GUI is not loading after installing nvidia proprietary drivers
Hello there. I’ve been using Manjaro XFCE for a week now (used to be a Windows and Mint user, I don’t know much about Linux overall). My problem is that whenever I install video-nvidia-390xx driver, the GUI is not loading after reboot, just a black screen, which I can access tty. To access the GUI I always have to remove the nvidia driver via tty and use video-linux. Also I can access the GRUB menu.
Anyway here is my inxi output.
  Kernel: 5.4.112-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=6641d2db-39a4-440b-987e-a6d2c6ebe651 rw quiet apparmor=1
  security=apparmor resume=UUID=978063bf-f30e-4ef9-b4c6-26ef1c44fe6a
  udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
  serial: <filter> Chassis: type: 10 v: Lenovo ideapad 330-15IKB
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
  v: 8TCN43WW date: 05/18/2018
  ID-1: BAT0 charge: 26.0 Wh (100.0%) condition: 26.0/30.6 Wh (84.9%)
  volts: 8.5 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly serial: <filter>
  status: Full
  RAM: total: 7.69 GiB used: 1.91 GiB (24.9%)
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 cache: L2: 6 MiB bogomips: 28808
  Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 801
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
  flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
  hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
  md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
  pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
  rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
  vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nouveau
  v: kernel bus-ID: 01:00.0 chip-ID: 10de:1d10 class-ID: 0302
  Device-3: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4
  chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nouveau
  alternate: fbdev,intel,nv,vesa display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.2
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.4.112-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.25 running: no
  vendor: Lenovo driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus-ID: 03:00.0
  chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
  chip-ID: 0cf3:e500 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 931.51 GiB used: 82.75 GiB (8.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
  dev-links: cdrom
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
  used: 82.75 GiB (9.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 6641d2db-39a4-440b-987e-a6d2c6ebe651
  used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 16AA-7643
  dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 978063bf-f30e-4ef9-b4c6-26ef1c44fe6a
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-3:2 info: A4Tech USB Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 09da:c10a class-ID: 0301
  Device-2: 1-7:3 info: Qualcomm Atheros type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
  class-ID: e001
  Device-3: 1-8:4 info: IMC Networks EasyCamera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 42.5 C mobo: N/A gpu: nouveau temp: 43.0 C
  Processes: 209 Uptime: 11m wakeups: 1 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1265 lib: 325
  flatpak: 0 Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.04
Also my mhwd -l output, if it helps.
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0302:10de:1d10) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2020.11.30               false            PCI
          video-nvidia            2020.11.30               false            PCI
    video-nvidia-390xx            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:5917) Display controller Intel Corporation:
It seems that my problem is solved with using Optimus Manager. I still set it to Intel integrated graphics card at startup because I worry about stucking in the terminal again with all the possible Optimus Manager configuration may make my case worse somehow.
You need to install video-hybrid-intel-nvidia-prime because you have a laptop,don’t install video-nvidia,then in optimus manager you can freely switch what graphics card you want.
Thanks for the reply, might be a newbie question but what’s the difference with driver video-hybrid-intel-nvidia-390xx-bumblebee?
I installed 390-xx-bumblebee, disabled Bumblebeed.service and now everything seems working.
Bumblebee is a old method of doing dual graphics,its deprecated unless you have a old nvidia card,thats why you need to install video-hybrid-intel-nvidia-prime because thats the current and improve method because its official by nvidia.
Like @XRaTiX already told you: Bumblebee is old technology and your:
is still supported by the 460 series driver so you’d indeed be better off with the video-hybrid-intel-nvidia-prime driver.
Why the GUI is not loading when you install the nVidia only drivers is because your
has no actual electric wiring from the nVidia card to the internal laptop screen and the Intel card is used as a dumb framebuffer to transfer data to the internal screen but that means you need the hybrid driver if you want to use the internal screen.
A few years ago laptops used to have dual wiring and you could choose between Intel - nVidia and Hybrid mode in the UEFI / BIOS, but not any more…
:sob:
P.S. Alternatively, you might be able to use the nVidia-only drivers with an external screen. (last time I looked that still worked on a Lenovo) :man_shrugging:
Thank you for your reply, it was really insightful. I guess I’ve got to learn more about the hardware I’m using.
:sweat_smile:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
