So for some time now after starting War Thunder or Cities: Skylines the game runs for a short while (up to 2 minutes) and them my screen turns black, but audio continues. I can use Ctrl+Alt+F3 to go to terminal. If I go back to the GUI (Ctrl+Alt+F2 or Ctrl+Alt+F1, although I have to login again after that one) I usually get some more screen time, until the scenario repeats. If I close the game via terminal I can go back to the GUI as if nothing happened. All other programs keep on running.
Now, that doesn’t happen with Don’t Starve: Together, which is graphically less intensive. It also wasn’t happening before. It might’ve started after the last update but I didn’t notice since I was busy with midterms and hadn’t had the time to play.
A few weeks ago this wasn’t an issue and I could play both WT and C:S normally. I find it weird that it says not enough memory.
Could this be a hardware problem, and not a software one?
I use a Lenovo ThinkPad E14, with Ryzen 5 4500U and 16 GB of RAM. DE is Gnome. Kernel Linux 6.0.8-1-MANJARO x86_64.
Any help would be appreciated. Thank you for your time.
These jumped out to me in the system journal logs:
pro 05 20:40:57 user-20t6000rsc firefox[3175]: Couldn't map window 0x7f4304ad7fc0 as subsurface because its parent is not mapped.
pro 05 20:40:57 user-20t6000rsc kernel: amdgpu 0000:04:00.0: amdgpu: 00000000f7fe5aff pin failed
pro 05 20:40:57 user-20t6000rsc kernel: [drm:dm_plane_helper_prepare_fb [amdgpu]] *ERROR* Failed to pin framebuffer with error -12
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Failed to scan out client buffer: drmModeAtomicCommit: Nema dovoljno memorije
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Failed to post KMS update: drmModeAtomicCommit: Nema dovoljno memorije
pro 05 20:40:57 user-20t6000rsc kernel: amdgpu 0000:04:00.0: amdgpu: 00000000f0cf4b1d pin failed
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Page flip discarded: drmModeAtomicCommit: Nema dovoljno memorije
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Failed to scan out client buffer: drmModeAtomicCommit: Nevaljani argument
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Failed to post KMS update: drmModeAtomicCommit: Nevaljani argument
pro 05 20:40:57 user-20t6000rsc gnome-shell[1682]: Page flip discarded: drmModeAtomicCommit: Nevaljani argument
Nema dovoljno memorije = Not enough memory.
Nevaljani argument = Invalid argument.
pro 05 20:41:20 user-20t6000rsc systemd-coredump[123188]: [🡕] Process 122687 (aces) of user 1000 dumped core.
Module /home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces with build-id 1a1000a33da373394942ef22f8f2059c04cfe261
Module /home/user/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so with build-id 6ac86a92a06512414fe84eef09b15c43bab99b3e
Module linux-vdso.so.1 with build-id 4c401cb13195aeea26415c88e112cbc06f615d11
Module libgpg-error.so.0 with build-id 470d76ceb1e53cb017f78c08936e9bafaeb4058b
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libFLAC.so.12 with build-id d09804bc783c1cad0b423b136a5260c0e8c62d40
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libasyncns.so.0 with build-id 01c1c4096a521b900216c5ce3f6bae6529324d74
Module libsystemd.so.0 with build-id 1c1489e575197ffbf417c79f926e572421f3692f
Module libsndfile.so.1 with build-id 923361ca7a51d29651ef1e282559cbff70e31cde
Module libdbus-1.so.3 with build-id 6d6e4846c8e56903b4fe7d992ae6bb30c8a20a9c
Module libpulsecommon-16.1.so with build-id bbc2ea99257d0013d10d1829bab2d762d56c9854
Module libpulse.so.0 with build-id 27ffa5ab84f98b1724cc7e9b1385d2f28ee557cc
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXrender.so.1 with build-id 9d6512ea1c9698e8c81f27e89fda57d36eb4b18e
Module libXext.so.6 with build-id d7f3b1c9d5be6574b5faf83b74f8bba3d0dfa3c6
Module libXrandr.so with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libicudata.so.72 with build-id a133b365160fc45e002163e5435f3029f4254cfa
Module libicuuc.so.72 with build-id c2e0249a038bd0fe76e681ecd2b73951c65a0866
Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
Module libxml2.so.2 with build-id 171e32069b76d4cfedbfdf97f2087807948a9b3d
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
Module libffi.so.8 with build-id 5c6b22b6624dd486a0783dfe74fee085b626b573
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libz.so.1 with build-id 5340199d53cb95e609028ce1143675c742ff4218
Module libnss_myhostname.so.2 with build-id 247f8b2a33d7a05abdc1ae21fa87476ebe501829
Module libnss_resolve.so.2 with build-id b4537867926f69db4f5a33943a3b155ce745023a
Module libnss_mdns4_minimal.so.2 with build-id a6fde528b667185a18aca5be61727fb369423647
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libnss_mymachines.so.2 with build-id ace689f86a3cbd6f5adbb58c219f1b2ccea83bf4
Module UTF-32.so with build-id e5df458f2d81d469022d6b75454240505639e35d
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libX11.so.6 with build-id e07bf7192ed4ad0be11565ee9374cb43a96ada98
Module librt.so.1 with build-id ce8e0934f83057f038b5a06eb70082bef142d2f0
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Stack trace of thread 122687:
#0 0x00007f918c454c6d getenv (libc.so.6 + 0x3bc6d)
#1 0x00007f9178107cd9 pa_in_valgrind (libpulsecommon-16.1.so + 0x24cd9)
#2 0x00007f91796f502e n/a (libpulse.so.0 + 0xd02e)
#3 0x00007f918cb66aae n/a (ld-linux-x86-64.so.2 + 0x4aae)
#4 0x00007f918c453fa5 n/a (libc.so.6 + 0x3afa5)
#5 0x00007f918c454120 exit (libc.so.6 + 0x3b120)
#6 0x00000000017e5892 n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x13e5892)
#7 0x0000000000994301 n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x594301)
#8 0x00000000017f5bbd n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x13f5bbd)
#9 0x00000000019fb315 n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x15fb315)
#10 0x000000000099ed59 n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x59ed59)
#11 0x000000000041f0c4 n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x1f0c4)
#12 0x00007f918c43c290 n/a (libc.so.6 + 0x23290)
#13 0x00007f918c43c34a __libc_start_main (libc.so.6 + 0x2334a)
#14 0x00000000004b6c6a n/a (/home/user/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0xb6c6a)
pro 05 20:41:20 user-20t6000rsc systemd[1]: systemd-coredump@8-123187-0.service: Deactivated successfully.
pro 05 20:41:20 user-20t6000rsc kernel: audit: type=1131 audit(1670269280.864:644): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@8-123187-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?>
pro 05 20:41:20 user-20t6000rsc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@8-123187-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
pro 05 20:41:20 user-20t6000rsc systemd[1]: systemd-coredump@8-123187-0.service: Consumed 7.544s CPU time.
pro 05 20:41:20 user-20t6000rsc audit: BPF prog-id=0 op=UNLOAD
pro 05 20:41:20 user-20t6000rsc kernel: audit: type=1334 audit(1670269280.984:645): prog-id=0 op=UNLOAD
pro 05 20:41:20 user-20t6000rsc kernel: audit: type=1334 audit(1670269280.984:646): prog-id=0 op=UNLOAD
pro 05 20:41:20 user-20t6000rsc kernel: audit: type=1334 audit(1670269280.984:647): prog-id=0 op=UNLOAD
