I have an Asus RT-AX3000 connected to an Australian NBN HFC cable modem with the latest Asus firmware. It is dual 2.4, 5ghz. The fastest d/l speed I can get to my desktop on either an ethernet connection (Cat 6) or wifi is about 90Mbps. However, from the same location (about 11 metres from the router) I can get 185Mbps over wifi from my Xiaomi Redmi Note 10 Pro (running crDroid OS) with 4g/LTE switched off. I am stumped as to why this is so. These speeds apply to different ISP’s. Enabling ipv6 made no difference.
My PC is Beelink SER5 5600H running Manjaro KDE with kernel 6.1.1-1. The network card is a Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller. The wifi card is a Mediatek MT7921K (RZ608) Wi-Fi 6E 80MHz.
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3f149b0a-bcf2-4edd-9950-19846ecd59f9 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Mini-pc Mobo: AZW model: SER v: V01 serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.15_P4C7M43_Blink date: 09/17/2022
RAM: total: 28.3 GiB used: 4.48 GiB (15.8%)
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1199 high: 1200 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
3: 1200 4: 1200 5: 1198 6: 1200 7: 1200 8: 1200 9: 1198 10: 1200 11: 1200
12: 1200 bogomips: 79082
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 34.0 C
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: AOC 24B2W1 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek driver: snd_hda_intel
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:0608
class-ID: 0280
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-3:3 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Local Storage: total: 5.91 TiB used: 3.96 TiB (66.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S8H40104 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD40NDZW-11MR8S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD20NMVW-11EDZS6 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5200 serial: <filter> rev: 1014 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 35.74 GiB (7.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 3f149b0a-bcf2-4edd-9950-19846ecd59f9
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2FCE-DCAB
ID-3: /external-2tb raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
used: 1.23 TiB (68.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: WD2GB
uuid: 8bc1a602-df98-408d-ad8e-7de53c330dd9
ID-4: /external-4tb raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 2.7 TiB (75.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: WD-4TB
uuid: b3369545-2e6b-4888-ab11-3488c95d8cc9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 1-2.3:3 info: TG3 Deck 108 Hassium type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 0a34:0212 class-ID: 0300
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0812 class-ID: 0900
Device-1: 2-2.1:3 info: Western Digital Elements SE 2622 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 1058:2622 class-ID: 0806 serial: <filter>
Device-2: 2-2.4:4 info: Western Digital Elements 25A2 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 1058:25a2 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-2: 3-3:3 info: MediaTek Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.5 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 314 Uptime: 43m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1500 libs: 380 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
[tpb@5600H ~]$
