Hard crashes/freezes with kernel 7.0.10
Hi,
Since the last update on testing branch which updated the kernel to version 7.0.10 I got 3 hard lockups without recovery. Had to hard reset the machine. As far as I can interpret it the programs that crashed were pavucontrol and transmission-gtk. Those programs were not updated with the last changes, so the culprit had to be something else. I changed to kernel 6.18 LTS and didn’t have any issues since then.
inxi -Fazy
  Kernel: 6.18.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=84806755-713a-40f0-9fa2-c9b09f2fe665 rw udev.log_priority=3
    acpi_enforce_resources=lax
  Desktop: Sway v: 1.12 with: waybar tools: avail: swayidle vt: 1 dm: N/A
  Type: Desktop System: Gigabyte product: X570S AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570S AORUS MASTER serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: F4 date: 12/26/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3597 min/max: 567/4955 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3597 2: 3597 3: 3597
    4: 3597 5: 3597 6: 3597 7: 3597 8: 3597 9: 3597 10: 3597 11: 3597 12: 3597
    13: 3597 14: 3597 15: 3597 16: 3597 17: 3597 18: 3597 19: 3597 20: 3597
    21: 3597 22: 3597 23: 3597 24: 3597 bogomips: 177609
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
    empty: DP-1,DP-3,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:7550
    class-ID: 0300
  Display: wayland server: Xwayland v: 24.1.11 compositor: Sway v: 1.12
    driver: gpu: amdgpu d-rect: 5760x2160 display-ID: 1
  Monitor-1: DP-2 pos: right model: Gigabyte M32U serial: <filter>
    built: 2022 res: mode: 3840x2160 hz: 144 scale: 150% (1.5) to: 2560x1440
    dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
    ratio: 16:9 modes: max: 3840x2160 min: 720x400
  Monitor-2: HDMI-A-1 pos: left model: EIZO NANAO EV2436W serial: <filter>
    built: 2013 res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
    size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi gfx1201 ACO DRM
    3.64 6.18.33-1-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 26.1.1-arch1.2
    device-ID: 1002:7550 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: amdgpu_top, lact,
    radeontop wl: swaymsg, wayland-info, wlr-randr x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 0d:00.1 chip-ID: 1002:ab40 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.33-1-MANJARO status: kernel-api
  Server-2: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vpnnl9 state: unknown speed: N/A duplex: N/A mac: N/A
  Info: services: sshd,systemd-timesyncd
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5:2 chip-ID: 8087:0032
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: see --recommends
  Local Storage: total: 6.46 TiB used: 3.41 TiB (52.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Lexar model: SSD NM790 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 53.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-1: / raw-size: 200 GiB size: 199.85 GiB (99.93%) used: 30.54 GiB (15.3%)
    fs: xfs dev: /dev/nvme0n1p3 maj-min: 259:8
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 336 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
  ID-3: /home raw-size: 3.49 TiB size: 3.49 TiB (99.95%)
    used: 2.51 TiB (72.0%) fs: xfs dev: /dev/nvme0n1p4 maj-min: 259:9
  ID-1: swap-1 type: partition size: 38 GiB used: 2.94 GiB (7.7%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:7
  System Temperatures: cpu: 42.8 C mobo: 36.0 C gpu: amdgpu temp: 46.0 C
    mem: 45.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 998 fan-3: 722 gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.12 gpu: amdgpu watts: 27.00
  Memory: total: 32 GiB available: 31.23 GiB used: 10.84 GiB (34.7%)
  Processes: 603 Power: uptime: 1d 13h 5m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: suspend avail: platform,
    shutdown, reboot, test_resume image: 12.44 GiB services: upowerd
    Init: systemd v: 260 default: graphical tool: systemctl
  Packages: 1137 pm: pacman pkgs: 1126 libs: 371 tools: yay pm: flatpak
    pkgs: 11 Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: alacritty
    inxi: 3.3.40
First freeze journal in a Pastebin
or hidden:
Mai 31 14:55:28 archjaro kernel: BUG: unable to handle page fault for address: 0000000c00000011
Mai 31 14:55:28 archjaro kernel: #PF: supervisor read access in kernel mode
Mai 31 14:55:28 archjaro kernel: #PF: error_code(0x0000) - not-present page
Mai 31 14:55:28 archjaro kernel: PGD 0 P4D 0
Mai 31 14:55:28 archjaro kernel: Oops: Oops: 0000 [#1] SMP NOPTI
Mai 31 14:55:28 archjaro kernel: CPU: 16 UID: 1000 PID: 3527 Comm: transmission-gt Not tainted 7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:55:28 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:55:28 archjaro kernel: RIP: 0010:ttm_lru_bulk_move_pos_tail+0x4f/0xb0 [ttm]
Mai 31 14:55:28 archjaro kernel: Code: 48 8d 72 40 48 8b 41 48 48 8b 79 40 4c 3b 00 0f 85 a9 45 00 00 4c 3b 47 08 0f 85 9f 45 00 00 48 89 47 08 48 89 38 48 8b 42 40 <48> 3b 70 08 0f 85 68 45 00 00 4c 39 c6 0f 84 5f 45 00 00 4c 39 c0
Mai 31 14:55:28 archjaro kernel: RSP: 0018:ffffd38ed18338b8 EFLAGS: 00010246
Mai 31 14:55:28 archjaro kernel: RAX: 0000000c00000009 RBX: ffff8ef0b7b55c48 RCX: ffff8ef12115cea0
Mai 31 14:55:28 archjaro kernel: RDX: ffff8ef08a9253c0 RSI: ffff8ef08a925400 RDI: ffff8ef0fdf666a0
Mai 31 14:55:28 archjaro kernel: RBP: ffff8ef201ddd800 R08: ffff8ef12115cee0 R09: ffff8ef10db1f958
Mai 31 14:55:28 archjaro kernel: R10: ffff8ef082bd60d0 R11: 0000000000000001 R12: ffff8ef08d18ee18
Mai 31 14:55:28 archjaro kernel: R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000001
Mai 31 14:55:28 archjaro kernel: FS:  00007fae214352c0(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:55:28 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:55:28 archjaro kernel: CR2: 0000000c00000011 CR3: 00000001e84e5000 CR4: 0000000000f50ef0
Mai 31 14:55:28 archjaro kernel: PKRU: 55555554
Mai 31 14:55:28 archjaro kernel: Call Trace:
Mai 31 14:55:28 archjaro kernel:  <TASK>
Mai 31 14:55:28 archjaro kernel:  ? ttm_tt_populate+0x12c/0x160 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 14:55:28 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:55:28 archjaro kernel:  ttm_bo_populate+0x93/0xe0 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 14:55:28 archjaro kernel:  ttm_bo_handle_move_mem+0x16f/0x180 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 14:55:28 archjaro kernel:  ttm_bo_validate+0xec/0x240 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 14:55:28 archjaro kernel:  amdgpu_cs_bo_validate+0xac/0x1d0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  ? __pfx_amdgpu_cs_bo_validate+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  amdgpu_vm_validate+0x2c8/0x450 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  ? drm_exec_lock_obj+0x62/0x220 [drm_exec 2df102f77104a682a63bff2ab1f65678412d6c3f]
Mai 31 14:55:28 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x5c1/0x810 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  amdgpu_cs_ioctl+0xc09/0x1b30 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:55:28 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:55:28 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:28 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:55:28 archjaro kernel:  ? task_work_run+0x66/0xa0
Mai 31 14:55:28 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:55:28 archjaro kernel:  ? irqentry_exit+0x241/0x7a0
Mai 31 14:55:28 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:55:28 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:55:28 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:55:28 archjaro kernel: RIP: 0033:0x7fae23d18edd
Mai 31 14:55:28 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:55:28 archjaro kernel: RSP: 002b:00007ffc8cad8410 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:55:28 archjaro kernel: RAX: ffffffffffffffda RBX: 00007ffc8cad8628 RCX: 00007fae23d18edd
Mai 31 14:55:28 archjaro kernel: RDX: 00007ffc8cad84b0 RSI: 00000000c0186444 RDI: 0000000000000017
Mai 31 14:55:28 archjaro kernel: RBP: 00007ffc8cad8460 R08: 000055fee317bb50 R09: 00007ffc8cad8470
Mai 31 14:55:28 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000017
Mai 31 14:55:28 archjaro kernel: R13: 000055fee4749110 R14: 000055fee317baf0 R15: 000055fee473dc90
Mai 31 14:55:28 archjaro kernel:  </TASK>
Mai 31 14:55:28 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:55:28 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:55:28 archjaro kernel: ---[ end trace 0000000000000000 ]---
Mai 31 14:55:28 archjaro kernel: note: transmission-gt[3527] exited with irqs disabled
Mai 31 14:55:28 archjaro kernel: note: transmission-gt[3527] exited with preempt_count 1
Mai 31 14:55:31 archjaro kernel: igc 0000:07:00.0 enp7s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Mai 31 14:55:54 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 26s! [sway:1479]
Mai 31 14:55:54 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:55:54 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:55:54 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:55:54 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:55:54 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:55:54 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:55:54 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:55:54 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:55:54 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D             7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:55:54 archjaro kernel: Tainted: [D]=DIE
Mai 31 14:55:54 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:55:54 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x72/0x310
Mai 31 14:55:54 archjaro kernel: Code: d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 <80> 39 00 75 f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07
Mai 31 14:55:54 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:55:54 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:55:54 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:55:54 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:55:54 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:55:54 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:55:54 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:55:54 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:55:54 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:55:54 archjaro kernel: PKRU: 55555554
Mai 31 14:55:54 archjaro kernel: Call Trace:
Mai 31 14:55:54 archjaro kernel:  <TASK>
Mai 31 14:55:54 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:55:54 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:54 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:55:54 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:55:54 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:54 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:55:54 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:55:54 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:55:54 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:55:54 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:55:54 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:55:54 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:55:54 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:55:54 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:55:54 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:55:54 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:55:54 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:55:54 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:55:54 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:55:54 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:55:54 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:55:54 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:55:54 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:55:54 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:55:54 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:55:54 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:55:54 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:55:54 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:55:54 archjaro kernel:  </TASK>
Mai 31 14:56:22 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 53s! [sway:1479]
Mai 31 14:56:22 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:56:22 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:56:22 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:22 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:22 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:56:22 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:22 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:56:22 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:56:22 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:56:22 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:56:22 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:56:22 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x72/0x310
Mai 31 14:56:22 archjaro kernel: Code: d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 <80> 39 00 75 f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07
Mai 31 14:56:22 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:56:22 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:56:22 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:56:22 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:56:22 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:56:22 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:56:22 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:56:22 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:56:22 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:56:22 archjaro kernel: PKRU: 55555554
Mai 31 14:56:22 archjaro kernel: Call Trace:
Mai 31 14:56:22 archjaro kernel:  <TASK>
Mai 31 14:56:22 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:56:22 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:22 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:56:22 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:56:22 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:22 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:22 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:56:22 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:56:22 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:56:22 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:56:22 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:56:22 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:56:22 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:56:22 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:56:22 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:56:22 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:56:22 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:56:22 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:56:22 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:56:22 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:56:22 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:56:22 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:56:22 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:56:22 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:56:22 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:56:22 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:56:22 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:56:22 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:56:22 archjaro kernel:  </TASK>
Mai 31 14:56:29 archjaro kernel: rcu: INFO: rcu_preempt self-detected stall on CPU
Mai 31 14:56:29 archjaro kernel: rcu:         16-....: (59999 ticks this GP) idle=b334/1/0x4000000000000000 softirq=325332/325332 fqs=14998
Mai 31 14:56:29 archjaro kernel: rcu:         (t=60000 jiffies g=1665693 q=5475 ncpus=24)
Mai 31 14:56:29 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:56:29 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:56:29 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:56:29 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:56:29 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:56:29 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:56:29 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:56:29 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:56:29 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:56:29 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:56:29 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:56:29 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:56:29 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:56:29 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:56:29 archjaro kernel: PKRU: 55555554
Mai 31 14:56:29 archjaro kernel: Call Trace:
Mai 31 14:56:29 archjaro kernel:  <TASK>
Mai 31 14:56:29 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:56:29 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:29 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:56:29 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:56:29 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:29 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:29 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:56:29 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:56:29 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:56:29 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:56:29 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:56:29 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:56:29 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:56:29 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:56:29 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:56:29 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:56:29 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:56:29 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:56:29 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:56:29 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:56:29 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:56:29 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:56:29 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:56:29 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:56:29 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:56:29 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:56:29 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:56:29 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:56:29 archjaro kernel:  </TASK>
Mai 31 14:56:54 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 82s! [sway:1479]
Mai 31 14:56:54 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:56:54 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:54 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:56:54 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:54 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:56:54 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:56:54 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:56:54 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:56:54 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:56:54 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:56:54 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:56:54 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:56:54 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:56:54 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:56:54 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:56:54 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:56:54 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:56:54 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:56:54 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:56:54 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:56:54 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:56:54 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:56:54 archjaro kernel: PKRU: 55555554
Mai 31 14:56:54 archjaro kernel: Call Trace:
Mai 31 14:56:54 archjaro kernel:  <TASK>
Mai 31 14:56:54 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:56:54 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:54 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:56:54 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:56:54 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:54 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:56:54 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:56:54 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:56:54 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:56:54 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:56:54 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:56:54 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:56:54 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:56:54 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:56:54 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:56:54 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:56:54 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:56:54 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:56:54 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:56:54 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:56:54 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:56:54 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:56:54 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:56:54 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:56:54 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:56:54 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:56:54 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:56:54 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:56:54 archjaro kernel:  </TASK>
Mai 31 14:57:22 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 108s! [sway:1479]
Mai 31 14:57:22 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:57:22 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:57:22 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:57:22 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:57:22 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:57:22 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:57:22 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:57:22 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:57:22 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:57:22 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:57:22 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:57:22 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:57:22 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:57:22 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:57:22 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:57:22 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:57:22 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:57:22 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:57:22 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:57:22 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:57:22 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:57:22 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:57:22 archjaro kernel: PKRU: 55555554
Mai 31 14:57:22 archjaro kernel: Call Trace:
Mai 31 14:57:22 archjaro kernel:  <TASK>
Mai 31 14:57:22 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:57:22 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:22 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:57:22 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:57:22 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:22 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:22 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:57:22 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:57:22 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:57:22 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:57:22 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:57:22 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:57:22 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:57:22 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:57:22 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:57:22 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:57:22 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:57:22 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:57:22 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:57:22 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:57:22 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:57:22 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:57:22 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:57:22 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:57:22 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:57:22 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:57:22 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:57:22 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:57:22 archjaro kernel:  </TASK>
Mai 31 14:57:50 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 134s! [sway:1479]
Mai 31 14:57:50 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:57:50 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:57:50 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:57:50 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:57:50 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:57:50 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:57:50 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:57:50 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:57:50 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:57:50 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:57:50 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:57:50 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:57:50 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:57:50 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:57:50 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:57:50 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:57:50 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:57:50 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:57:50 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:57:50 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:57:50 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:57:50 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:57:50 archjaro kernel: PKRU: 55555554
Mai 31 14:57:50 archjaro kernel: Call Trace:
Mai 31 14:57:50 archjaro kernel:  <TASK>
Mai 31 14:57:50 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:57:50 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:50 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:57:50 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:57:50 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:50 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:57:50 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:57:50 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:57:50 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:57:50 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:57:50 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:57:50 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:57:50 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:57:50 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:57:50 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:57:50 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:57:50 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:57:50 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:57:50 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:57:50 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:57:50 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:57:50 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:57:50 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:57:50 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:57:50 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:57:50 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:57:50 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:57:50 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:57:50 archjaro kernel:  </TASK>
Mai 31 14:58:18 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 161s! [sway:1479]
Mai 31 14:58:18 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:58:18 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:58:18 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:58:18 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:58:18 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:58:18 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:58:18 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:58:18 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:58:18 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:58:18 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:58:18 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:58:18 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:58:18 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:58:18 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:58:18 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:58:18 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:58:18 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:58:18 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:58:18 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:58:18 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:58:18 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:58:18 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:58:18 archjaro kernel: PKRU: 55555554
Mai 31 14:58:18 archjaro kernel: Call Trace:
Mai 31 14:58:18 archjaro kernel:  <TASK>
Mai 31 14:58:18 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:58:18 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:18 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:58:18 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:58:18 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:18 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:18 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:58:18 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:58:18 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:58:18 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:58:18 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:58:18 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:58:18 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:58:18 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:58:18 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:58:18 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:58:18 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:58:18 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:58:18 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:58:18 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:58:18 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:58:18 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:58:18 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:58:18 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:58:18 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:58:18 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:58:18 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:58:18 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:58:18 archjaro kernel:  </TASK>
Mai 31 14:58:27 archjaro kernel: rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 16-.... } 63857 jiffies s: 1805 root: 0x2/.
