Gwenview does not start anymore
from commandline I get this:
 gwenview         ✔
QPainter::begin: Paint device returned engine == 0, type: 2
QPainter::setOpacity: Painter not active
QPainter::end: Painter not active, aborted
journalctl shows a lot of automount requests like these:
journalctl  -xe|grep gwenview
Feb 25 12:03:57 t14 systemd[1]: mnt-Serienarchiv.automount: Got automount request for /mnt/Serienarchiv, triggered by 26345 (gwenview)
worked before last (Feb) update
not sure if it still worked before switching from sddm to plasma-login-manager
any ideas?
Gwenview launches without issue for me — launching via the command-line produces the same warning messages you indicated, however it still launches as expected.
Note that many applications may produce warnings when launched from the command-line. This doesn’t necessarily indicate a problem for the User.
As Gwenview doesn’t launch at all for you, then the problem might be elsewhere – one of the first things to rule out is that the problem is due to local configuration;
Please create a new User account for testing purposes, reboot and login to that account, and launch Gwenview normally and via the command-line to see if the problem persists.
Also note any differences in the warning messages that appear, if any. Report back with your findings.
Please provide your system information formatted according to forum guidelines: :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
I see the same message - then the GUI appears.
Perhaps the window is behind another one? :wink:
with new user gwenview starts, both ways from command line (same messages) and from GUI …
here’s system info:
inxi -zv8
  Kernel: 6.19.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
    root=UUID=91660225-4931-4ac7-a964-9ccb573ac93c rw quiet splash
    resume=UUID=d77979e3-95ca-42d5-946c-5f652ae4eb65 udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
    wm: kwin_wayland vt: 3 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21HD0043GE v: ThinkPad T14 Gen 4
  Mobo: LENOVO model: 21HD0043GE v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21HD_BU_Think_FM_ThinkPad
    T14 Gen 4 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: N3QET51W (1.51 ) date: 10/16/2025
  ID-1: BAT0 charge: 36.1 Wh (79.5%) condition: 45.5/52.5 Wh (86.6%)
    volts: 16.05 min: 15.44 model: Celxpert 5B10W51866 type: Li-poly
    serial: <filter> charging: status: not charging control: start: 75%
    end: 80% cycles: 120
  System RAM: total: 16 GiB available: 15.28 GiB used: 3.75 GiB (24.5%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA type: DDR5 detail: synchronous size: 16 GiB
    speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M425R1GB4DB0-CWMOL
    serial: N/A
  Device-2: Controller1-ChannelA/B-DIMM0 type: no module installed
  Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x6134
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 562 min/max: 400/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 562 2: 562 3: 562 4: 562 5: 562 6: 562 7: 562
    8: 562 9: 562 10: 562 11: 562 12: 562 bogomips: 59904
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:a721 class-ID: 0300
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 5986:118c
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0xd291 built: 2020 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.333 green: x: 0.294 y: 0.616 blue: x: 0.137 y: 0.051 white:
    x: 0.322 y: 0.345 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
    device-ID: 8086:a721 memory: 14.92 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-U) driver: mesa intel v: 25.3.5-arch1.1
    device-ID: 8086:a721 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:51ca
    class-ID: 0403
  API: ALSA v: k6.19.2-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0dc6 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 111.67 GiB (23.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN740 SDDQNQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 73112101 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 111.67 GiB (24.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 91660225-4931-4ac7-a964-9ccb573ac93c
    used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 1D78-6BE1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: d77979e3-95ca-42d5-946c-5f652ae4eb65
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:118c class-ID: fe01 serial: <filter>
  Device-2: 3-8:3 info: Alcor Micro AU9540 Smartcard Reader type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1453 libs: 387 tools: pamac
    1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    4: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    5: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    6: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    7: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 373
  1: cpu: 100% command: ps pid: 5661 mem: 4.01 MiB (0.0%)
  2: cpu: 18.5% command: plasmashell pid: 4361 mem: 419.5 MiB (2.6%)
  3: cpu: 13.8% command: vivaldi-bin pid: 5084 mem: 261.9 MiB (1.6%)
  4: cpu: 11.5% command: vivaldi-bin pid: 4917 mem: 500.6 MiB (3.1%)
  5: cpu: 6.4% command: vivaldi-bin pid: 4977 mem: 276.4 MiB (1.7%)
  Memory top: 5 of 373
  1: mem: 500.6 MiB (3.1%) command: vivaldi-bin pid: 4917 cpu: 11.5%
  2: mem: 421.1 MiB (2.6%) command: plasmashell pid: 1111 cpu: 0.1%
  3: mem: 419.5 MiB (2.6%) command: plasmashell pid: 4361 cpu: 18.5%
  4: mem: 276.4 MiB (1.7%) command: vivaldi-bin pid: 4977 cpu: 6.4%
  5: mem: 262.6 MiB (1.6%) command: kwin_wayland pid: 4197 cpu: 5.8%
  Processes: 373 Power: uptime: 2h 3m states: freeze,mem,disk suspend: s2idle
    wakeups: 3 fails: 1 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 6.1 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
In that case, you must compare the gwenview configuration files of both accounts. They are under ~/.config and ~/.local/share/gwenview.
uuuhh … thx - that was easy: removed the “recent folders” which contained some smb shares on my NAS, which of course I dont have when I travel …
in general: not very resilient – shouldn’t a reasonably decent application catch such trivial errors instead of endlessly trying to mount a non-existent share?
That is not up to dolphin, but it may depend on how you mount the Samba shares. If you mount them unconditionally, then dolphin will of course assume that they are always there.
thx Aragorn … well I mount them through systemd automount/mount units assuming this is the proper way to do it? Sometimes I remotely access my NAS via wireguard to copy a file to/from a share … but i assumed the automounts would timeout after a while again? don’t they?
Anecdotal:-
The scenario I’m about to describe doesn’t happen very often – but, it does happen – most recently with LibreOffice, but also with various other applications:
Scenario:
I launch an application and there is no apparent result; I try again, and again with no result.
Then I notice a small vertical line in the center of the screen – maybe 100px high and 2-4px wide – which I initially mistake for screen tearing, and ignore, while working the problem of the application not opening.
After a reboot, the screen tearing artifact is gone (yay, one less thing to be concerned with) and I try to launch the application again, as if the reboot might magically solve the issue.
The screen tearing artifact reappears. This time I hover the mouse over it, and the cursor changes to a sizing icon.
What the…?
I carefully position the mouse (the sizing icon is difficult to make appear again) and finally drag it to the right a little, and to my surprise it reveals the application that I presumes wasn’t starting.
It was starting just fine, only it’s dimensions were too small for me to notice it. :open_mouth:
So, carefully check for this scenario in case it’s actually open but not easily visible.
That’s all, folks!
This reminds me of around the time I finally switched to Wayland, > 2½ years ago; I needed to reset the “Special Window Settings” (or it might have been the application ones). I was getting tiny boxes show up with stuff I tried to show from the panel on hover, etc. and popups appearing in the wrong place (separated from the panel). I wonder if this is related? … if it is, removing those customizations will fix it.
No, better would be something like autofs, set up in /etc/fstab. That’s what’s normally used for remotely hosted filesystems.
And better add nofail as a mount option too, so that it won’t stall on boot.
No, better would be something like autofs , set up in /etc/fstab
OK, thank you – I’ll give fstab a try.
