Hello everyone, I have been looking for a Haier Tv L26F6 driver for Manjaro but I haven’t been able to find any, I’m using the tv right now but is in default mode 1024*768 and it doesn’t accept other resolutions, if anybody could help me it would be really appreciated.-
Monitors normally have no drivers. They simply set the resolution they may support. You can check in your manual if connecting your PC via VGA/DVI or HDMI might work. If you use X11 still you can play with xrandr to force a specific resolution. When supported you will see a picture, else the TV will show no signal …
Haier L26F6 Owner’s Manual [page 26] states that 1024x768 is maximum supported resolution for PC (VGA) or DVI connection but HDMI should support 720p and 1080i
Thanks for the replay ^^, I was testing too and VGA can only use, as you said, with 1024x768, can be set to look like 16:9 from another resolution with xrandr or from the monitor section in hyprland (the both i use), with HDMI the TV recognize the signal and better resolutions can be pair with the pc, thanks again for the replay ^^.