Mai 31 14:58:27 archjaro kernel: rcu: blocking rcu_node structures (internal RCU debug): l=1:12-23:0x10/.
Mai 31 14:58:27 archjaro kernel: Sending NMI from CPU 5 to CPUs 16:
Mai 31 14:58:27 archjaro kernel: NMI backtrace for cpu 16
Mai 31 14:58:27 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:58:27 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:58:27 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:58:27 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:58:27 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:58:27 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:58:27 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:58:27 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:58:27 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:58:27 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:58:27 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:58:27 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:58:27 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:58:27 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:58:27 archjaro kernel: PKRU: 55555554
Mai 31 14:58:27 archjaro kernel: Call Trace:
Mai 31 14:58:27 archjaro kernel:  <TASK>
Mai 31 14:58:27 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:58:27 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:27 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:58:27 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:58:27 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:27 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:27 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:58:27 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:58:27 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:58:27 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:58:27 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:58:27 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:58:27 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:58:27 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:58:27 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:58:27 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:58:27 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:58:27 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:58:27 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:58:27 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:58:27 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:58:27 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:58:27 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:58:27 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:58:27 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:58:27 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:58:27 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:58:27 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:58:27 archjaro kernel:  </TASK>
Mai 31 14:58:54 archjaro kernel: watchdog: BUG: soft lockup - CPU#16 stuck for 194s! [sway:1479]
Mai 31 14:58:54 archjaro kernel: CPU#16 Utilization every 4000ms during lockup:
Mai 31 14:58:54 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:58:54 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:58:54 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:58:54 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Mai 31 14:58:54 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Mai 31 14:58:54 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi snd_hda_intel jc42 snd_hda_codec snd_hda_core ee1004 snd_intel_dspcfg intel_rapl_msr amd_atl snd_intel_sdw_acpi intel_rapl_common snd_hwdep amd64_edac snd_pcm ghash_clmulni_intel snd_timer aesni_intel sp5100_tco hid_logitech_dj snd rapl gigabyte_wmi wmi_bmof pcspkr ccp soundcore i2c_piix4 k10temp i2c_smbus xpad joydev mousedev ff_memless mac_hid it87 hwmon_vid i2c_dev crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 14:58:54 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 14:58:54 archjaro kernel: CPU: 16 UID: 1000 PID: 1479 Comm: sway Tainted: G      D      L      7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 14:58:54 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Mai 31 14:58:54 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 14:58:54 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x310
Mai 31 14:58:54 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 3d 4a f7 01 e9 0b 18 bc fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Mai 31 14:58:54 archjaro kernel: RSP: 0018:ffffd38ec562f9b8 EFLAGS: 00000202
Mai 31 14:58:54 archjaro kernel: RAX: 0000000000000001 RBX: ffff8ef13e56f848 RCX: ffff8ef08d18f688
Mai 31 14:58:54 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8ef08d18f688
Mai 31 14:58:54 archjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffc0a22297
Mai 31 14:58:54 archjaro kernel: R10: fffff73b043027c0 R11: ffff8ef080042700 R12: ffff8ef27df00c00
Mai 31 14:58:54 archjaro kernel: R13: ffffffffc0a299f0 R14: ffff8ef08d18ee18 R15: 00000000c1206446
Mai 31 14:58:54 archjaro kernel: FS:  00007f6d134d0a00(0000) GS:ffff8ef7f8d66000(0000) knlGS:0000000000000000
Mai 31 14:58:54 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 14:58:54 archjaro kernel: CR2: 0000000c00000011 CR3: 0000000134963000 CR4: 0000000000f50ef0
Mai 31 14:58:54 archjaro kernel: PKRU: 55555554
Mai 31 14:58:54 archjaro kernel: Call Trace:
Mai 31 14:58:54 archjaro kernel:  <TASK>
Mai 31 14:58:54 archjaro kernel:  _raw_spin_lock+0x29/0x30
Mai 31 14:58:54 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:54 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 14:58:54 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 14:58:54 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:54 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 14:58:54 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 14:58:54 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 14:58:54 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 14:58:54 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 14:58:54 archjaro kernel:  ? unix_stream_recvmsg+0x8a/0xa0
Mai 31 14:58:54 archjaro kernel:  ? __pfx_unix_stream_read_actor+0x10/0x10
Mai 31 14:58:54 archjaro kernel:  ? __task_pid_nr_ns+0x64/0xd0
Mai 31 14:58:54 archjaro kernel:  ? ____sys_recvmsg+0xbc/0x210
Mai 31 14:58:54 archjaro kernel:  ? ___sys_recvmsg+0xc6/0x100
Mai 31 14:58:54 archjaro kernel:  ? __sys_recvmsg+0xeb/0x100
Mai 31 14:58:54 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 14:58:54 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Mai 31 14:58:54 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 14:58:54 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 14:58:54 archjaro kernel: RIP: 0033:0x7f6d14118edd
Mai 31 14:58:54 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 14:58:54 archjaro kernel: RSP: 002b:00007ffcda4fb450 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 14:58:54 archjaro kernel: RAX: ffffffffffffffda RBX: 000000000000000f RCX: 00007f6d14118edd
Mai 31 14:58:54 archjaro kernel: RDX: 00007ffcda4fb4b0 RSI: 00000000c1206446 RDI: 000000000000000f
Mai 31 14:58:54 archjaro kernel: RBP: 00007ffcda4fb4a0 R08: 00007ffcda4fb7ac R09: 00007ffcda4fb7b0
Mai 31 14:58:54 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000055fd65f74230
Mai 31 14:58:54 archjaro kernel: R13: 0000000000000020 R14: 000055fd6711eaa0 R15: 0000000000000000
Mai 31 14:58:54 archjaro kernel:  </TASK>
Second freeze in a Pastebin
Second freeze journal
Mai 31 17:08:24 archjaro kernel: BUG: kernel NULL pointer dereference, address: 0000000000000010
Mai 31 17:08:24 archjaro kernel: #PF: supervisor read access in kernel mode
Mai 31 17:08:24 archjaro kernel: #PF: error_code(0x0000) - not-present page
Mai 31 17:08:24 archjaro kernel: PGD 0 P4D 0
Mai 31 17:08:24 archjaro kernel: Oops: Oops: 0000 [#1] SMP NOPTI
Mai 31 17:08:24 archjaro kernel: CPU: 0 UID: 1000 PID: 1319 Comm: pavucontrol Not tainted 7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Mai 31 17:08:24 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Mai 31 17:08:24 archjaro kernel: RIP: 0010:ttm_lru_bulk_move_del+0xd4/0x120 [ttm]
Mai 31 17:08:24 archjaro kernel: Code: e9 4c c3 49 c6 0f 0b 4a 8d 04 81 48 c1 e0 04 48 c7 04 02 00 00 00 00 48 c7 44 02 08 00 00 00 00 e9 2c c3 49 c6 90 48 8b 7f 08 <8b> 47 10 85 c0 75 f5 4a 8d 04 81 48 83 ef 40 48 c1 e0 04 48 89 7c
Mai 31 17:08:24 archjaro kernel: RSP: 0018:ffffcfb0467d35c8 EFLAGS: 00010202
Mai 31 17:08:24 archjaro kernel: RAX: 000000000000000e RBX: ffff888d8ebc8448 RCX: 0000000000000001
Mai 31 17:08:24 archjaro kernel: RDX: ffff888d8ea79948 RSI: ffff888d9ce0d660 RDI: 0000000000000000
Mai 31 17:08:24 archjaro kernel: RBP: ffff888d83141a00 R08: 0000000000000000 R09: ffff888d9ce0d660
Mai 31 17:08:24 archjaro kernel: R10: ffff888d9c20ee18 R11: ffff888dd6a89c00 R12: ffff888d8ebc85e8
Mai 31 17:08:24 archjaro kernel: R13: ffff888d9ce0d660 R14: ffff888d9c200000 R15: 0000000000000001
Mai 31 17:08:24 archjaro kernel: FS:  00007f67d081ee40(0000) GS:ffff889514f66000(0000) knlGS:0000000000000000
Mai 31 17:08:24 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 31 17:08:24 archjaro kernel: CR2: 0000000000000010 CR3: 000000011aa54000 CR4: 0000000000f50ef0
Mai 31 17:08:24 archjaro kernel: PKRU: 55555554
Mai 31 17:08:24 archjaro kernel: Call Trace:
Mai 31 17:08:24 archjaro kernel:  <TASK>
Mai 31 17:08:24 archjaro kernel:  ttm_resource_free+0x5a/0xf0 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 17:08:24 archjaro kernel:  amdgpu_bo_move+0xd2/0x880 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 31 17:08:24 archjaro kernel:  ? unmap_mapping_range+0x7e/0x130
Mai 31 17:08:24 archjaro kernel:  ? __pfx_amdgpu_bo_move+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ttm_bo_handle_move_mem+0xc0/0x180 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 17:08:24 archjaro kernel:  ttm_bo_validate+0xec/0x240 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Mai 31 17:08:24 archjaro kernel:  amdgpu_cs_bo_validate+0xac/0x1d0 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ? __pfx_amdgpu_cs_bo_validate+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  amdgpu_vm_validate+0x2c8/0x450 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ? drm_exec_lock_obj+0x62/0x220 [drm_exec 2df102f77104a682a63bff2ab1f65678412d6c3f]
Mai 31 17:08:24 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x5c1/0x810 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  amdgpu_cs_ioctl+0xc09/0x1b30 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Mai 31 17:08:24 archjaro kernel:  drm_ioctl+0x2d8/0x570
Mai 31 17:08:24 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Mai 31 17:08:24 archjaro kernel:  do_syscall_64+0x119/0x1640
Mai 31 17:08:24 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Mai 31 17:08:24 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Mai 31 17:08:24 archjaro kernel:  ? do_syscall_64+0x119/0x1640
Mai 31 17:08:24 archjaro kernel:  ? place_entity+0x9f/0x150
Mai 31 17:08:24 archjaro kernel:  ? reweight_entity+0x292/0x300
Mai 31 17:08:24 archjaro kernel:  ? task_tick_fair+0x1c3/0x500
Mai 31 17:08:24 archjaro kernel:  ? sched_balance_trigger+0x81/0x400
Mai 31 17:08:24 archjaro kernel:  ? perf_event_task_tick+0x4f/0xb0
Mai 31 17:08:24 archjaro kernel:  ? update_process_times+0x95/0xc0
Mai 31 17:08:24 archjaro kernel:  ? tick_nohz_handler+0xb1/0x180
Mai 31 17:08:24 archjaro kernel:  ? timerqueue_add+0xb8/0xe0
Mai 31 17:08:24 archjaro kernel:  ? __hrtimer_run_queues+0x16e/0x2c0
Mai 31 17:08:24 archjaro kernel:  ? ktime_get+0xac/0x100
Mai 31 17:08:24 archjaro kernel:  ? clockevents_program_event+0x98/0x150
Mai 31 17:08:24 archjaro kernel:  ? hrtimer_interrupt+0x13b/0x240
Mai 31 17:08:24 archjaro kernel:  ? sched_clock_cpu+0xf/0x1f0
Mai 31 17:08:24 archjaro kernel:  ? irqtime_account_irq+0x30/0xc0
Mai 31 17:08:24 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Mai 31 17:08:24 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mai 31 17:08:24 archjaro kernel: RIP: 0033:0x7f67d2d18edd
Mai 31 17:08:24 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Mai 31 17:08:24 archjaro kernel: RSP: 002b:00007ffff623bdb0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mai 31 17:08:24 archjaro kernel: RAX: ffffffffffffffda RBX: 00007ffff623bfc8 RCX: 00007f67d2d18edd
