I did not know what subforum to use for this topic but a quick search of partitioning made me believe this one would serve well. I am not having problems with installation, Manjaro is already installed on my hardware but a hard drive that is read only and had my old files is ready to be resized and wiped clean so I can use it for storage, but it will not let me unmount it and I tried to give myself permissions over it but that failed too.
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3f0aa64b-f46e-427e-b9d4-5979c9c803d8 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: BIOSTAR model: Hi-Fi A85W serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 04/18/2013
RAM: total: 15.59 GiB used: 2.85 GiB (18.3%)
Info: Quad Core model: AMD A10-5800K APU with Radeon HD Graphics bits: 64
type: MCP arch: Piledriver family: 15 (21) model-id: 10 (16) stepping: 1
microcode: 6001119 cache: L1: 320 KiB L2: 8 MiB bogomips: 30409
Speed: 2111 MHz min/max: 1400/3800 MHz boost: enabled Core speeds (MHz):
1: 1601 2: 1457 3: 1400 4: 1400
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt
xop xsave
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Turks XT [Radeon HD 6670/7670] vendor: ASUSTeK driver: radeon
v: kernel bus-ID: 01:00.0 chip-ID: 1002:6758 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x285mm (34.2x11.2")
s-diag: 915mm (36")
Monitor-1: HDMI-0 res: 1366x768 hz: 60 dpi: 60 size: 575x323mm (22.6x12.7")
diag: 660mm (26")
Monitor-2: DVI-0 res: 1920x1080 hz: 60 dpi: 103 size: 474x296mm (18.7x11.7")
diag: 559mm (22")
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.15.2-2-MANJARO LLVM 13.0.0)
v: 3.3 Mesa 21.2.5 compat-v: 3.1 direct render: Yes
Device-1: AMD FCH Azalia vendor: Biostar Microtech Intl Corp
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa90 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: NetGear Nighthawk A7000 802.11ac Wireless Adapter AC1900 [Realtek
8814AU]
type: USB driver: rtl8814au bus-ID: 6-2:2 chip-ID: 0846:9054 class-ID: 0000
serial: <filter>
IF: wlp0s16f0u2 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 3.09 TiB used: 103 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3400820AS
size: 372.61 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: D scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EARS-00Y5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 0A80 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000LM003 HN-M201RAD
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: <unknown>
type: HDD rpm: 5400 serial: <filter> rev: 0002 scheme: GPT
ID-1: / raw-size: 372.31 GiB size: 365.4 GiB (98.14%) used: 103 GiB (28.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3f0aa64b-f46e-427e-b9d4-5979c9c803d8
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F8DE-0045
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: btrfs label: G
uuid: 3d602246-8708-444c-8c97-01fdc68f004c
ID-2: /dev/sdc1 maj-min: 8:33 size: 500 MiB fs: vfat label: ESP
uuid: AECE-2B6C
ID-3: /dev/sdc2 maj-min: 8:34 size: 40 MiB fs: vfat label: DIAGS
uuid: A8EE-65FA
ID-4: /dev/sdc3 maj-min: 8:35 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdc4 maj-min: 8:36 size: 750 MiB fs: ntfs label: WINRETOOLS
uuid: 78A6F027A6EFE41A
ID-6: /dev/sdc5 maj-min: 8:37 size: 1.81 TiB fs: ntfs label: OS
uuid: 6E0AA18D0AA1533F
ID-7: /dev/sdc6 maj-min: 8:38 size: 6.71 GiB fs: ntfs label: PBR Image
uuid: 06B0E046B0E03E35
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-3: 3-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Device-1: 4-2:2 info: Corsair Gaming HARPOON RGB Mouse type: Mouse,HID
power: 300mA chip-ID: 1b1c:1b3c class-ID: 0300 serial: <filter>
Device-2: 4-4:3 info: Cypress type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 04b4:f02f
class-ID: 0300
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 6-2:2 info: NetGear Nighthawk A7000 802.11ac Wireless Adapter
AC1900 [Realtek 8814AU]
type: Network driver: rtl8814au interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0846:9054 class-ID: 0000 serial: <filter>
Hub-7: 7-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-8: 8-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 9-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 14.0 C mobo: N/A gpu: radeon temp: 36.0 C
Processes: 224 Uptime: 6h 31m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1289 lib: 357
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.09
KDE partition manager says this
The file system on partition ‘/dev/sda2’ could not be unmounted.
>Details
Command: umount --verbose --all-targets /dev/sda2
And when I tried to change permissions i was trying.
chown username:username /run/media/blah/blah
but it came back and said it was a read only file system which thats exactly what i was trying to change.
the above command worked on the first partition i tried it on but also the unmounting issue did not happen to the first one just the second one.
chown: changing ownership of '/run/media/bodom/OS': Read-only file system
My goal is two fold, resize and clear out that hard drive as its purpose of bringing over my old files is done. And give myself rw permission on the drive after I’m done.
I cant seem to get any closer to the answer at this point and would really appreciate one of you guys’ help.
Thank you for looking over this topic if you found it.
