gallium driver 23.0.1 for AMD Radeon Graphics (renoir, LLVM 15.0.7, DRM 3.49, 6.2.8-1-MANJARO)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
inxi -G output:
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel
Display: x11 server: XOrg v: 21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 2560x1440~60Hz
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.2.8-1-MANJARO)
grep -iE ‘vdpau | dri driver’ Xorg.0.log output
[ 6.270] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 6.270] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
clinfo output
Number of platforms 0
Running 6.2.8-1-MANJARO
Any input is appreciated, thanks!
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
