yaolet
11 February 2022 06:12
1
Hi,
I’ve been using manjaro for a couple of years. Before I always install hardinfo utility on my system however after the latest keyring update, the package cannot be found:
sudo pacman -Sy
sudo pacman -S hardinfo
error: target not found: hardinfo
wondering if there was a renaming or the package has been removed ???
It is no longer available in arch community repositories. See https://archlinux.org/packages/community/x86_64/hardinfo/
You can install AUR (en) - hardinfo-git from AUR:
pamac build hardinfo-git
Or you can use the replacement hwinfo
system
Closed
14 February 2022 00:41
4
