Have to revive this thread, since the problem still occurs (but it took me some time to catch a crash while remembering to run it from terminal beforehand). Running pamac-manager via terminal only returns:
pamac-manager ✔
(pamac-manager:3302): IBUS-WARNING **: 18:02:58.261: Unable to connect to ibus: The given address is empty
zsh: terminated pamac-manager
(while the IBUS-warning appears right after launching). It seems to be only the GUI that is crashing, because if I re-launch pamac-manager (or any other package manger) it is complaining that anothe rupdate is still running. And on the next day most of the updates are installed.
Kernel: 6.12.37-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=/dev/mapper/VolumeGroup-root rw systemd.show_status=1 apparmor=1
security=apparmor udev.log_priority=5 intel_iommu=on
vfio-pci.ids=10de:21c4,10de:1aeb,10de:1aec,10de:1aed kvm.ignore_msrs=1
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Desktop Mobo: ASUSTeK model: H170-PRO v: Rev X.0x
UEFI: American Megatrends v: 3805 date: 05/16/2018
System RAM: total: 64 GiB available: 62.72 GiB used: 10.1 GiB (16.1%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM_A1 type: DDR4 detail: synchronous size: 16 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Team Group Inc. part-no: TEAMGROUP-UD4-3000 serial: <filter>
Device-2: DIMM_A2 type: DDR4 detail: synchronous size: 16 GiB
Device-3: DIMM_B1 type: DDR4 detail: synchronous size: 16 GiB
Device-4: DIMM_B2 type: DDR4 detail: synchronous size: 16 GiB
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1000 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1000 2: 1000 3: 1000 4: 1000 5: 1000 6: 1000
7: 1000 8: 1000 bogomips: 54417
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 575.64.03 non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4 ports: active: none
off: DP-1 empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1d01
class-ID: 0300
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: vfio-pci v: N/A non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:21c4 class-ID: 0300
Device-3: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1.2:7
chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Dell U2713HM
serial: <filter> built: 2013 res: mode: 2560x1440 hz: 60 scale: 100% (1)
dpi: 109 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.294
y: 0.639 blue: x: 0.145 y: 0.039 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 575.64.03
device-ID: 10de:1d01 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: ASUSTeK H110I-PLUS driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK CMI8786
driver: snd_oxygen v: kernel bus-ID: 03:04.0 chip-ID: 13f6:8788
class-ID: 0401
Device-4: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: vfio-pci pcie: speed: Unknown lanes: 63 link-max: gen: 6
speed: 64 GT/s bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-5: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.37-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.6 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 07:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br0 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
IF-ID-3: virbr1 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-4: virbr2 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-5: virbr3 state: down mac: <filter>
IF-ID-6: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-7: vnet1 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: vnet2 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Info: services: httpd, NetworkManager, systemd-timesyncd
Message: Unable to run lvs. Root privileges required.
Local Storage: total: 9.1 TiB used: 4.4 TiB (48.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC54 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM000-1F2168
Optical-1: /dev/sr0 vendor: ASUS model: BC-12D2HT rev: 1.00
dev-links: cdrom
Features: speed: 1 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 180 GiB size: 176.11 GiB (97.84%) used: 93.11 GiB (52.9%)
fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: VolumeGroup-root label: N/A
uuid: N/A
ID-2: /boot/efi raw-size: 401 MiB size: 400.2 MiB (99.79%)
used: 340 KiB (0.1%) fs: vfat dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 7B90-C820
ID-3: /home raw-size: 1.28 TiB size: 1.26 TiB (98.35%)
used: 830.06 GiB (64.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: VolumeGroup-home label: N/A uuid: N/A
ID-4: /home/<filter>/backups raw-size: 2.31 TiB size: 2.27 TiB (98.39%)
used: 1.83 TiB (80.9%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Backup
uuid: 6a4a8faf-3b9d-435e-ac58-8f7ad273b102
ID-5: /run/media/VolumeGroups/downloads raw-size: 1.91 TiB
size: 1.88 TiB (98.42%) used: 1.43 TiB (76.1%) fs: ext4 dev: /dev/dm-4
maj-min: 254:4 mapped: VolumeGroup3-downloads label: N/A uuid: N/A
ID-6: /run/media/VolumeGroups/server raw-size: 437.62 GiB
size: 430.56 GiB (98.39%) used: 33.86 GiB (7.9%) fs: ext4 dev: /dev/dm-2
maj-min: 254:2 mapped: VolumeGroup2-server label: N/A uuid: N/A
ID-7: /run/media/VolumeGroups/videos raw-size: 927.73 GiB
size: 912.1 GiB (98.31%) used: 205.59 GiB (22.5%) fs: ext4 dev: /dev/dm-3
maj-min: 254:3 mapped: VolumeGroup2-videos label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 24.22 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb8 maj-min: 8:24 label: N/A
uuid: 9486fb7e-a0c2-42ae-ba32-171a0c28c293
ID-1: /dev/sda1 maj-min: 8:1 size: 1.73 TiB fs: ntfs label: Win_Daten
uuid: 5971FDA10442A372
ID-2: /dev/sdb1 maj-min: 8:17 size: 350 MiB fs: ntfs label: Recovery
uuid: C218DCFC18DCF101
ID-3: /dev/sdb6 maj-min: 8:22 size: 348.08 GiB fs: ntfs
label: Win_Programme uuid: 33B0857F0E3DF308
Hub-2: 1-9:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-3: 1-9.1:3 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Hub-4: 1-9.1.1:5 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
Device-1: 1-9.1.2:7 info: Microdia USB Live camera type: video,audio
Device-2: 1-9.2:4 info: Microdia Foot Switch type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 0c45:7403 class-ID: 0301
Device-3: 1-9.3:6 info: Microdia Foot Switch type: keyboard,mouse
Hub-5: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 3-2:2 info: Terminus Hub ports: 4 rev: 2.0
Device-1: 3-2.2:3 info: Microdia Foot Switch type: keyboard,mouse
Device-2: 3-2.3:4 info: Microdia Foot Switch type: keyboard,mouse
Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 2030 libs: 365 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
2: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
3: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
4: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
5: https://mirror.zetup.net/manjaro/stable/$repo/$arch
6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://muug.ca/mirror/manjaro/stable/$repo/$arch
8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 338
1: cpu: 57.0% command: qemu-system-x86_64 pid: 2767 mem: 3218.5 MiB (5.0%)
2: cpu: 25.5% command: firefox pid: 2250 mem: 722.0 MiB (1.1%)
3: cpu: 11.4% command: qemu-system-x86_64 pid: 1930 mem: 1394.8 MiB (2.1%)
4: cpu: 11.0% command: firefox pid: 4068 mem: 298.1 MiB (0.4%)
5: cpu: 9.8% command: firefox pid: 36709 mem: 277.3 MiB (0.4%)
Memory top: 5 of 338
1: mem: 3218.5 MiB (5.0%) command: qemu-system-x86_64 pid: 2767 cpu: 57.0%
2: mem: 1394.8 MiB (2.1%) command: qemu-system-x86_64 pid: 1930 cpu: 11.4%
3: mem: 722.0 MiB (1.1%) command: firefox pid: 2250 cpu: 25.5%
4: mem: 611.8 MiB (0.9%) command: plasmashell pid: 1698 cpu: 9.2%
5: mem: 380.3 MiB (0.5%) command: firefox pid: 2386 cpu: 1.6%
Processes: 338 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.06 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 20.1.7 gcc: 15.1.1 alt: 13/14 Shell: Zsh v: 5.9
default: Bash v: 5.3.0 running-in: konsole inxi: 3.3.38
