I’ve seen so many incomplete guides and know many people struggled with this (myself included!). This is the EASIEST guide out there on how to set up the Korean keyboard!
Difficulty: ★★☆☆☆
Step 1: Add ko_KR.UTF-8 UTF-8 to /etc/locale.gen :
echo ko_KR.UTF-8 UTF-8 | sudo tee -a /etc/locale.gen
Step 2: Update your system locale:
sudo locale-gen
Step 3: Update Manjaro so you can install software:
sudo pacman -Syyu
Step 4: Install your keyboard switcher, and the 한국어 fonts!
sudo pacman -S adobe-source-han-sans-kr-fonts fcitx5-hangul fcitx5-configtool
Step 5: Open fcitx in your launcher
A keyboard icon (fcitx) will appear in your bottom right, near the clock
Step 6: Right click fcitx in your tray and select configure
Step 7: Deselect “Only Show Current Language”
Step 8: Find hangul, click it, then click the > button to send it to “Current Input Method”:
Step 9: Hit OK
Step 10: Type in Korean!!
By default, Ctrl + Space will swap you between Korean and English characters. You can also Right Click Fcitx again and select “Hangul” or “English” from “Input Method”.
Bonus tip: If you add fcitx to your Autostart in the settings, you can have Hangul start up every time you boot your computer.
I spent a while figuring out the exact steps you need for Hangul on fresh VMs, so hopefully this works for you!
If you have any problems, please reply to this thread or message me and I’ll do my best to help you. Also @Admins, if this thread is in the wrong spot, feel free to move it. Enjoy