Mai 31 17:08:24 archjaro kernel: RDX: 00007ffff623be50 RSI: 00000000c0186444 RDI: 000000000000000b
Mai 31 17:08:24 archjaro kernel: RBP: 00007ffff623be00 R08: 000055a553743bf0 R09: 00007ffff623be10
Mai 31 17:08:24 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000b
Mai 31 17:08:24 archjaro kernel: R13: 000055a5533480e0 R14: 000055a553743b90 R15: 000055a55333ceb0
Mai 31 17:08:24 archjaro kernel:  </TASK>
Mai 31 17:08:24 archjaro kernel: Modules linked in: 8021q garp mrp stp llc snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_atihdmi snd_hda_codec_hdmi jc42 snd_hda_intel snd_hda_codec amd_atl intel_rapl_msr ee1004 intel_rapl_common snd_hda_core vfat amd64_edac snd_intel_dspcfg fat ghash_clmulni_intel snd_intel_sdw_acpi snd_hwdep aesni_intel snd_pcm sp5100_tco hid_logitech_dj rapl snd_timer wmi_bmof gigabyte_wmi pcspkr snd i2c_piix4 ccp soundcore k10temp i2c_smbus mousedev joydev xpad ff_memless mac_hid it87 i2c_dev hwmon_vid crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Mai 31 17:08:24 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Mai 31 17:08:24 archjaro kernel: ---[ end trace 0000000000000000 ]---
Mai 31 17:08:24 archjaro kernel: note: pavucontrol[1319] exited with irqs disabled
Mai 31 17:08:24 archjaro kernel: note: pavucontrol[1319] exited with preempt_count 1
Third freeze in Pastebin
Third freeze journal
Jun 01 07:31:55 archjaro kernel: #PF: supervisor read access in kernel mode
Jun 01 07:31:55 archjaro kernel: #PF: error_code(0x0000) - not-present page
Jun 01 07:31:55 archjaro kernel: PGD 0 P4D 0
Jun 01 07:31:55 archjaro kernel: Oops: Oops: 0000 [#1] SMP NOPTI
Jun 01 07:31:55 archjaro kernel: CPU: 16 UID: 1000 PID: 10298 Comm: transmission-gt Not tainted 7.0.10-1-MANJARO #1 PREEMPT(full)  566ba636deb7082f128dd87f76270b8ca76878d6
Jun 01 07:31:55 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 01 07:31:55 archjaro kernel: RIP: 0010:ttm_lru_bulk_move_pos_tail+0x4f/0xb0 [ttm]
Jun 01 07:31:55 archjaro kernel: Code: 48 8d 72 40 48 8b 41 48 48 8b 79 40 4c 3b 00 0f 85 a9 45 00 00 4c 3b 47 08 0f 85 9f 45 00 00 48 89 47 08 48 89 38 48 8b 42 40 <48> 3b 70 08 0f 85 68 45 00 00 4c 39 c6 0f 84 5f 45 00 00 4c 39 c0
Jun 01 07:31:55 archjaro kernel: RSP: 0000:ffffd0c054f0bc38 EFLAGS: 00010246
Jun 01 07:31:55 archjaro kernel: RAX: 00000008001005ff RBX: ffff8edecf920c48 RCX: ffff8edf8396c1e0
Jun 01 07:31:55 archjaro kernel: RDX: ffff8edf8396c960 RSI: ffff8edf8396c9a0 RDI: ffff8edf8396c1c0
Jun 01 07:31:55 archjaro kernel: RBP: ffff8edf17173680 R08: ffff8edf8396c220 R09: ffff8edf6a7cf958
Jun 01 07:31:55 archjaro kernel: R10: ffff8edec27860d0 R11: 0000000000000001 R12: ffff8ededdb0ee18
Jun 01 07:31:55 archjaro kernel: R13: 000000000011df6c R14: 0000000000000001 R15: 0000000000000080
Jun 01 07:31:55 archjaro kernel: FS:  00007fa20986b2c0(0000) GS:ffff8ee64cd66000(0000) knlGS:0000000000000000
Jun 01 07:31:55 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 01 07:31:55 archjaro kernel: CR2: 0000000800100607 CR3: 000000036e14f000 CR4: 0000000000f50ef0
Jun 01 07:31:55 archjaro kernel: PKRU: 55555554
Jun 01 07:31:55 archjaro kernel: Call Trace:
Jun 01 07:31:55 archjaro kernel:  <TASK>
Jun 01 07:31:55 archjaro kernel:  ? ttm_tt_populate+0x12c/0x160 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Jun 01 07:31:55 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 01 07:31:55 archjaro kernel:  ttm_bo_populate+0x93/0xe0 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Jun 01 07:31:55 archjaro kernel:  ttm_bo_vm_fault_reserved+0x253/0x470 [ttm 2cb1b09aff5703ef70ee4aabeb151d98cbe6bde9]
Jun 01 07:31:55 archjaro kernel:  amdgpu_gem_fault+0x95/0x100 [amdgpu f8b2dca1d6c0641254752586c6bc5d59136cff7c]
Jun 01 07:31:55 archjaro kernel:  __do_fault+0x34/0x1b0
Jun 01 07:31:55 archjaro kernel:  do_fault+0x157/0x5d0
Jun 01 07:31:55 archjaro kernel:  ? __pte_offset_map+0x1b/0x100
Jun 01 07:31:55 archjaro kernel:  __handle_mm_fault+0x95c/0xfa0
Jun 01 07:31:55 archjaro kernel:  handle_mm_fault+0xe7/0x2b0
Jun 01 07:31:55 archjaro kernel:  do_user_addr_fault+0x16a/0x710
Jun 01 07:31:55 archjaro kernel:  exc_page_fault+0x90/0x1f0
Jun 01 07:31:55 archjaro kernel:  ? __irq_exit_rcu+0x4c/0xf0
Jun 01 07:31:55 archjaro kernel:  asm_exc_page_fault+0x26/0x30
Jun 01 07:31:55 archjaro kernel: RIP: 0033:0x7fa20d96fdcd
Jun 01 07:31:55 archjaro kernel: Code: c0 50 48 8d 45 bc 45 89 d8 31 c9 50 48 8d 35 0a 2a 5c 00 e8 35 ae 08 00 4c 8b 55 a0 48 8b 5d b0 f3 41 0f 10 02 f3 41 0f 58 07 <f3> 0f 11 03 f3 41 0f 10 42 04 f3 41 0f 58 47 04 f3 0f 11 43 04 f3
Jun 01 07:31:55 archjaro kernel: RSP: 002b:00007fffb43a8fa0 EFLAGS: 00010202
Jun 01 07:31:55 archjaro kernel: RAX: 0000000000000000 RBX: 00007fa1aff80000 RCX: 0000000000000000
Jun 01 07:31:55 archjaro kernel: RDX: 0000000000000000 RSI: 00007fffb43a8ec0 RDI: 000055ad9505ea80
Jun 01 07:31:55 archjaro kernel: RBP: 00007fffb43a9020 R08: 0000000000000001 R09: 00007fffb43a8fe0
Jun 01 07:31:55 archjaro kernel: R10: 00007fffb43a9170 R11: 0000000000000000 R12: 00007fa20df3c100
Jun 01 07:31:55 archjaro kernel: R13: 00007fffb43a9230 R14: 00007fffb43a91c0 R15: 00007fffb43a91b0
Jun 01 07:31:55 archjaro kernel:  </TASK>
Jun 01 07:31:55 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device 8021q garp mrp stp llc wireguard libcurve25519 ip6_udp_tunnel udp_tunnel nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink hid_logitech_hidpp btusb btmtk btrtl btbcm btintel bluetooth iwlmvm mac80211 libarc4 iwlwifi cfg80211 snd_hda_codec_alc882 igc snd_hda_codec_atihdmi snd_hda_codec_realtek_lib snd_hda_codec_generic snd_hda_codec_hdmi ptp pps_core rfkill hid_logitech_dj snd_hda_intel snd_hda_codec jc42 snd_hda_core intel_rapl_msr ee1004 vfat snd_intel_dspcfg amd_atl snd_intel_sdw_acpi fat intel_rapl_common snd_hwdep amd64_edac snd_pcm xpad ghash_clmulni_intel mousedev joydev sp5100_tco ff_memless snd_timer aesni_intel gigabyte_wmi wmi_bmof snd rapl i2c_piix4 soundcore ccp pcspkr k10temp i2c_smbus mac_hid it87 i2c_dev hwmon_vid crypto_user xfs amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm
Jun 01 07:31:55 archjaro kernel:  drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video drm_buddy nvme drm_display_helper nvme_core cec nvme_keyring nvme_auth hkdf wmi
Jun 01 07:31:55 archjaro kernel: ---[ end trace 0000000000000000 ]---
Jun 01 07:31:55 archjaro kernel: note: transmission-gt[10298] exited with irqs disabled
Jun 01 07:31:55 archjaro kernel: note: transmission-gt[10298] exited with preempt_count 1
My knowledge is not sufficient to make sense of these journals. Could someone from the community share his thoughts on this?
Created the logs with this command, although it worked only on the first journal, the second and third are capped, for some reason.
sudo journalctl --since "2026-06-01 07:31:55" --until "2026-06-01 07:32:20" | grep kernel >> thirdkernelfreeze  ```
It’s pretty hard to tell what’s causing it with those logs, but amdgpu is crashing when the DRM memory manager tries to do an operation.
Want to know what each of those mean?
It sounds probable you found a bug in the newest kernel release candidate, related to your GPU.
If you want a fix, run a newer more stable kernel than 6.18 LTS, run kernel 7.0, as it’s the latest.
(7.1 has not even been officially released yet.)
I seriously doubt whether 7.0 would be more stable than 6.18, which is an LTS kernel. 7.0 will have more features, yes, but also more bugs, while 6.18 is rock-solid.
Besides, 6.18 does appear to work for the OP.
I don’t know why I said “fix”.
But if they need a newer kernel, it’s an option.
As the last 7.1 RC worked, it’s probable that 7.0 would be fine.
I have been using 7.0 kernel for few weeks, it’s very stable for me…
But I also happen to have most supported hardware - ThinkPad (with iGPU)
So maybe the experience on certain hardware may vary.
I also avoid kernels that specifically are marked as ‘experimental’ like the new 7.10 series.
I amended the topic title to say 7.0.10, however after reading through this thread again I am still not entirely certain which kernel you are actually referring to. Edit: don’t worry - I found it in your first freeze journal - I had to do some horizontal scrolling to spot it:
Needless to say, the Linux 7.10 kernel that you have mentioned is still a long way off - probably close to 2 years away. There were 21 months between the releases of linux60on 2022-10-02 & linux610 on 2024-07-14:
❯ datediff 2022-10-02 2024-07-14 -f '%m months %d days'
21 months 12 days
Also, you might want to test if the issue occurs with the kernel 7.1 release candidate. I’ve been running the linux71 release candidates full-time on my AMD mini-PC since the 19th of April (nearly 2 months ago) without encountering any issues. I did experience quite a few issues with the linux70 release candidates & early versions though.
You might find linux71 to be a better user experience than linux70.
Thanks for all the answers.
It has been for me as well, until 7.0.10, the subversions before this .1 .2 .3 .5 and .7 were stable as well. For these unforeseen circumstances I keep the last two LTS kernels around, just to be on the safe side.
It was late yesterday and a long working day but I didn’t want to wait till weekend to report this.
I’m quite happy with the 6.18 kernel for the time being. The question is whether I should report this kernel bug upstream.
Did you try ?
This often prevents damage to the filesystem. :footprints:
I suggest:
  1. install pavucontrol-qt and remove pavucontrol (depends on Gtk)
  2. install transmission-qt or qbitorrent and remove transmission-gtk
  3. Remove orphaned Gtk packages
Your kernel log indicates that your kernel is not tainted — i.e. it does not have any proprietary drivers loaded — so in theory, you could indeed submit a bug report.
However, due to 7.1 still being a work in progress — it’s still a prerelease — chances are that a patch for the bug may already be on its way into the source code by the time you’ve submitted your report.
You are free to try, though. Again, it’s an untainted kernel, so they will take your bug report seriously. :wink:
I didn’t try this for about 20 years, as it never worked for me, but I’ll give it a try next weekend when testing further. It seems that I actually had some damage with active torrents, as after the next boot some torrents had to be downloaded again. Is there a way to check for further damage on XFS?
As Sway is a GTK based WM, the theming is all weird with Qt packages. Tried in the past, but thanks for the input.
sudo pacman -Qtdq
calcmysky
cantarell-fonts
cmake
eigen
fcitx5
ffmpeg4.4
freeimage
glm
granite
ibus
jasper
lib32-libcap
libgusb
libindi
libinstpatch
libomxil-bellagio
libsoup
linux-firmware-amdgpu
linux-firmware-atheros
linux-firmware-broadcom
linux-firmware-cirrus
linux-firmware-intel
linux-firmware-mediatek
linux-firmware-nvidia
linux-firmware-other
linux-firmware-radeon
linux-firmware-realtek
mhwd-nvidia-570xx
mhwd-nvidia-575xx
nlopt
python-flit
qt6-charts
qt6-webengine
t1lib
vulkan-headers
wlroots0.17
wlroots0.18
wlroots0.19
@nikgnomic which one do you suggest I should remove? Don’t see any GTK deps.
I choose my hardware very specifically to be supported by the kernel. Neither Nvidia nor any other Evilcorp hardware will find a place in my computer if I can help it :smiling_face_with_horns:
That’s what I thought too. I have only time in the weekend. If there is a new 7.0.x version, or 7.1.x gets released, I’ll give that I try first. If the problem persists I’ll file a bug report upstream.
I use kvantum on Xfce to manage Qt theme
I’ve had a couple of cases where a newer kernel exposed an issue that wasn’t obvious before. If you haven’t already, it might be worth testing an older LTS kernel for a few days just to confirm whether the freezes are kernel-related or coming from something else in the stack.
FYI, confirmed REISUB working beforehand in sysctl. Booted into 7.0.10 by accident. System froze, audio of the video kept playing. REISUB didn’t work.
Journal not recoverable, simply missing.
Same crash now with 7.1.1-3. I’ll have to report this upstream.
