Hi everyone a relative noob here typing. I had GZDoom running nice and smoothly until latest update a few days ago when it suddenly went mute. I removed it and when tried to reinstall it I got:
could not satisfy dependencies:
- unable to satisfy dependency ‘fluidsynth>=2.2’ required by zmusic
- unable to satisfy dependency ‘zmusic>=1.1.1’ required by gzdoom
The only way I can install it now is via snap but it keeps silent.
Ok now the “good information”:
Kernel: 5.13.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4df67120-defb-46cd-8440-53fd62303adc rw quiet
resume=UUID=b9098bba-74b7-462b-a07f-118d2fbcec70
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Apple product: MacBookAir5,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-66F35F19FE2A0D05 serial: <filter>
Mobo: Apple model: Mac-66F35F19FE2A0D05 v: MacBookAir5,1 serial: <filter>
UEFI: Apple v: MBA51.88Z.00EF.B04.1509111654 date: 09/11/2015
ID-1: BAT0 charge: 4.8 Wh (25.4%) condition: 18.9/35.1 Wh (54.0%) volts: 7.9
min: 7.5 model: DP bq20z451 type: Li-ion serial: N/A status: Charging
cycles: 2219
RAM: total: 3.74 GiB used: 3.27 GiB (87.3%)
Info: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 13574
Speed: 1264 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1264 2: 1690
3: 1470 4: 1917
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8510 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.1.5 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma port: efa0 bus-ID: 02:00.0
chip-ID: 14e4:4353 class-ID: 0280
IF-ID-1: pan1 state: down mac: <filter>
IP v4: <filter> scope: global
Device-1: Apple Built-in Bluetooth 2.0+EDR HCI type: USB driver: btusb
v: 0.8 bus-ID: 2-1.8.1.3:8 chip-ID: 05ac:821f class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 56.5 GiB used: 40.6 GiB (71.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD TS064E size: 56.5 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: BBF0 scheme: GPT
ID-1: / raw-size: 47.93 GiB size: 46.92 GiB (97.91%) used: 40.51 GiB (86.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4df67120-defb-46cd-8440-53fd62303adc
used: 264 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FB65-B49C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.27 GiB used: 97.2 MiB (1.1%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b9098bba-74b7-462b-a07f-118d2fbcec70
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2512 class-ID: 0900
Hub-6: 2-1.8.1:4
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.8.1.3:8 info: Apple Built-in Bluetooth 2.0+EDR HCI
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 2-1.8.2:5
info: Apple Internal Keyboard/Trackpad (MacBook Air) (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:024a class-ID: 0301
Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 234 Uptime: 1h 21m wakeups: 2 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1475 lib: 438
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
What should I do now?
