GUI applications over ssh freeze within seconds
Hey,
I need your help with a problem that I couldn’t find much about on the internet.
My issue is that any gui application I open on an openSUSE Server via ssh X11-forwarding freezes within seconds and I get a “application is not responding” popup, no matter how complex those applications are.
Another problem, that might be related to that is, that sometimes, my laptop isn’t even able to launch a qt based gui application, giving me the error:
qt.qpa.plugin: Could not load the Qt platform plugin "xcb"
But currently I am not able to reproduce that, so this is of lesser concern, if this issue is not related to the first one.
I know, that it was working a few weeks ago, so probably an update on the server or my personal laptop broke it.
My Setup 1: Manjaro, Linux 6.0.2-2, Gnome 42.5, wayland
Setup 2: Ubuntu (set up a few days a go), Gnome (probably also 42)
Setup 3: OpenSUSE, Linux 6.0.3-1, Gnome 43.0
Server 1: openSUSE, Linux 5.19.13-1, Gnome 43.0
Server 2: openSUSE, Linux 6.0.3-1, Gnome 43.0
My personal Setup is the first one and I observe the issue both with Server 1 or Server 2. First I was running open-source graphic drivers with wayland but also had the same problem when changing to xorg.
I installed proprietary drivers and got the gui applications working on xorg. However as my laptop has quite a high resolution I don’t want to switch to xorg as it doesn’t support fractional scaling, I had issues with external monitors with a smaller resolution and ssh applications don’t get scaled at all. The combination of proprietary drivers and wayland led to the same issue again.
I know that a laptop running openSUSE on the latest Gnome version (Setup 3) has no issues with gui applications over shh. However a freshly setup Ubuntu Gnome system (Setup 2) has the same problem I am facing.
I would be very grateful for any ideas on how to solve the problem with gui applications on wayland.
Your topic is very confusing - so I am trying to clarify a few things.
Besides the obvious SSH tunnel, how do you connect to the system?
Are your connection to the desktop or are you running a specific application over ssh?
Are you using xdmcp, vnc or rdp?
Sorry for the confusion, I guess I forgot to mention a few things:
I am just running specific apps using X11 forwarding (ssh -X), I don’t think the server supports anything else at the moment.
That’s what I thought - depending on the complexity and general requirements of the application this can be very slow.
I have been playing with running firefox on a RPI4 and even though it is running in my LAN it is very slow.
Mousepad on the other hand is fairly swift in the response - also with the file dialog.
Yes, I know, but in my use case this doesn’t matter so much. Some applications are very simple, like a qt application with some text and a few buttons or a gnuplot graph. And those ones also freeze, even in a LAN network.
If the remote Gnome is running on Wayland add to your ~/.profile
export QT_QPA_PLATFORM=wayland
If I try to run Manjaro Settings Manager using X over ssh - I get a message
qt.qpa.xcb: XKeyboard extension not present on the X server
Above search also suggests It may be caused by a missing qt library.
In any case there is no definite answer - so you are left to experiment with the various suggestions.
Installing featherpad (a wellknown qt based notepad app) generates more messages
There is no XRandR 1.2 and later version available. There will be only fake screen(s) to use.
The messages does not prevent the application from being functional.