Never done this before. Anyone experience?
This tells me to identify the subsystem and then look for hoe to notify. My guess would be it is the graphics card crashing, but is it mesa then?
How do I find out which subsystem it is?
Here is the new journal in a pastebin
and as preformatted text
Jun 29 08:16:31 archjaro kernel: BUG: unable to handle page fault for address: 0000000800100670
Jun 29 08:16:31 archjaro kernel: #PF: supervisor read access in kernel mode
Jun 29 08:16:31 archjaro kernel: #PF: error_code(0x0000) - not-present page
Jun 29 08:16:31 archjaro kernel: PGD 0 P4D 0
Jun 29 08:16:31 archjaro kernel: Oops: Oops: 0000 [#1] SMP NOPTI
Jun 29 08:16:31 archjaro kernel: CPU: 0 UID: 1000 PID: 7012 Comm: vo Not tainted 7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:31 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:16:31 archjaro kernel: RIP: 0010:ttm_lru_bulk_move_tail+0x129/0x1d0 [ttm]
Jun 29 08:16:31 archjaro kernel: Code: ff ff 31 db 41 89 da 4d 89 d8 41 b9 68 00 00 00 31 ff 49 83 c2 1a 49 8b 10 48 85 d2 74 51 48 8b 42 30 49 8b 48 08 48 8b 6a 48 <48> 8b 80 70 01 00 00 48 83 c1 40 4a 8b 74 d0 08 48 8b 01 48 89 45
Jun 29 08:16:31 archjaro kernel: RSP: 0018:ffffcd6fd0b8f8f8 EFLAGS: 00010286
Jun 29 08:16:31 archjaro kernel: RAX: 0000000800100500 RBX: 0000000000000000 RCX: ffff8a7f920c6b40
Jun 29 08:16:31 archjaro kernel: RDX: ffff8a7c59aec5a0 RSI: ffff8a7cd7067000 RDI: 0000000000000002
Jun 29 08:16:31 archjaro kernel: RBP: 0000000000000000 R08: ffff8a7cd7067960 R09: 0000000000000088
Jun 29 08:16:31 archjaro kernel: R10: 000000000000001a R11: ffff8a7cd7067940 R12: ffff8a7cd7067000
Jun 29 08:16:31 archjaro kernel: R13: ffffffff9dd53c60 R14: 0000000000000003 R15: 000000000000a00e
Jun 29 08:16:31 archjaro kernel: FS:  00007ff257fff6c0(0000) GS:ffff8a844036a000(0000) knlGS:0000000000000000
Jun 29 08:16:31 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:16:31 archjaro kernel: CR2: 0000000800100670 CR3: 00000001ab4d6000 CR4: 0000000000f50ef0
Jun 29 08:16:31 archjaro kernel: PKRU: 55555554
Jun 29 08:16:31 archjaro kernel: Call Trace:
Jun 29 08:16:31 archjaro kernel:  <TASK>
Jun 29 08:16:31 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:16:31 archjaro kernel:  amdgpu_vm_move_to_lru_tail+0x29/0x40 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  amdgpu_cs_ioctl+0x1914/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:16:31 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:16:31 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:16:31 archjaro kernel:  ? dma_fence_signal_timestamp_locked+0xc8/0x180
Jun 29 08:16:31 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:16:31 archjaro kernel:  ? kgd2kfd_interrupt+0xe3/0x1a0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? amdgpu_irq_dispatch+0xcc/0x2e0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? __wake_up+0x44/0x60
Jun 29 08:16:31 archjaro kernel:  ? amdgpu_ih_process+0xcc/0x1a0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? amdgpu_ras_interrupt_fatal_error_handler+0x4c/0xb0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? amdgpu_irq_handler+0x55/0x60 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:31 archjaro kernel:  ? sched_clock_cpu+0xf/0x1f0
Jun 29 08:16:31 archjaro kernel:  ? irqtime_account_irq+0x30/0xc0
Jun 29 08:16:31 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:16:31 archjaro kernel:  ? __irq_exit_rcu+0x48/0x100
Jun 29 08:16:31 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:16:31 archjaro kernel: RIP: 0033:0x7ff279318edd
Jun 29 08:16:31 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:16:31 archjaro kernel: RSP: 002b:00007ff257fefa50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:16:31 archjaro kernel: RAX: ffffffffffffffda RBX: 00007ff257fefc68 RCX: 00007ff279318edd
Jun 29 08:16:31 archjaro kernel: RDX: 00007ff257fefaf0 RSI: 00000000c0186444 RDI: 000000000000000b
Jun 29 08:16:31 archjaro kernel: RBP: 00007ff257fefaa0 R08: 00007ff2486a4130 R09: 00007ff257fefab0
Jun 29 08:16:31 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000b
Jun 29 08:16:31 archjaro kernel: R13: 00007ff248081440 R14: 00007ff2486a40d0 R15: 00007ff248079d20
Jun 29 08:16:31 archjaro kernel:  </TASK>
Jun 29 08:16:31 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:16:31 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:16:31 archjaro kernel: ---[ end trace 0000000000000000 ]---
Jun 29 08:16:31 archjaro kernel: note: vo[7012] exited with irqs disabled
Jun 29 08:16:31 archjaro kernel: note: vo[7012] exited with preempt_count 1
Jun 29 08:16:57 archjaro kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 26s! [kworker/u97:104:29753]
Jun 29 08:16:57 archjaro kernel: CPU#0 Utilization every 4000ms during lockup:
Jun 29 08:16:57 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:57 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:57 archjaro kernel:         #3: 100% system,          1% softirq,          0% hardirq,          0% idle
Jun 29 08:16:57 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:57 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:57 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:16:57 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:16:57 archjaro kernel: CPU: 0 UID: 0 PID: 29753 Comm: kworker/u97:104 Tainted: G      D             7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:57 archjaro kernel: Tainted: [D]=DIE
Jun 29 08:16:57 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:16:57 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:16:57 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x297/0x300
Jun 29 08:16:57 archjaro kernel: Code: 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 <66> 85 c0 75 f7 44 39 c0 74 47 c6 01 01 48 85 f6 74 0e c7 46 08 01
Jun 29 08:16:57 archjaro kernel: RSP: 0018:ffffcd6fc1b0bb38 EFLAGS: 00000202
Jun 29 08:16:57 archjaro kernel: RAX: 0000000000480101 RBX: ffff8a7cced6e848 RCX: ffff8a7ce148f918
Jun 29 08:16:57 archjaro kernel: RDX: ffff8a83dec34140 RSI: 0000000000000000 RDI: 0000000000000000
Jun 29 08:16:57 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000040000 R09: ffff8a844036a000
Jun 29 08:16:57 archjaro kernel: R10: 0000000000040000 R11: ffff8a7ccd03d480 R12: 0000000000000000
Jun 29 08:16:57 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:16:57 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a844036a000(0000) knlGS:0000000000000000
Jun 29 08:16:57 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:16:57 archjaro kernel: CR2: 0000000800100670 CR3: 000000041d9ff000 CR4: 0000000000f50ef0
Jun 29 08:16:57 archjaro kernel: PKRU: 55555554
Jun 29 08:16:57 archjaro kernel: Call Trace:
Jun 29 08:16:57 archjaro kernel:  <TASK>
Jun 29 08:16:57 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:16:57 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:16:57 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:16:57 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:57 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:57 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:57 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:16:57 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:57 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:16:57 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:16:57 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:16:57 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:16:57 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:16:57 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:16:57 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:16:57 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:16:57 archjaro kernel:  </TASK>
Jun 29 08:16:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 26s! [vivaldi-bi:cs0:6081]
Jun 29 08:16:59 archjaro kernel: CPU#2 Utilization every 4000ms during lockup:
Jun 29 08:16:59 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:16:59 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:16:59 archjaro kernel: CPU: 2 UID: 1000 PID: 6081 Comm: vivaldi-bi:cs0 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:59 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:16:59 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:16:59 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x300
Jun 29 08:16:59 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 9d 5a f8 01 e9 6b 68 bd fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Jun 29 08:16:59 archjaro kernel: RSP: 0018:ffffcd6fd1f93818 EFLAGS: 00000202
Jun 29 08:16:59 archjaro kernel: RAX: 0000000000000001 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:16:59 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a7ce148f918
Jun 29 08:16:59 archjaro kernel: RBP: ffff8a7dffc75000 R08: ffff8a7f62d52ba8 R09: ffff8a8007e06448
Jun 29 08:16:59 archjaro kernel: R10: ffffcd6fd1f93988 R11: ffff8a7cc0371700 R12: ffff8a7ce1480000
Jun 29 08:16:59 archjaro kernel: R13: ffff8a7ce1490e58 R14: ffff8a7ce1490870 R15: 00000003f2459000
Jun 29 08:16:59 archjaro kernel: FS:  00007f4010dff6c0(0000) GS:ffff8a84403ea000(0000) knlGS:0000000000000000
Jun 29 08:16:59 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:16:59 archjaro kernel: CR2: 0000183c07d7b600 CR3: 0000000118f96000 CR4: 0000000000f50ef0
Jun 29 08:16:59 archjaro kernel: PKRU: 55555558
Jun 29 08:16:59 archjaro kernel: Call Trace:
Jun 29 08:16:59 archjaro kernel:  <TASK>
Jun 29 08:16:59 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:16:59 archjaro kernel:  ttm_resource_manager_usage+0x2e/0x70 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x486/0x810 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  amdgpu_cs_ioctl+0xc06/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:16:59 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:16:59 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:16:59 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:16:59 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:16:59 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:16:59 archjaro kernel:  ? __x64_sys_futex+0x12a/0x220
Jun 29 08:16:59 archjaro kernel:  ? switch_fpu_return+0x5e/0x100
Jun 29 08:16:59 archjaro kernel:  ? do_syscall_64+0x282/0x640
Jun 29 08:16:59 archjaro kernel:  ? futex_wake+0xcc/0x240
Jun 29 08:16:59 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:16:59 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:16:59 archjaro kernel: RIP: 0033:0x7f4029718edd
Jun 29 08:16:59 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:16:59 archjaro kernel: RSP: 002b:00007f4010dfcb50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:16:59 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f4010dfce88 RCX: 00007f4029718edd
Jun 29 08:16:59 archjaro kernel: RDX: 00007f4010dfcbe0 RSI: 00000000c0186444 RDI: 0000000000000012
Jun 29 08:16:59 archjaro kernel: RBP: 00007f4010dfcba0 R08: 00007f4010dfcd20 R09: 00007f4010dfcbb0
Jun 29 08:16:59 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000012
Jun 29 08:16:59 archjaro kernel: R13: 00007f4010dfce88 R14: 0000000000000004 R15: 00000ff400720000
Jun 29 08:16:59 archjaro kernel:  </TASK>
Jun 29 08:16:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 26s! [Renderer:2175]
Jun 29 08:16:59 archjaro kernel: CPU#13 Utilization every 4000ms during lockup:
Jun 29 08:16:59 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel: CPU: 13 UID: 1000 PID: 2175 Comm: Renderer Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:59 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x27f/0x300
Jun 29 08:16:59 archjaro kernel: Code: c1 ef 12 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 <8b> 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90
Jun 29 08:16:59 archjaro kernel: RSP: 0018:ffffcd6fc669f6f0 EFLAGS: 00000246
Jun 29 08:16:59 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a80fd7ad680 RCX: ffff8a7ce148f918
Jun 29 08:16:59 archjaro kernel: RDX: ffff8a83def74140 RSI: 0000000000000000 RDI: 000000000000000f
Jun 29 08:16:59 archjaro kernel: RBP: ffff8a7fe82e4448 R08: 0000000000380000 R09: ffff8a84406aa000
Jun 29 08:16:59 archjaro kernel: R10: 0000000000380000 R11: ffff8a7f7a2decd8 R12: ffff8a7ce1490870
Jun 29 08:16:59 archjaro kernel: R13: ffff8a7fe82e4408 R14: ffff8a80fd7ad680 R15: 00000003fa800000
Jun 29 08:16:59 archjaro kernel: FS:  00007f03210d86c0(0000) GS:ffff8a84406aa000(0000) knlGS:0000000000000000
Jun 29 08:16:59 archjaro kernel: CR2: 0000183c03582000 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:16:59 archjaro kernel: PKRU: 55555554
Jun 29 08:16:59 archjaro kernel:  ? __kmalloc_cache_noprof+0x135/0x480
Jun 29 08:16:59 archjaro kernel:  ? amdgpu_vram_mgr_new+0xad/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ttm_resource_init+0x6f/0x150 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  amdgpu_vram_mgr_new+0xc7/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? dmem_cgroup_try_charge+0x98/0x200
Jun 29 08:16:59 archjaro kernel:  ttm_resource_alloc+0x90/0x120 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  ttm_bo_alloc_resource+0x118/0x4d0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  ? add_hole+0x130/0x1b0
Jun 29 08:16:59 archjaro kernel:  ? drm_mm_insert_node_in_range+0x5f4/0x680
Jun 29 08:16:59 archjaro kernel:  ttm_bo_validate+0xaf/0x240 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  ttm_bo_init_reserved+0x15c/0x1e0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  amdgpu_bo_create+0x1de/0x520 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? __pfx_amdgpu_bo_user_destroy+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  amdgpu_bo_create_user+0x3d/0x70 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  amdgpu_gem_create_ioctl+0x17d/0x470 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? __pfx_amdgpu_gem_create_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? drm_ioctl_kernel+0xae/0x100
Jun 29 08:16:59 archjaro kernel:  ? drm_ioctl+0x30f/0x550
Jun 29 08:16:59 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:16:59 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Jun 29 08:16:59 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:16:59 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
Jun 29 08:16:59 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:16:59 archjaro kernel: RIP: 0033:0x7f034eb18edd
Jun 29 08:16:59 archjaro kernel: RSP: 002b:00007f03210d5fb0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:16:59 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f03210d6110 RCX: 00007f034eb18edd
