Hello everyone!
I got problem with GTX 1650 on my laptop, when I try to start X it freezes. Only 1 in 20 retries (or so) it runs my XMonad WM (I suppose its not the culprit).
It can freeze on tty when I login too! It shows error can't change power state from D3cold to D0 (config space inaccessible)
Here’s my inxi -Fxxxz:
Kernel: 5.4.100-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: N/A dm: startx Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GT_X571GT
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X571GT v: 1.0 serial: <filter> UEFI: American Megatrends
v: X571GT.308 date: 12/17/2020
ID-1: BAT1 charge: 33.4 Wh condition: 33.4/41.9 Wh (80%) volts: 12.8/11.8
model: ASUS A32-K55 type: Li-ion serial: N/A status: Full
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: A L2 cache: 12 MiB
bogomips: 62431
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 901 8: 901 9: 900 10: 900 11: 901 12: 900
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 460.39 bus ID: 01:00.0 chip ID: 10de:1f91 class ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-7:5 chip ID: 13d3:56a8 class ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.10 compositor: picom v: git-a8445 driver:
loaded: modesetting,nvidia unloaded: intel,nouveau,vesa alternate: fbdev,nv
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a348 class ID: 0403
Sound Server: ALSA v: k5.4.100-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 4000
bus ID: 03:00.0 chip ID: 8086:2723 class ID: 0280
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI port: 3000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-14:6
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --rec
ommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 10
Local Storage: total: 953.88 GiB used: 198.87 GiB (20.8%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 002C
scheme: GPT
ID-2: /dev/sda type: USB vendor: Silicon Power model: SPCC Sol id State Disk
size: 476.94 GiB serial: <filter> rev: 0301 scheme: GPT
ID-1: / size: 97.93 GiB used: 41.65 GiB (42.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot size: 511 MiB used: 150.2 MiB (29.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 369.53 GiB used: 157.08 GiB (42.5%) fs: ext4
dev: /dev/nvme0n1p3
ID-1: swap-1 type: file size: 20.38 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 46.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 246 Uptime: 31m wakeups: 1 Memory: 15.49 GiB
used: 1.68 GiB (10.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: pacman: 1297 Shell: Bash v: 5.1.0 running in: kitty
inxi: 3.3.01
and my mhwd -li:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
network-r8168 2016.04.20 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
I installed my system using Manjaro’s Architect, I use kernel 5.4 now, but I have 5.10 and 5.9 installed, I tried to change those because I was thinking it might help.
I think its worth noting to say that my /etc/X11/mhwd.d/nvidia.conf is empty, should It be like that?
When I uninstall hybrid driver and use only video-linux, my system works fine, but it doesnt see my GTX card… so I cant even use it in Blender.
Is there workaround to this freezing driver? Could I install drivers myself or something, using bumblebee or whatnot
