I recently bought a new mainboard (ASRock B650E Taichi Lite) and CPU (amd ryzen 9 7950X3D) and since then I experience that my SATA drives are disconnecting occasionally while running my system (~5min-60min). Also sometimes my LAN connection is not working anymore, especially when used with VPN. Before the replacement of the hardware everything worked without issue.
I see the following logs, when a hard drive is suddenly disconnecting
Jun 27 17:29:35 desktop kernel: ata3.00: exception Emask 0x52 SAct 0x40817c SErr 0xffffffff action 0xe frozen
Jun 27 17:29:35 desktop kernel: ata3: SError: { RecovData RecovComm UnrecovData Persist Proto HostInt PHYRdyChg PHYInt CommWake 10B8B Dispar BadCRC Handshk LinkSeq TrStaTrns UnrecFIS DevExch }
Jun 27 17:29:35 desktop kernel: ata3.00: failed command: READ FPDMA QUEUED
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 60/20:10:40:23:05/00:00:00:00:00/40 tag 2 ncq dma 16384 in
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x56 (ATA bus error)
Jun 27 17:29:35 desktop kernel: ata3.00: status: { DRDY }
Jun 27 17:29:35 desktop kernel: ata3.00: failed command: WRITE FPDMA QUEUED
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 61/d8:18:18:5c:e2/07:00:21:00:00/40 tag 3 ncq dma 1028096 ou
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 61/20:20:f0:63:e2/03:00:21:00:00/40 tag 4 ncq dma 409600 out
res 40/00:00:00:4f:c2/00:00:00:00:00/00 Emask 0x56 (ATA bus error)
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 61/00:28:10:67:e2/0a:00:21:00:00/40 tag 5 ncq dma 1310720 ou
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 61/70:30:10:71:e2/08:00:21:00:00/40 tag 6 ncq dma 1105920 ou
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 60/20:40:00:a5:1f/00:00:00:00:00/40 tag 8 ncq dma 16384 in
res 40/00:ff:00:00:00/00:00:00:00:00/00 Emask 0x56 (ATA bus error)
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 60/20:78:98:44:32/01:00:37:00:00/40 tag 15 ncq dma 147456 in
res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x56 (ATA bus error)
Jun 27 17:29:35 desktop kernel: ata3.00: cmd 60/08:b0:b8:2c:80/00:00:19:00:00/40 tag 22 ncq dma 4096 in
Jun 27 17:29:35 desktop kernel: ata3: hard resetting link
Jun 27 17:29:35 desktop kernel: ahci 0000:4b:00.0: AHCI controller unavailable!
Jun 27 17:29:36 desktop kernel: ata3: failed to resume link (SControl FFFFFFFF)
Jun 27 17:29:36 desktop kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
Jun 27 17:29:41 desktop kernel: ata3: hard resetting link
Jun 27 17:29:41 desktop kernel: ahci 0000:4b:00.0: AHCI controller unavailable!
Jun 27 17:29:42 desktop kernel: ata3: failed to resume link (SControl FFFFFFFF)
Jun 27 17:29:42 desktop kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
Jun 27 17:29:42 desktop kernel: ata3: limiting SATA link speed to <unknown>
Jun 27 17:29:47 desktop kernel: ata3: hard resetting link
Jun 27 17:29:47 desktop kernel: ahci 0000:4b:00.0: AHCI controller unavailable!
Jun 27 17:29:49 desktop kernel: ata3: failed to resume link (SControl FFFFFFFF)
Jun 27 17:29:49 desktop kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
Jun 27 17:29:49 desktop kernel: ata3.00: disable device
Jun 27 17:29:49 desktop kernel: ata3.00: device reported invalid CHS sector 0
Jun 27 17:29:49 desktop kernel: ahci 0000:4b:00.0: AHCI controller unavailable!
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#2 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=43s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#2 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#2 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#2 CDB: Read(10) 28 00 00 05 23 40 00 00 20 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 336704 op 0x0:(READ) flags 0x1000 phys_seg 4 prio class 2
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 0, rd 1, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#3 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=43s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#3 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#3 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#3 CDB: Write(10) 2a 00 21 e2 5c 18 00 07 d8 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 568482840 op 0x1:(WRITE) flags 0x104000 phys_seg 168 prio class 2
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#4 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=43s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#4 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#4 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#4 CDB: Write(10) 2a 00 21 e2 63 f0 00 03 20 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 568484848 op 0x1:(WRITE) flags 0x100000 phys_seg 91 prio class 2
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 1, rd 1, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: rejecting I/O to offline device
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 2433856 op 0x0:(READ) flags 0x1000 phys_seg 4 prio class 2
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 1, rd 2, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 1, rd 3, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 1, rd 4, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=43s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#5 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#5 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#5 CDB: Write(10) 2a 00 21 e2 67 10 00 0a 00 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 568485648 op 0x1:(WRITE) flags 0x104000 phys_seg 132 prio class 2
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=43s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#6 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#6 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#6 CDB: Write(10) 2a 00 21 e2 71 10 00 08 70 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 568488208 op 0x1:(WRITE) flags 0x100000 phys_seg 128 prio class 2
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 2, rd 4, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=44s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#8 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#8 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#8 CDB: Read(10) 28 00 00 1f a5 00 00 00 20 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 2073856 op 0x0:(READ) flags 0x1000 phys_seg 4 prio class 2
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 2, rd 5, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=48s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#15 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#15 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#15 CDB: Read(10) 28 00 37 32 44 98 00 01 20 00
Jun 27 17:29:49 desktop kernel: I/O error, dev sdc, sector 568490368 op 0x1:(WRITE) flags 0x104000 phys_seg 142 prio class 2
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=48s
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#22 Sense Key : Illegal Request [current]
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#22 Add. Sense: Unaligned write command
Jun 27 17:29:49 desktop kernel: sd 2:0:0:0: [sdc] tag#22 CDB: Read(10) 28 00 19 80 2c b8 00 00 08 00
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 2, rd 6, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: ata3: EH complete
Jun 27 17:29:49 desktop kernel: ata3.00: detaching (SCSI 2:0:0:0)
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 2, rd 7, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop kernel: BTRFS error (device sdc1): bdev /dev/sdc1 errs: wr 3, rd 7, flush 0, corrupt 0, gen 0
Jun 27 17:29:49 desktop systemd[1]: Unmounting /run/media/thomas/Daten...
Jun 27 17:29:49 desktop umount[6756]: umount: /run/media/thomas/Daten: target is busy.
Jun 27 17:29:49 desktop systemd[1]: run-media-thomas-Daten.mount: Mount process exited, code=exited, status=32/n/a
Jun 27 17:29:49 desktop systemd[1]: Failed unmounting /run/media/thomas/Daten.
I use the latest version of Manjaro with everything uptodate with Linux 6.1.92-1-MANJARO and Gnome.