Jun 29 08:16:59 archjaro kernel: RDX: 00007f03210d6060 RSI: 00000000c0206440 RDI: 000000000000003c
Jun 29 08:16:59 archjaro kernel: RBP: 00007f03210d6000 R08: 00000000119ead40 R09: 72d1252a48819325
Jun 29 08:16:59 archjaro kernel: R10: 0000000000001007 R11: 0000000000000246 R12: 00007f03210d6060
Jun 29 08:16:59 archjaro kernel: R13: 00000000c0206440 R14: 000000000000003c R15: 00007f02f9020b30
Jun 29 08:16:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#14 stuck for 26s! [vo:7035]
Jun 29 08:16:59 archjaro kernel: CPU#14 Utilization every 4000ms during lockup:
Jun 29 08:16:59 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:16:59 archjaro kernel: CPU: 14 UID: 1000 PID: 7035 Comm: vo Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:59 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:16:59 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:16:59 archjaro kernel: RSP: 0018:ffffcd6fd2b23858 EFLAGS: 00000246
Jun 29 08:16:59 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:16:59 archjaro kernel: RDX: ffff8a83defb4140 RSI: 0000000000000000 RDI: 0000000000000001
Jun 29 08:16:59 archjaro kernel: RBP: ffff8a7d6efbb000 R08: 00000000003c0000 R09: ffff8a84406ea000
Jun 29 08:16:59 archjaro kernel: R10: 00000000003c0000 R11: ffff8a7cc0371d00 R12: ffff8a7ce1480000
Jun 29 08:16:59 archjaro kernel: FS:  00007fa85a9bb6c0(0000) GS:ffff8a84406ea000(0000) knlGS:0000000000000000
Jun 29 08:16:59 archjaro kernel: CR2: 000027dc00eff000 CR3: 000000020fc42000 CR4: 0000000000f50ef0
Jun 29 08:16:59 archjaro kernel:  ? drm_sched_entity_error+0x28/0x30 [gpu_sched 88f2198543191f36e763bec107fe4bd669170408]
Jun 29 08:16:59 archjaro kernel:  ? drm_exec_prepare_obj+0x3f/0x60 [drm_exec 1ef07484ba852eeb2df4f030e3c642b283f08d81]
Jun 29 08:16:59 archjaro kernel: RIP: 0033:0x7fa86fb18edd
Jun 29 08:16:59 archjaro kernel: RSP: 002b:00007fa85a9b1630 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:16:59 archjaro kernel: RAX: ffffffffffffffda RBX: 00007fa85a9b1838 RCX: 00007fa86fb18edd
Jun 29 08:16:59 archjaro kernel: RDX: 00007fa85a9b16c0 RSI: 00000000c0186444 RDI: 000000000000000b
Jun 29 08:16:59 archjaro kernel: RBP: 00007fa85a9b1680 R08: 00007fa8487e9ba0 R09: 00007fa85a9b1690
Jun 29 08:16:59 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000b
Jun 29 08:16:59 archjaro kernel: R13: 00007fa8480819d0 R14: 00007fa8487e9b50 R15: 00007fa84807a2b0
Jun 29 08:16:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#17 stuck for 26s! [kworker/u97:73:29723]
Jun 29 08:16:59 archjaro kernel: CPU#17 Utilization every 4000ms during lockup:
Jun 29 08:16:59 archjaro kernel: CPU: 17 UID: 0 PID: 29723 Comm: kworker/u97:73 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:16:59 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:16:59 archjaro kernel: RSP: 0018:ffffcd6fc198fb38 EFLAGS: 00000246
Jun 29 08:16:59 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7cdf172848 RCX: ffff8a7ce148f918
Jun 29 08:16:59 archjaro kernel: RDX: ffff8a83df074140 RSI: 0000000000000000 RDI: 000000000000000e
Jun 29 08:16:59 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000480000 R09: ffff8a84407aa000
Jun 29 08:16:59 archjaro kernel: R10: 0000000000480000 R11: ffff8a7eba210880 R12: 0000000000000000
Jun 29 08:16:59 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:16:59 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a84407aa000(0000) knlGS:0000000000000000
Jun 29 08:16:59 archjaro kernel: CR2: 0000183c06f62600 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:16:59 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:16:59 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:16:59 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:16:59 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:16:59 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:16:59 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:16:59 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:16:59 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:16:59 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:16:59 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:16:59 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:16:59 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:23 archjaro kernel: watchdog: BUG: soft lockup - CPU#15 stuck for 22s! [signal-desktop:2206]
Jun 29 08:17:23 archjaro kernel: CPU#15 Utilization every 4000ms during lockup:
Jun 29 08:17:23 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:23 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:23 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:23 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:23 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:23 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:23 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:23 archjaro kernel: CPU: 15 UID: 1000 PID: 2206 Comm: signal-desktop Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:23 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:23 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:23 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:23 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:23 archjaro kernel: RSP: 0018:ffffcd6fc73a3a40 EFLAGS: 00000246
Jun 29 08:17:23 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7d159b9dd0 RCX: ffff8a7ce148f918
Jun 29 08:17:23 archjaro kernel: RDX: ffff8a83deff4140 RSI: 0000000000000000 RDI: 0000000000000012
Jun 29 08:17:23 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000400000 R09: ffff8a844072a000
Jun 29 08:17:23 archjaro kernel: R10: 0000000000400000 R11: 0000000000000001 R12: ffff8a7d159b9c48
Jun 29 08:17:23 archjaro kernel: R13: ffff8a7d159b9d48 R14: ffffcd6fc73a3bd0 R15: 0000000000000024
Jun 29 08:17:23 archjaro kernel: FS:  00007f2869840500(0000) GS:ffff8a844072a000(0000) knlGS:0000000000000000
Jun 29 08:17:23 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:23 archjaro kernel: CR2: 000026140223cc00 CR3: 0000000101cba000 CR4: 0000000000f50ef0
Jun 29 08:17:23 archjaro kernel: PKRU: 55555558
Jun 29 08:17:23 archjaro kernel: Call Trace:
Jun 29 08:17:23 archjaro kernel:  <TASK>
Jun 29 08:17:23 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:23 archjaro kernel:  ? dma_resv_iter_next_unlocked+0x7c/0x90
Jun 29 08:17:23 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:23 archjaro kernel:  ttm_bo_release+0x201/0x330 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:23 archjaro kernel:  drm_gem_object_release_handle+0x7f/0xe0
Jun 29 08:17:23 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:17:23 archjaro kernel:  drm_gem_handle_delete+0x61/0xa0
Jun 29 08:17:23 archjaro kernel:  ? drm_dev_enter+0x1d/0x60
Jun 29 08:17:23 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:23 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:23 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:23 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:23 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:23 archjaro kernel:  ? mmap_region+0xeb/0x110
Jun 29 08:17:23 archjaro kernel:  ? __handle_mm_fault+0x9da/0xf80
Jun 29 08:17:23 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:17:23 archjaro kernel:  ? handle_mm_fault+0x1e5/0x2c0
Jun 29 08:17:23 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
Jun 29 08:17:23 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:23 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:17:23 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:23 archjaro kernel: RIP: 0033:0x7f286ad18edd
Jun 29 08:17:23 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:23 archjaro kernel: RSP: 002b:00007fff77498e30 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:23 archjaro kernel: RAX: ffffffffffffffda RBX: 000026140089c9c0 RCX: 00007f286ad18edd
Jun 29 08:17:23 archjaro kernel: RDX: 00007fff77498ec0 RSI: 0000000040086409 RDI: 0000000000000011
Jun 29 08:17:23 archjaro kernel: RBP: 00007fff77498e80 R08: ffff800103000000 R09: 0000000000000000
Jun 29 08:17:23 archjaro kernel: R10: 0000000000000024 R11: 0000000000000246 R12: 00007fff77498ec0
Jun 29 08:17:23 archjaro kernel: R13: 0000000040086409 R14: 0000000000000011 R15: 00002614001dc000
Jun 29 08:17:23 archjaro kernel:  </TASK>
Jun 29 08:17:25 archjaro kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 52s! [kworker/u97:104:29753]
Jun 29 08:17:25 archjaro kernel: CPU#0 Utilization every 4000ms during lockup:
Jun 29 08:17:25 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:25 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:25 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:25 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:25 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:25 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:25 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:25 archjaro kernel: CPU: 0 UID: 0 PID: 29753 Comm: kworker/u97:104 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:25 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:25 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:25 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:17:25 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x295/0x300
Jun 29 08:17:25 archjaro kernel: Code: 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 <8b> 01 66 85 c0 75 f7 44 39 c0 74 47 c6 01 01 48 85 f6 74 0e c7 46
Jun 29 08:17:25 archjaro kernel: RSP: 0018:ffffcd6fc1b0bb38 EFLAGS: 00000202
Jun 29 08:17:25 archjaro kernel: RAX: 0000000000100101 RBX: ffff8a7cced6e848 RCX: ffff8a7ce148f918
Jun 29 08:17:25 archjaro kernel: RDX: ffff8a83dec34140 RSI: 0000000000000000 RDI: 0000000000000000
Jun 29 08:17:25 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000040000 R09: ffff8a844036a000
Jun 29 08:17:25 archjaro kernel: R10: 0000000000040000 R11: ffff8a7ccd03d480 R12: 0000000000000000
Jun 29 08:17:25 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:17:25 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a844036a000(0000) knlGS:0000000000000000
Jun 29 08:17:25 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:25 archjaro kernel: CR2: 0000000800100670 CR3: 000000041d9ff000 CR4: 0000000000f50ef0
Jun 29 08:17:25 archjaro kernel: PKRU: 55555554
Jun 29 08:17:25 archjaro kernel: Call Trace:
Jun 29 08:17:25 archjaro kernel:  <TASK>
Jun 29 08:17:25 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:25 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:17:25 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:25 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:25 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:25 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:25 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:17:25 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:25 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:17:25 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:17:25 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:17:25 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:17:25 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:17:25 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:17:25 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:17:25 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:25 archjaro kernel:  </TASK>
Jun 29 08:17:27 archjaro kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 52s! [vivaldi-bi:cs0:6081]
Jun 29 08:17:27 archjaro kernel: CPU#2 Utilization every 4000ms during lockup:
Jun 29 08:17:27 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:27 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:27 archjaro kernel: CPU: 2 UID: 1000 PID: 6081 Comm: vivaldi-bi:cs0 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:27 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:27 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:27 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x300
Jun 29 08:17:27 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 9d 5a f8 01 e9 6b 68 bd fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Jun 29 08:17:27 archjaro kernel: RSP: 0018:ffffcd6fd1f93818 EFLAGS: 00000202
Jun 29 08:17:27 archjaro kernel: RAX: 0000000000000001 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:17:27 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a7ce148f918
Jun 29 08:17:27 archjaro kernel: RBP: ffff8a7dffc75000 R08: ffff8a7f62d52ba8 R09: ffff8a8007e06448
Jun 29 08:17:27 archjaro kernel: R10: ffffcd6fd1f93988 R11: ffff8a7cc0371700 R12: ffff8a7ce1480000
Jun 29 08:17:27 archjaro kernel: R13: ffff8a7ce1490e58 R14: ffff8a7ce1490870 R15: 00000003f2459000
Jun 29 08:17:27 archjaro kernel: FS:  00007f4010dff6c0(0000) GS:ffff8a84403ea000(0000) knlGS:0000000000000000
Jun 29 08:17:27 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:27 archjaro kernel: CR2: 0000183c07d7b600 CR3: 0000000118f96000 CR4: 0000000000f50ef0
Jun 29 08:17:27 archjaro kernel: PKRU: 55555558
Jun 29 08:17:27 archjaro kernel: Call Trace:
Jun 29 08:17:27 archjaro kernel:  <TASK>
Jun 29 08:17:27 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:27 archjaro kernel:  ttm_resource_manager_usage+0x2e/0x70 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x486/0x810 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  amdgpu_cs_ioctl+0xc06/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:27 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:27 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:27 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:27 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:27 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:17:27 archjaro kernel:  ? __x64_sys_futex+0x12a/0x220
Jun 29 08:17:27 archjaro kernel:  ? switch_fpu_return+0x5e/0x100
Jun 29 08:17:27 archjaro kernel:  ? do_syscall_64+0x282/0x640
Jun 29 08:17:27 archjaro kernel:  ? futex_wake+0xcc/0x240
Jun 29 08:17:27 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:27 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:27 archjaro kernel: RIP: 0033:0x7f4029718edd
Jun 29 08:17:27 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:27 archjaro kernel: RSP: 002b:00007f4010dfcb50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:27 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f4010dfce88 RCX: 00007f4029718edd
Jun 29 08:17:27 archjaro kernel: RDX: 00007f4010dfcbe0 RSI: 00000000c0186444 RDI: 0000000000000012
Jun 29 08:17:27 archjaro kernel: RBP: 00007f4010dfcba0 R08: 00007f4010dfcd20 R09: 00007f4010dfcbb0
