Gzdoom not working with Vulkan
Hello, just tried to to play some doom. On gzdoom, i can’t get Vulkan working. OpenGL works flawlessly, though.
that’s what gdb says:
https://paste.gg/p/anonymous/c5e1825ef37247ea99dfb2d22be10405
and the backtrace:
(gdb) bt
#0  0x00007fffd9b691ed in ?? () from /usr/lib/libnvidia-glcore.so.510.54
#1  0x000055555599ff55 in VulkanDevice::SelectPhysicalDevice() ()
#2  0x00005555559a0fd5 in VulkanDevice::VulkanDevice() ()
#3  0x00005555557b8eb0 in SDLVideo::CreateFrameBuffer() ()
#4  0x0000555555dbd43e in V_Init2() ()
#5  0x0000555555a1e1e0 in ?? ()
#6  0x0000555555a1f4e9 in GameMain() ()
#7  0x0000555555796664 in main ()
I’m pretty sure that’s not gzdoom problem. Same thing happened in quake 3:
https://paste.gg/p/anonymous/f73ab99168ab49b49ec4da9c13171984
any thoughts?
can you please return
inxi -Fza
this is not bugzilla here
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=1994032f-b14b-422e-b841-145b94598d15 rw apparmor=1
    security=apparmor udev.log_priority=3 debug
  Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
  Type: Desktop System: Gigabyte product: AB350M-DS3H V2 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350M-DS3H V2-CF v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F50
    date: 12/02/2019
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2131 high: 3449 min/max: 1550/3200 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1765 2: 3449
    3: 3339 4: 1375 5: 1374 6: 1375 7: 2699 8: 3212 9: 2872 10: 1374 11: 1374
    12: 1375 bogomips: 76669
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
    v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 4
    bus-ID: 06:00.0 chip-ID: 10de:1d01 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
    s-diag: 610mm (24")
  Monitor-1: HDMI-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") modes: N/A
  OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
    direct render: Yes
  Device-1: NVIDIA GP108 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
    bus-ID: 06:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.48 running: yes
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 931.51 GiB used: 183.18 GiB (19.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
    scheme: GPT
  ID-1: / raw-size: 417.2 GiB size: 409.58 GiB (98.17%)
    used: 183.16 GiB (44.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
  ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
    used: 25.4 MiB (26.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: file size: 3 GiB used: 48.5 MiB (1.6%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 54 C
  Processes: 320 Uptime: 1h 25m wakeups: 0 Memory: 7.77 GiB
  used: 4.17 GiB (53.7%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: 1523 pacman: 1513 lib: 407 flatpak: 0
  snap: 10 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.15
I have a GTX 1050ti and had problems with the newest driver. please try 470xx instead of 510xx. It fixed some games for me.
Also does this work?
pamac install vulkan-tools
vkcube
Yeah, that works
by the way, wouldnt installing 4700xx drivers break my system? I’m worried a little bit.
downgrading drivers didnt help =(