Jun 29 08:17:27 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000012
Jun 29 08:17:27 archjaro kernel: R13: 00007f4010dfce88 R14: 0000000000000004 R15: 00000ff400720000
Jun 29 08:17:27 archjaro kernel:  </TASK>
Jun 29 08:17:27 archjaro kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 52s! [Renderer:2175]
Jun 29 08:17:27 archjaro kernel: CPU#13 Utilization every 4000ms during lockup:
Jun 29 08:17:27 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel: CPU: 13 UID: 1000 PID: 2175 Comm: Renderer Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:27 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:27 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:27 archjaro kernel: RSP: 0018:ffffcd6fc669f6f0 EFLAGS: 00000246
Jun 29 08:17:27 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a80fd7ad680 RCX: ffff8a7ce148f918
Jun 29 08:17:27 archjaro kernel: RDX: ffff8a83def74140 RSI: 0000000000000000 RDI: 000000000000000f
Jun 29 08:17:27 archjaro kernel: RBP: ffff8a7fe82e4448 R08: 0000000000380000 R09: ffff8a84406aa000
Jun 29 08:17:27 archjaro kernel: R10: 0000000000380000 R11: ffff8a7f7a2decd8 R12: ffff8a7ce1490870
Jun 29 08:17:27 archjaro kernel: R13: ffff8a7fe82e4408 R14: ffff8a80fd7ad680 R15: 00000003fa800000
Jun 29 08:17:27 archjaro kernel: FS:  00007f03210d86c0(0000) GS:ffff8a84406aa000(0000) knlGS:0000000000000000
Jun 29 08:17:27 archjaro kernel: CR2: 0000183c03582000 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:17:27 archjaro kernel: PKRU: 55555554
Jun 29 08:17:27 archjaro kernel:  ? __kmalloc_cache_noprof+0x135/0x480
Jun 29 08:17:27 archjaro kernel:  ? amdgpu_vram_mgr_new+0xad/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ttm_resource_init+0x6f/0x150 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  amdgpu_vram_mgr_new+0xc7/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? dmem_cgroup_try_charge+0x98/0x200
Jun 29 08:17:27 archjaro kernel:  ttm_resource_alloc+0x90/0x120 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  ttm_bo_alloc_resource+0x118/0x4d0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  ? add_hole+0x130/0x1b0
Jun 29 08:17:27 archjaro kernel:  ? drm_mm_insert_node_in_range+0x5f4/0x680
Jun 29 08:17:27 archjaro kernel:  ttm_bo_validate+0xaf/0x240 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  ttm_bo_init_reserved+0x15c/0x1e0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  amdgpu_bo_create+0x1de/0x520 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? __pfx_amdgpu_bo_user_destroy+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  amdgpu_bo_create_user+0x3d/0x70 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  amdgpu_gem_create_ioctl+0x17d/0x470 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? __pfx_amdgpu_gem_create_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:27 archjaro kernel:  ? drm_ioctl+0x30f/0x550
Jun 29 08:17:27 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:17:27 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Jun 29 08:17:27 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:17:27 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
Jun 29 08:17:27 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:17:27 archjaro kernel: RIP: 0033:0x7f034eb18edd
Jun 29 08:17:27 archjaro kernel: RSP: 002b:00007f03210d5fb0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:27 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f03210d6110 RCX: 00007f034eb18edd
Jun 29 08:17:27 archjaro kernel: RDX: 00007f03210d6060 RSI: 00000000c0206440 RDI: 000000000000003c
Jun 29 08:17:27 archjaro kernel: RBP: 00007f03210d6000 R08: 00000000119ead40 R09: 72d1252a48819325
Jun 29 08:17:27 archjaro kernel: R10: 0000000000001007 R11: 0000000000000246 R12: 00007f03210d6060
Jun 29 08:17:27 archjaro kernel: R13: 00000000c0206440 R14: 000000000000003c R15: 00007f02f9020b30
Jun 29 08:17:27 archjaro kernel: watchdog: BUG: soft lockup - CPU#14 stuck for 52s! [vo:7035]
Jun 29 08:17:27 archjaro kernel: CPU#14 Utilization every 4000ms during lockup:
Jun 29 08:17:27 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:27 archjaro kernel: CPU: 14 UID: 1000 PID: 7035 Comm: vo Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:27 archjaro kernel: RSP: 0018:ffffcd6fd2b23858 EFLAGS: 00000246
Jun 29 08:17:27 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:17:27 archjaro kernel: RDX: ffff8a83defb4140 RSI: 0000000000000000 RDI: 0000000000000001
Jun 29 08:17:27 archjaro kernel: RBP: ffff8a7d6efbb000 R08: 00000000003c0000 R09: ffff8a84406ea000
Jun 29 08:17:27 archjaro kernel: R10: 00000000003c0000 R11: ffff8a7cc0371d00 R12: ffff8a7ce1480000
Jun 29 08:17:27 archjaro kernel: FS:  00007fa85a9bb6c0(0000) GS:ffff8a84406ea000(0000) knlGS:0000000000000000
Jun 29 08:17:27 archjaro kernel: CR2: 000027dc00eff000 CR3: 000000020fc42000 CR4: 0000000000f50ef0
Jun 29 08:17:27 archjaro kernel:  ? drm_sched_entity_error+0x28/0x30 [gpu_sched 88f2198543191f36e763bec107fe4bd669170408]
Jun 29 08:17:27 archjaro kernel:  ? drm_exec_prepare_obj+0x3f/0x60 [drm_exec 1ef07484ba852eeb2df4f030e3c642b283f08d81]
Jun 29 08:17:27 archjaro kernel: RIP: 0033:0x7fa86fb18edd
Jun 29 08:17:27 archjaro kernel: RSP: 002b:00007fa85a9b1630 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:27 archjaro kernel: RAX: ffffffffffffffda RBX: 00007fa85a9b1838 RCX: 00007fa86fb18edd
Jun 29 08:17:27 archjaro kernel: RDX: 00007fa85a9b16c0 RSI: 00000000c0186444 RDI: 000000000000000b
Jun 29 08:17:27 archjaro kernel: RBP: 00007fa85a9b1680 R08: 00007fa8487e9ba0 R09: 00007fa85a9b1690
Jun 29 08:17:27 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000b
Jun 29 08:17:27 archjaro kernel: R13: 00007fa8480819d0 R14: 00007fa8487e9b50 R15: 00007fa84807a2b0
Jun 29 08:17:27 archjaro kernel: watchdog: BUG: soft lockup - CPU#17 stuck for 52s! [kworker/u97:73:29723]
Jun 29 08:17:27 archjaro kernel: CPU#17 Utilization every 4000ms during lockup:
Jun 29 08:17:27 archjaro kernel: CPU: 17 UID: 0 PID: 29723 Comm: kworker/u97:73 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:27 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:17:27 archjaro kernel: RSP: 0018:ffffcd6fc198fb38 EFLAGS: 00000246
Jun 29 08:17:27 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7cdf172848 RCX: ffff8a7ce148f918
Jun 29 08:17:27 archjaro kernel: RDX: ffff8a83df074140 RSI: 0000000000000000 RDI: 000000000000000e
Jun 29 08:17:27 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000480000 R09: ffff8a84407aa000
Jun 29 08:17:27 archjaro kernel: R10: 0000000000480000 R11: ffff8a7eba210880 R12: 0000000000000000
Jun 29 08:17:27 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:17:27 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a84407aa000(0000) knlGS:0000000000000000
Jun 29 08:17:27 archjaro kernel: CR2: 0000183c06f62600 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:17:27 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:17:27 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:27 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:17:27 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:27 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:17:27 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:17:27 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:17:27 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:17:27 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:17:27 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:17:27 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:17:27 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:31 archjaro kernel: rcu: INFO: rcu_preempt self-detected stall on CPU
Jun 29 08:17:31 archjaro kernel: rcu:         2-...!: (59997 ticks this GP) idle=9484/1/0x4000000000000000 softirq=1922188/1922188 fqs=1
Jun 29 08:17:31 archjaro kernel: rcu:         (t=60001 jiffies g=5567921 q=7799 ncpus=24)
Jun 29 08:17:31 archjaro kernel: rcu: rcu_preempt kthread starved for 59997 jiffies! g5567921 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=13
Jun 29 08:17:31 archjaro kernel: rcu:         Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
Jun 29 08:17:31 archjaro kernel: rcu: RCU grace-period kthread stack dump:
Jun 29 08:17:31 archjaro kernel: task:rcu_preempt     state:R  running task     stack:0     pid:16    tgid:16    ppid:2      task_flags:0x208040 flags:0x00080000
Jun 29 08:17:31 archjaro kernel: Call Trace:
Jun 29 08:17:31 archjaro kernel:  <TASK>
Jun 29 08:17:31 archjaro kernel:  ? __pfx_rcu_gp_kthread+0x10/0x10
Jun 29 08:17:31 archjaro kernel:  __schedule+0x457/0x1860
Jun 29 08:17:31 archjaro kernel:  ? sysvec_reschedule_ipi+0x2c/0x120
Jun 29 08:17:31 archjaro kernel:  ? lock_timer_base+0x70/0x90
Jun 29 08:17:31 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:31 archjaro kernel:  ? __mod_timer+0x242/0x3a0
Jun 29 08:17:31 archjaro kernel:  schedule+0x27/0xd0
Jun 29 08:17:31 archjaro kernel:  schedule_timeout+0xa3/0x120
Jun 29 08:17:31 archjaro kernel:  ? __pfx_process_timeout+0x10/0x10
Jun 29 08:17:31 archjaro kernel:  rcu_gp_fqs_loop+0xf4/0x440
Jun 29 08:17:31 archjaro kernel:  rcu_gp_kthread+0x90/0x120
Jun 29 08:17:31 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:17:31 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:17:31 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:17:31 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:31 archjaro kernel:  </TASK>
Jun 29 08:17:31 archjaro kernel: rcu: Stack dump where RCU GP kthread last ran:
Jun 29 08:17:31 archjaro kernel: Sending NMI from CPU 2 to CPUs 13:
Jun 29 08:17:31 archjaro kernel: NMI backtrace for cpu 13
Jun 29 08:17:31 archjaro kernel: CPU: 13 UID: 1000 PID: 2175 Comm: Renderer Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:31 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:31 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:31 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x27f/0x300
Jun 29 08:17:31 archjaro kernel: Code: c1 ef 12 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 <8b> 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90
Jun 29 08:17:31 archjaro kernel: RSP: 0018:ffffcd6fc669f6f0 EFLAGS: 00000246
Jun 29 08:17:31 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a80fd7ad680 RCX: ffff8a7ce148f918
Jun 29 08:17:31 archjaro kernel: RDX: ffff8a83def74140 RSI: 0000000000000000 RDI: 000000000000000f
Jun 29 08:17:31 archjaro kernel: RBP: ffff8a7fe82e4448 R08: 0000000000380000 R09: ffff8a84406aa000
Jun 29 08:17:31 archjaro kernel: R10: 0000000000380000 R11: ffff8a7f7a2decd8 R12: ffff8a7ce1490870
Jun 29 08:17:31 archjaro kernel: R13: ffff8a7fe82e4408 R14: ffff8a80fd7ad680 R15: 00000003fa800000
Jun 29 08:17:31 archjaro kernel: FS:  00007f03210d86c0(0000) GS:ffff8a84406aa000(0000) knlGS:0000000000000000
Jun 29 08:17:31 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:31 archjaro kernel: CR2: 0000183c03582000 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:17:31 archjaro kernel: PKRU: 55555554
Jun 29 08:17:31 archjaro kernel:  ? __kmalloc_cache_noprof+0x135/0x480
Jun 29 08:17:31 archjaro kernel:  ? amdgpu_vram_mgr_new+0xad/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:31 archjaro kernel:  ttm_resource_init+0x6f/0x150 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  amdgpu_vram_mgr_new+0xc7/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? dmem_cgroup_try_charge+0x98/0x200
Jun 29 08:17:31 archjaro kernel:  ttm_resource_alloc+0x90/0x120 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  ttm_bo_alloc_resource+0x118/0x4d0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  ? add_hole+0x130/0x1b0
Jun 29 08:17:31 archjaro kernel:  ? drm_mm_insert_node_in_range+0x5f4/0x680
Jun 29 08:17:31 archjaro kernel:  ttm_bo_validate+0xaf/0x240 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  ttm_bo_init_reserved+0x15c/0x1e0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  amdgpu_bo_create+0x1de/0x520 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? __pfx_amdgpu_bo_user_destroy+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  amdgpu_bo_create_user+0x3d/0x70 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  amdgpu_gem_create_ioctl+0x17d/0x470 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? __pfx_amdgpu_gem_create_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:31 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:31 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:31 archjaro kernel:  ? drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:31 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:31 archjaro kernel:  ? drm_ioctl+0x30f/0x550
Jun 29 08:17:31 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:17:31 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Jun 29 08:17:31 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:17:31 archjaro kernel:  ? __x64_sys_futex+0x12a/0x220
Jun 29 08:17:31 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:17:31 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
Jun 29 08:17:31 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:31 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:17:31 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:31 archjaro kernel: RIP: 0033:0x7f034eb18edd
Jun 29 08:17:31 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:31 archjaro kernel: RSP: 002b:00007f03210d5fb0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:31 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f03210d6110 RCX: 00007f034eb18edd
Jun 29 08:17:31 archjaro kernel: RDX: 00007f03210d6060 RSI: 00000000c0206440 RDI: 000000000000003c
Jun 29 08:17:31 archjaro kernel: RBP: 00007f03210d6000 R08: 00000000119ead40 R09: 72d1252a48819325
Jun 29 08:17:31 archjaro kernel: R10: 0000000000001007 R11: 0000000000000246 R12: 00007f03210d6060
Jun 29 08:17:31 archjaro kernel: R13: 00000000c0206440 R14: 000000000000003c R15: 00007f02f9020b30
Jun 29 08:17:31 archjaro kernel: INFO: NMI handler (nmi_cpu_backtrace_handler) took too long to run: 2.365 msecs
Jun 29 08:17:31 archjaro kernel: CPU: 2 UID: 1000 PID: 6081 Comm: vivaldi-bi:cs0 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:31 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x300
Jun 29 08:17:31 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 9d 5a f8 01 e9 6b 68 bd fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Jun 29 08:17:31 archjaro kernel: RSP: 0018:ffffcd6fd1f93818 EFLAGS: 00000202
Jun 29 08:17:31 archjaro kernel: RAX: 0000000000000001 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:17:31 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a7ce148f918
Jun 29 08:17:31 archjaro kernel: RBP: ffff8a7dffc75000 R08: ffff8a7f62d52ba8 R09: ffff8a8007e06448
Jun 29 08:17:31 archjaro kernel: R10: ffffcd6fd1f93988 R11: ffff8a7cc0371700 R12: ffff8a7ce1480000
Jun 29 08:17:31 archjaro kernel: R13: ffff8a7ce1490e58 R14: ffff8a7ce1490870 R15: 00000003f2459000
Jun 29 08:17:31 archjaro kernel: FS:  00007f4010dff6c0(0000) GS:ffff8a84403ea000(0000) knlGS:0000000000000000
Jun 29 08:17:31 archjaro kernel: CR2: 0000183c07d7b600 CR3: 0000000118f96000 CR4: 0000000000f50ef0
Jun 29 08:17:31 archjaro kernel: PKRU: 55555558
Jun 29 08:17:31 archjaro kernel:  ttm_resource_manager_usage+0x2e/0x70 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:31 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x486/0x810 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  amdgpu_cs_ioctl+0xc06/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:31 archjaro kernel:  ? switch_fpu_return+0x5e/0x100
Jun 29 08:17:31 archjaro kernel:  ? do_syscall_64+0x282/0x640
Jun 29 08:17:31 archjaro kernel:  ? futex_wake+0xcc/0x240
Jun 29 08:17:31 archjaro kernel: RIP: 0033:0x7f4029718edd
Jun 29 08:17:31 archjaro kernel: RSP: 002b:00007f4010dfcb50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:31 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f4010dfce88 RCX: 00007f4029718edd
Jun 29 08:17:31 archjaro kernel: RDX: 00007f4010dfcbe0 RSI: 00000000c0186444 RDI: 0000000000000012
Jun 29 08:17:31 archjaro kernel: RBP: 00007f4010dfcba0 R08: 00007f4010dfcd20 R09: 00007f4010dfcbb0
Jun 29 08:17:31 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000012
Jun 29 08:17:31 archjaro kernel: R13: 00007f4010dfce88 R14: 0000000000000004 R15: 00000ff400720000
Jun 29 08:17:35 archjaro kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [brave:1769]
Jun 29 08:17:35 archjaro kernel: CPU#3 Utilization every 4000ms during lockup:
Jun 29 08:17:35 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:35 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:35 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:35 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:35 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:35 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:35 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:35 archjaro kernel: CPU: 3 UID: 1000 PID: 1769 Comm: brave Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:35 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:35 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:35 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:35 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:35 archjaro kernel: RSP: 0018:ffffcd6fc5e4fae8 EFLAGS: 00000246
Jun 29 08:17:35 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7f9eac2c48 RCX: ffff8a7ce148f918
Jun 29 08:17:35 archjaro kernel: RDX: ffff8a83decf4140 RSI: 0000000000000000 RDI: 0000000000000010
Jun 29 08:17:35 archjaro kernel: RBP: 0000000000000000 R08: 0000000000100000 R09: ffff8a844042a000
Jun 29 08:17:35 archjaro kernel: R10: 0000000000100000 R11: ffff8a7cc0042700 R12: ffff8a7ee7a0f600
Jun 29 08:17:35 archjaro kernel: R13: ffffffffc08284e0 R14: ffff8a7ce148ed90 R15: 00000000c1206446
Jun 29 08:17:35 archjaro kernel: FS:  00007f6c2085f640(0000) GS:ffff8a844042a000(0000) knlGS:0000000000000000
Jun 29 08:17:35 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:35 archjaro kernel: CR2: 00007f6c1b568080 CR3: 000000011645f000 CR4: 0000000000f50ef0
Jun 29 08:17:35 archjaro kernel: PKRU: 55555558
Jun 29 08:17:35 archjaro kernel: Call Trace:
Jun 29 08:17:35 archjaro kernel:  <TASK>
Jun 29 08:17:35 archjaro kernel:  ? amdgpu_bo_set_metadata+0x57/0xc0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:35 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:35 archjaro kernel:  amdgpu_gem_metadata_ioctl+0xbc/0x1e0 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:35 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:35 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:35 archjaro kernel:  ? __pfx_amdgpu_gem_metadata_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:35 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:35 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:35 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:35 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:35 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:17:35 archjaro kernel:  ? mmap_region+0xeb/0x110
Jun 29 08:17:35 archjaro kernel:  ? vm_mmap_pgoff+0x15e/0x210
Jun 29 08:17:35 archjaro kernel:  ? ksys_mmap_pgoff+0x168/0x200
Jun 29 08:17:35 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:35 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:17:35 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:35 archjaro kernel: RIP: 0033:0x7f6c21118edd
Jun 29 08:17:35 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:35 archjaro kernel: RSP: 002b:00007ffe6f35e190 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:35 archjaro kernel: RAX: ffffffffffffffda RBX: 0000000000000015 RCX: 00007f6c21118edd
Jun 29 08:17:35 archjaro kernel: RDX: 00007ffe6f35e1f0 RSI: 00000000c1206446 RDI: 0000000000000015
Jun 29 08:17:35 archjaro kernel: RBP: 00007ffe6f35e1e0 R08: 00007ffe6f35e4ec R09: 00007ffe6f35e4f0
Jun 29 08:17:35 archjaro kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 000000dc0004dd60
Jun 29 08:17:35 archjaro kernel: R13: 000000000000001e R14: 000000dc0405b0e0 R15: 0000000000000000
Jun 29 08:17:35 archjaro kernel:  </TASK>
Jun 29 08:17:51 archjaro kernel: watchdog: BUG: soft lockup - CPU#15 stuck for 48s! [signal-desktop:2206]
Jun 29 08:17:51 archjaro kernel: CPU#15 Utilization every 4000ms during lockup:
Jun 29 08:17:51 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:51 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:51 archjaro kernel:         #3: 100% system,          1% softirq,          0% hardirq,          0% idle
Jun 29 08:17:51 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:51 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:51 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:51 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:51 archjaro kernel: CPU: 15 UID: 1000 PID: 2206 Comm: signal-desktop Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:51 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:51 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:51 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:51 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:51 archjaro kernel: RSP: 0018:ffffcd6fc73a3a40 EFLAGS: 00000246
Jun 29 08:17:51 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7d159b9dd0 RCX: ffff8a7ce148f918
Jun 29 08:17:51 archjaro kernel: RDX: ffff8a83deff4140 RSI: 0000000000000000 RDI: 0000000000000012
Jun 29 08:17:51 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000400000 R09: ffff8a844072a000
Jun 29 08:17:51 archjaro kernel: R10: 0000000000400000 R11: 0000000000000001 R12: ffff8a7d159b9c48
Jun 29 08:17:51 archjaro kernel: R13: ffff8a7d159b9d48 R14: ffffcd6fc73a3bd0 R15: 0000000000000024
Jun 29 08:17:51 archjaro kernel: FS:  00007f2869840500(0000) GS:ffff8a844072a000(0000) knlGS:0000000000000000
Jun 29 08:17:51 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:51 archjaro kernel: CR2: 000026140223cc00 CR3: 0000000101cba000 CR4: 0000000000f50ef0
Jun 29 08:17:51 archjaro kernel: PKRU: 55555558
Jun 29 08:17:51 archjaro kernel: Call Trace:
Jun 29 08:17:51 archjaro kernel:  <TASK>
Jun 29 08:17:51 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:51 archjaro kernel:  ? dma_resv_iter_next_unlocked+0x7c/0x90
Jun 29 08:17:51 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:51 archjaro kernel:  ttm_bo_release+0x201/0x330 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:51 archjaro kernel:  drm_gem_object_release_handle+0x7f/0xe0
Jun 29 08:17:51 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:17:51 archjaro kernel:  drm_gem_handle_delete+0x61/0xa0
Jun 29 08:17:51 archjaro kernel:  ? drm_dev_enter+0x1d/0x60
Jun 29 08:17:51 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:51 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:51 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:51 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:51 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:51 archjaro kernel:  ? mmap_region+0xeb/0x110
Jun 29 08:17:51 archjaro kernel:  ? __handle_mm_fault+0x9da/0xf80
Jun 29 08:17:51 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:17:51 archjaro kernel:  ? handle_mm_fault+0x1e5/0x2c0
Jun 29 08:17:51 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
Jun 29 08:17:51 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:51 archjaro kernel:  ? exc_page_fault+0x90/0x1f0
Jun 29 08:17:51 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:51 archjaro kernel: RIP: 0033:0x7f286ad18edd
Jun 29 08:17:51 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:51 archjaro kernel: RSP: 002b:00007fff77498e30 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:51 archjaro kernel: RAX: ffffffffffffffda RBX: 000026140089c9c0 RCX: 00007f286ad18edd
Jun 29 08:17:51 archjaro kernel: RDX: 00007fff77498ec0 RSI: 0000000040086409 RDI: 0000000000000011
Jun 29 08:17:51 archjaro kernel: RBP: 00007fff77498e80 R08: ffff800103000000 R09: 0000000000000000
Jun 29 08:17:51 archjaro kernel: R10: 0000000000000024 R11: 0000000000000246 R12: 00007fff77498ec0
Jun 29 08:17:51 archjaro kernel: R13: 0000000040086409 R14: 0000000000000011 R15: 00002614001dc000
Jun 29 08:17:51 archjaro kernel:  </TASK>
Jun 29 08:17:53 archjaro kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 78s! [kworker/u97:104:29753]
Jun 29 08:17:53 archjaro kernel: CPU#0 Utilization every 4000ms during lockup:
Jun 29 08:17:53 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:53 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:53 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:53 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:53 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:53 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:53 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:53 archjaro kernel: CPU: 0 UID: 0 PID: 29753 Comm: kworker/u97:104 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:53 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:53 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:53 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:17:53 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x297/0x300
Jun 29 08:17:53 archjaro kernel: Code: 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 <66> 85 c0 75 f7 44 39 c0 74 47 c6 01 01 48 85 f6 74 0e c7 46 08 01
Jun 29 08:17:53 archjaro kernel: RSP: 0018:ffffcd6fc1b0bb38 EFLAGS: 00000202
Jun 29 08:17:53 archjaro kernel: RAX: 0000000000100101 RBX: ffff8a7cced6e848 RCX: ffff8a7ce148f918
Jun 29 08:17:53 archjaro kernel: RDX: ffff8a83dec34140 RSI: 0000000000000000 RDI: 0000000000000000
Jun 29 08:17:53 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000040000 R09: ffff8a844036a000
Jun 29 08:17:53 archjaro kernel: R10: 0000000000040000 R11: ffff8a7ccd03d480 R12: 0000000000000000
Jun 29 08:17:53 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:17:53 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a844036a000(0000) knlGS:0000000000000000
Jun 29 08:17:53 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:53 archjaro kernel: CR2: 0000000800100670 CR3: 000000041d9ff000 CR4: 0000000000f50ef0
Jun 29 08:17:53 archjaro kernel: PKRU: 55555554
Jun 29 08:17:53 archjaro kernel: Call Trace:
Jun 29 08:17:53 archjaro kernel:  <TASK>
Jun 29 08:17:53 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:53 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:17:53 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:53 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:53 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:53 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:53 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:17:53 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:53 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:17:53 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:17:53 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:17:53 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:17:53 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:17:53 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:17:53 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:17:53 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:53 archjaro kernel:  </TASK>
Jun 29 08:17:55 archjaro kernel: watchdog: BUG: soft lockup - CPU#14 stuck for 78s! [vo:7035]
Jun 29 08:17:55 archjaro kernel: CPU#14 Utilization every 4000ms during lockup:
Jun 29 08:17:55 archjaro kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:55 archjaro kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:55 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:55 archjaro kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:55 archjaro kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:55 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:55 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:55 archjaro kernel: CPU: 14 UID: 1000 PID: 7035 Comm: vo Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:55 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:55 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:55 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x27f/0x300
Jun 29 08:17:55 archjaro kernel: Code: c1 ef 12 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 <8b> 42 08 85 c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90
Jun 29 08:17:55 archjaro kernel: RSP: 0018:ffffcd6fd2b23858 EFLAGS: 00000246
Jun 29 08:17:55 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:17:55 archjaro kernel: RDX: ffff8a83defb4140 RSI: 0000000000000000 RDI: 0000000000000001
Jun 29 08:17:55 archjaro kernel: RBP: ffff8a7d6efbb000 R08: 00000000003c0000 R09: ffff8a84406ea000
Jun 29 08:17:55 archjaro kernel: R10: 00000000003c0000 R11: ffff8a7cc0371d00 R12: ffff8a7ce1480000
Jun 29 08:17:55 archjaro kernel: R13: ffff8a7ce1490e58 R14: ffff8a7ce1490870 R15: 00000003f2459000
Jun 29 08:17:55 archjaro kernel: FS:  00007fa85a9bb6c0(0000) GS:ffff8a84406ea000(0000) knlGS:0000000000000000
Jun 29 08:17:55 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:55 archjaro kernel: CR2: 000027dc00eff000 CR3: 000000020fc42000 CR4: 0000000000f50ef0
Jun 29 08:17:55 archjaro kernel: PKRU: 55555554
Jun 29 08:17:55 archjaro kernel: Call Trace:
Jun 29 08:17:55 archjaro kernel:  <TASK>
Jun 29 08:17:55 archjaro kernel:  ? drm_sched_entity_error+0x28/0x30 [gpu_sched 88f2198543191f36e763bec107fe4bd669170408]
Jun 29 08:17:55 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:55 archjaro kernel:  ? drm_exec_prepare_obj+0x3f/0x60 [drm_exec 1ef07484ba852eeb2df4f030e3c642b283f08d81]
Jun 29 08:17:55 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:55 archjaro kernel:  ttm_resource_manager_usage+0x2e/0x70 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:55 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x486/0x810 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  amdgpu_cs_ioctl+0xc06/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:55 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:55 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:55 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:55 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Jun 29 08:17:55 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:17:55 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:55 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:55 archjaro kernel: RIP: 0033:0x7fa86fb18edd
Jun 29 08:17:55 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:55 archjaro kernel: RSP: 002b:00007fa85a9b1630 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:55 archjaro kernel: RAX: ffffffffffffffda RBX: 00007fa85a9b1838 RCX: 00007fa86fb18edd
Jun 29 08:17:55 archjaro kernel: RDX: 00007fa85a9b16c0 RSI: 00000000c0186444 RDI: 000000000000000b
Jun 29 08:17:55 archjaro kernel: RBP: 00007fa85a9b1680 R08: 00007fa8487e9ba0 R09: 00007fa85a9b1690
Jun 29 08:17:55 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000b
Jun 29 08:17:55 archjaro kernel: R13: 00007fa8480819d0 R14: 00007fa8487e9b50 R15: 00007fa84807a2b0
Jun 29 08:17:55 archjaro kernel:  </TASK>
Jun 29 08:17:55 archjaro kernel: watchdog: BUG: soft lockup - CPU#17 stuck for 78s! [kworker/u97:73:29723]
Jun 29 08:17:55 archjaro kernel: CPU#17 Utilization every 4000ms during lockup:
Jun 29 08:17:55 archjaro kernel: CPU: 17 UID: 0 PID: 29723 Comm: kworker/u97:73 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:55 archjaro kernel: Workqueue: events_unbound commit_work
Jun 29 08:17:55 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:55 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:55 archjaro kernel: RSP: 0018:ffffcd6fc198fb38 EFLAGS: 00000246
Jun 29 08:17:55 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a7cdf172848 RCX: ffff8a7ce148f918
Jun 29 08:17:55 archjaro kernel: RDX: ffff8a83df074140 RSI: 0000000000000000 RDI: 000000000000000e
Jun 29 08:17:55 archjaro kernel: RBP: ffff8a7ce148ed90 R08: 0000000000480000 R09: ffff8a84407aa000
Jun 29 08:17:55 archjaro kernel: R10: 0000000000480000 R11: ffff8a7eba210880 R12: 0000000000000000
Jun 29 08:17:55 archjaro kernel: R13: 0000000000000246 R14: ffff8a7ce148ed90 R15: 00000000000000e0
Jun 29 08:17:55 archjaro kernel: FS:  0000000000000000(0000) GS:ffff8a84407aa000(0000) knlGS:0000000000000000
Jun 29 08:17:55 archjaro kernel: CR2: 0000183c06f62600 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:17:55 archjaro kernel:  ? wait_for_completion_timeout+0x12d/0x180
Jun 29 08:17:55 archjaro kernel:  ttm_bo_unpin+0x34/0x80 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:55 archjaro kernel:  amdgpu_bo_unpin+0x1e/0x90 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  amdgpu_dm_plane_helper_cleanup_fb+0x6b/0x110 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  drm_atomic_helper_cleanup_planes+0x4a/0x70
Jun 29 08:17:55 archjaro kernel:  amdgpu_dm_atomic_commit_tail+0x2a65/0x3990 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:55 archjaro kernel:  commit_tail+0xc1/0x160
Jun 29 08:17:55 archjaro kernel:  process_one_work+0x19c/0x390
Jun 29 08:17:55 archjaro kernel:  worker_thread+0x1b1/0x310
Jun 29 08:17:55 archjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 29 08:17:55 archjaro kernel:  kthread+0xe1/0x120
Jun 29 08:17:55 archjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 29 08:17:55 archjaro kernel:  ret_from_fork+0x2a7/0x330
Jun 29 08:17:55 archjaro kernel:  ret_from_fork_asm+0x1a/0x30
Jun 29 08:17:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 82s! [vivaldi-bi:cs0:6081]
Jun 29 08:17:59 archjaro kernel: CPU#2 Utilization every 4000ms during lockup:
Jun 29 08:17:59 archjaro kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device wireguard libcurve25519 ip6_udp_tunnel udp_tunnel 8021q garp mrp stp llc nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink vfat fat iwlmvm mac80211 libarc4 btusb btmtk iwlwifi btrtl btbcm btintel hid_logitech_hidpp bluetooth cfg80211 igc ptp rfkill pps_core snd_hda_codec_alc882 snd_hda_codec_realtek_lib snd_hda_codec_atihdmi snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_intel amd_atl jc42 snd_hda_codec intel_rapl_msr snd_hda_core intel_rapl_common snd_intel_dspcfg ee1004 amd64_edac snd_intel_sdw_acpi snd_hwdep aesni_intel gf128mul hid_logitech_dj snd_pcm aead sp5100_tco mousedev rapl wmi_bmof snd_timer gigabyte_wmi joydev pcspkr snd soundcore ccp i2c_piix4 k10temp i2c_smbus mac_hid it87 crypto_user hwmon_vid i2c_dev xfs amdgpu drm_buddy amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec
Jun 29 08:17:59 archjaro kernel:  drm_panel_backlight_quirks gpu_sched drm_suballoc_helper video nvme drm_display_helper cec nvme_core nvme_keyring wmi nvme_auth
Jun 29 08:17:59 archjaro kernel: CPU: 2 UID: 1000 PID: 6081 Comm: vivaldi-bi:cs0 Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:59 archjaro kernel: Tainted: [D]=DIE, [L]=SOFTLOCKUP
Jun 29 08:17:59 archjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. X570S AORUS MASTER/X570S AORUS MASTER, BIOS F4 12/26/2022
Jun 29 08:17:59 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x75/0x300
Jun 29 08:17:59 archjaro kernel: Code: 08 30 e4 09 d0 3d ff 00 00 00 77 4e 85 c0 75 17 bf 01 00 00 00 66 89 39 65 48 ff 05 9d 5a f8 01 e9 6b 68 bd fe f3 90 80 39 00 <75> f9 eb e2 8b 37 b8 00 02 00 00 81 fe 00 01 00 00 74 07 eb aa 83
Jun 29 08:17:59 archjaro kernel: RSP: 0018:ffffcd6fd1f93818 EFLAGS: 00000202
Jun 29 08:17:59 archjaro kernel: RAX: 0000000000000001 RBX: ffff8a7ce1490870 RCX: ffff8a7ce148f918
Jun 29 08:17:59 archjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a7ce148f918
Jun 29 08:17:59 archjaro kernel: RBP: ffff8a7dffc75000 R08: ffff8a7f62d52ba8 R09: ffff8a8007e06448
Jun 29 08:17:59 archjaro kernel: R10: ffffcd6fd1f93988 R11: ffff8a7cc0371700 R12: ffff8a7ce1480000
Jun 29 08:17:59 archjaro kernel: R13: ffff8a7ce1490e58 R14: ffff8a7ce1490870 R15: 00000003f2459000
Jun 29 08:17:59 archjaro kernel: FS:  00007f4010dff6c0(0000) GS:ffff8a84403ea000(0000) knlGS:0000000000000000
Jun 29 08:17:59 archjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 29 08:17:59 archjaro kernel: CR2: 0000183c07d7b600 CR3: 0000000118f96000 CR4: 0000000000f50ef0
Jun 29 08:17:59 archjaro kernel: PKRU: 55555558
Jun 29 08:17:59 archjaro kernel: Call Trace:
Jun 29 08:17:59 archjaro kernel:  <TASK>
Jun 29 08:17:59 archjaro kernel:  _raw_spin_lock+0x29/0x30
Jun 29 08:17:59 archjaro kernel:  ttm_resource_manager_usage+0x2e/0x70 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  amdgpu_cs_parser_bos.isra.0+0x486/0x810 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  amdgpu_cs_ioctl+0xc06/0x1b30 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? __pfx_amdgpu_cs_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:59 archjaro kernel:  drm_ioctl+0x2d8/0x550
Jun 29 08:17:59 archjaro kernel:  amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  __x64_sys_ioctl+0xb9/0x100
Jun 29 08:17:59 archjaro kernel:  do_syscall_64+0xe1/0x640
Jun 29 08:17:59 archjaro kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Jun 29 08:17:59 archjaro kernel:  ? do_syscall_64+0xe1/0x640
Jun 29 08:17:59 archjaro kernel:  ? __x64_sys_futex+0x12a/0x220
Jun 29 08:17:59 archjaro kernel:  ? switch_fpu_return+0x5e/0x100
Jun 29 08:17:59 archjaro kernel:  ? do_syscall_64+0x282/0x640
Jun 29 08:17:59 archjaro kernel:  ? futex_wake+0xcc/0x240
Jun 29 08:17:59 archjaro kernel:  ? do_syscall_64+0x98/0x640
Jun 29 08:17:59 archjaro kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jun 29 08:17:59 archjaro kernel: RIP: 0033:0x7f4029718edd
Jun 29 08:17:59 archjaro kernel: Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
Jun 29 08:17:59 archjaro kernel: RSP: 002b:00007f4010dfcb50 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jun 29 08:17:59 archjaro kernel: RAX: ffffffffffffffda RBX: 00007f4010dfce88 RCX: 00007f4029718edd
Jun 29 08:17:59 archjaro kernel: RDX: 00007f4010dfcbe0 RSI: 00000000c0186444 RDI: 0000000000000012
Jun 29 08:17:59 archjaro kernel: RBP: 00007f4010dfcba0 R08: 00007f4010dfcd20 R09: 00007f4010dfcbb0
Jun 29 08:17:59 archjaro kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000012
Jun 29 08:17:59 archjaro kernel: R13: 00007f4010dfce88 R14: 0000000000000004 R15: 00000ff400720000
Jun 29 08:17:59 archjaro kernel:  </TASK>
Jun 29 08:17:59 archjaro kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 82s! [Renderer:2175]
Jun 29 08:17:59 archjaro kernel: CPU#13 Utilization every 4000ms during lockup:
Jun 29 08:17:59 archjaro kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Jun 29 08:17:59 archjaro kernel: CPU: 13 UID: 1000 PID: 2175 Comm: Renderer Tainted: G      D      L      7.1.1-3-MANJARO #1 PREEMPT(full)  4881901faee9ae5f905ed543be76f48fc6c2d91d
Jun 29 08:17:59 archjaro kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x282/0x300
Jun 29 08:17:59 archjaro kernel: Code: 83 e0 03 8d 77 ff 48 c1 e0 05 48 63 f6 48 05 40 a1 8c 9e 48 03 04 f5 e0 20 34 9d 48 89 10 8b 72 08 85 f6 75 09 f3 90 8b 42 08 <85> c0 74 f7 48 8b 32 48 85 f6 74 07 0f 0d 0e eb 02 f3 90 8b 01 66
Jun 29 08:17:59 archjaro kernel: RSP: 0018:ffffcd6fc669f6f0 EFLAGS: 00000246
Jun 29 08:17:59 archjaro kernel: RAX: 0000000000000000 RBX: ffff8a80fd7ad680 RCX: ffff8a7ce148f918
Jun 29 08:17:59 archjaro kernel: RDX: ffff8a83def74140 RSI: 0000000000000000 RDI: 000000000000000f
Jun 29 08:17:59 archjaro kernel: RBP: ffff8a7fe82e4448 R08: 0000000000380000 R09: ffff8a84406aa000
Jun 29 08:17:59 archjaro kernel: R10: 0000000000380000 R11: ffff8a7f7a2decd8 R12: ffff8a7ce1490870
Jun 29 08:17:59 archjaro kernel: R13: ffff8a7fe82e4408 R14: ffff8a80fd7ad680 R15: 00000003fa800000
Jun 29 08:17:59 archjaro kernel: FS:  00007f03210d86c0(0000) GS:ffff8a84406aa000(0000) knlGS:0000000000000000
Jun 29 08:17:59 archjaro kernel: CR2: 0000183c03582000 CR3: 000000012399a000 CR4: 0000000000f50ef0
Jun 29 08:17:59 archjaro kernel: PKRU: 55555554
Jun 29 08:17:59 archjaro kernel:  ? __kmalloc_cache_noprof+0x135/0x480
Jun 29 08:17:59 archjaro kernel:  ? amdgpu_vram_mgr_new+0xad/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ttm_resource_init+0x6f/0x150 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  amdgpu_vram_mgr_new+0xc7/0x700 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? dmem_cgroup_try_charge+0x98/0x200
Jun 29 08:17:59 archjaro kernel:  ttm_resource_alloc+0x90/0x120 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  ttm_bo_alloc_resource+0x118/0x4d0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  ? add_hole+0x130/0x1b0
Jun 29 08:17:59 archjaro kernel:  ? drm_mm_insert_node_in_range+0x5f4/0x680
Jun 29 08:17:59 archjaro kernel:  ttm_bo_validate+0xaf/0x240 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  ttm_bo_init_reserved+0x15c/0x1e0 [ttm 6ef3629219a246950a208b6696807eecb40cae89]
Jun 29 08:17:59 archjaro kernel:  amdgpu_bo_create+0x1de/0x520 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? __pfx_amdgpu_bo_user_destroy+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  amdgpu_bo_create_user+0x3d/0x70 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  amdgpu_gem_create_ioctl+0x17d/0x470 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? __pfx_amdgpu_gem_create_ioctl+0x10/0x10 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? drm_ioctl_kernel+0xae/0x100
Jun 29 08:17:59 archjaro kernel:  ? drm_ioctl+0x30f/0x550
Jun 29 08:17:59 archjaro kernel:  ? __pfx_drm_gem_close_ioctl+0x10/0x10
Jun 29 08:17:59 archjaro kernel:  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 7b82f3eb70de006af8f85c3507f9055fbc7c7295]
Jun 29 08:17:59 archjaro kernel:  ? __x64_sys_ioctl+0xd4/0x100
Jun 29 08:17:59 archjaro kernel:  ? count_memcg_events+0xd1/0x190
Jun 29 08:17:59 archjaro kernel:  ? do_user_addr_fault+0x237/0x710
-- Boot 830cded0565b49cda6b4fd025c024ece --
Jun 29 08:20:53 manjaro kernel: Linux version 6.18.36-1-MANJARO (linux618@manjaro) (gcc (GCC) 16.1.1 20260430, GNU ld (GNU Binutils) 2.46.0) #1 SMP PREEMPT_DYNAMIC Fri, 19 Jun 2026 12:31:28 +0000
This seems to be a quite complex bug that needs some work. If someone got the same issue, you can follow it over there.
Mod edit: Consecutive posts merged, spacers added.
Why you use that ?
acpi_enforce_resources=lax
Jun 29 08:20:57 archjaro kernel: ACPI: OSL: Resource conflict; ACPI support missing from driver?
Jun 29 08:20:57 archjaro kernel: ACPI: OSL: Resource conflict: System may be unstable or behave erratically
here
Jun 29 08:20:53 manjaro systemd-fsck[402]: fsck: /usr/bin/fsck.xfs: execute failed: No such file or directory
Jun 29 08:20:53 manjaro systemd-fsck[399]: fsck failed with exit status 8.
Jun 29 08:20:53 manjaro systemd-fsck[399]: Ignoring error.
Jun 29 08:20:57 archjaro systemd-remount-fs[494]:       * xfs: Deprecated parameter 'attr2'
As I remember, this was a try to get around another bug with my old RX480 which spammed my journal and crashed once in a while. Got a RX9070 now and should probably remove it. But I don’t think this is related to this issue. Nonetheless I’ll give it a go tomorrow.
Can’t explain the fsck part. Just checked and /usr/bin/fsck.xfs is where it should be.
YES !!!
I already removed it and updated grub.
Why is this so important? Do you think this is related?
I had used this parameter on my old Rampage III. The system did run, but I discovered that some modules weren’t loading at all, and so on; the system was unstable. Remove it and—if necessary—configure the modules correctly.
REISUB is working now. Only the kernel parameter wasn’t enough, had to put the sysctl config in there.
I can explain it. The base hook is not in the mkinitcpio because I do it with the systemd hook and the fsck hook as explained here.
