GTK theme not applying after update, appearance settings not changing theme
Hi there,
I recently ran yay -Syu and my GTK theme is no longer applying. I also can’t use the Appearance Settings to change my theme. I use i3 as a WM on top of XFCE, and don’t use the XFCE panel, if that’s relevant.
I deleted ~/.gtkrc-2.0 (can’t recall exact file name), ~/.config/gtk-2.0, ~/.config/gtk-3.0, ~/.config/gtk-4.0, and ~/.config/xfce4 and logging back in to no avail.
I’ve also tried creating another user and changing the theme there, which also doesn’t work.
Oddly, I have my theme set as my LightDM GTK+ Greeter theme, and when I log in, the correct theme is shown on my greeter.
As well, sudo thunar doesn’t use the correct theme, but opening Thunar and right-clicking, then clicking ‘Thunar Root’ uses the right theme.
I can also change my icon theme correctly, but not my GTK theme. I’ve verified that the selected theme has a gtk-4.0 folder.
Here is the relevant bit of /var/log/pacman.log:
[2024-02-23T21:25:59-0800] [ALPM] transaction started
[2024-02-23T21:25:59-0800] [ALPM] removed bashrc-manjaro (5.2.021-1)
[2024-02-23T21:25:59-0800] [ALPM] upgraded linux-api-headers (6.4-1 -> 6.7-1)
[2024-02-23T21:25:59-0800] [ALPM] upgraded tzdata (2023d-1 -> 2024a-1)
[2024-02-23T21:25:59-0800] [ALPM] upgraded iana-etc (20231117-1 -> 20231228-1)
[2024-02-23T21:25:59-0800] [ALPM] warning: /etc/passwd installed as /etc/passwd.pacnew
[2024-02-23T21:25:59-0800] [ALPM] upgraded filesystem (2023.12.21-1 -> 2024.01.19-1)
[2024-02-23T21:25:59-0800] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2024-02-23T21:25:59-0800] [ALPM] upgraded glibc (2.38-7 -> 2.39-1.1)
[2024-02-23T21:25:59-0800] [ALPM-SCRIPTLET] Generating locales...
[2024-02-23T21:26:00-0800] [ALPM-SCRIPTLET]   en_US.UTF-8... done
[2024-02-23T21:26:01-0800] [ALPM-SCRIPTLET]   en_CA.UTF-8... done
[2024-02-23T21:26:01-0800] [ALPM-SCRIPTLET] Generation complete.
[2024-02-23T21:26:01-0800] [ALPM] upgraded acl (2.3.1-3 -> 2.3.2-1)
[2024-02-23T21:26:01-0800] [ALPM] upgraded adobe-source-han-sans-cn-fonts (2.004-1 -> 2.004-2)
[2024-02-23T21:26:01-0800] [ALPM] upgraded adobe-source-han-sans-jp-fonts (2.004-1 -> 2.004-2)
[2024-02-23T21:26:01-0800] [ALPM] upgraded adobe-source-han-sans-kr-fonts (2.004-1 -> 2.004-2)
[2024-02-23T21:26:01-0800] [ALPM] upgraded alsa-card-profiles (1:1.0.0-2 -> 1:1.0.3-1)
[2024-02-23T21:26:01-0800] [ALPM] upgraded alsa-ucm-conf (1.2.10-2 -> 1.2.11-1)
[2024-02-23T21:26:01-0800] [ALPM] upgraded alsa-lib (1.2.10-2 -> 1.2.11-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded gcc-libs (13.2.1-3 -> 13.2.1-5)
[2024-02-23T21:26:02-0800] [ALPM] upgraded hwdata (0.378-1 -> 0.379-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded zlib (1:1.3-2 -> 1:1.3.1-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded openssl (3.2.0-1 -> 3.2.1-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded readline (8.2.007-1 -> 8.2.010-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded bash (5.2.021-1 -> 5.2.026-2)
[2024-02-23T21:26:02-0800] [ALPM] upgraded xz (5.4.5-1 -> 5.4.6-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded alsa-utils (1.2.10-1 -> 1.2.11-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded aom (3.8.0-2 -> 3.8.1-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libidn2 (2.3.4-3 -> 2.3.7-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libnghttp2 (1.58.0-1 -> 1.59.0-2)
[2024-02-23T21:26:02-0800] [ALPM] installed libnghttp3 (1.1.0-2)
[2024-02-23T21:26:02-0800] [ALPM] upgraded attr (2.5.1-3 -> 2.5.2-1)
[2024-02-23T21:26:02-0800] [ALPM] warning: directory permissions differ on /var/log/audit/
filesystem: 700  package: 755
[2024-02-23T21:26:02-0800] [ALPM] upgraded audit (3.1.2-1 -> 4.0-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded pam (1.5.3-3 -> 1.6.0-3)
[2024-02-23T21:26:02-0800] [ALPM] upgraded coreutils (9.4-2 -> 9.4-3)
[2024-02-23T21:26:02-0800] [ALPM] upgraded systemd-libs (255.2-2 -> 255.3-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded ca-certificates-mozilla (3.96.1-1 -> 3.97-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded curl (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libsysprof-capture (45.1-1 -> 45.2-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded glib2 (2.78.3-1 -> 2.78.4-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libxml2 (2.12.3-1 -> 2.12.5-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libpng (1.6.40-2 -> 1.6.42-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded pixman (0.43.0-1 -> 0.43.2-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libxext (1.3.5-1 -> 1.3.6-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded expat (2.5.0-1 -> 2.6.0-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded pango (1:1.51.1-1 -> 1:1.51.2-1)
[2024-02-23T21:26:02-0800] [ALPM] upgraded libjpeg-turbo (3.0.1-1 -> 3.0.2-2)
[2024-02-23T21:26:02-0800] [ALPM] upgraded appstream (1.0.1-1 -> 1.0.1-2)
[2024-02-23T21:26:03-0800] [ALPM] upgraded archlinux-appstream-data (20231203-1 -> 20240112-1)
[2024-02-23T21:26:03-0800] [ALPM] upgraded xorg-xprop (1.2.6-1 -> 1.2.7-1)
[2024-02-23T21:26:03-0800] [ALPM] upgraded libelf (0.190-1 -> 0.190-2)
[2024-02-23T21:26:03-0800] [ALPM] upgraded device-mapper (2.03.22-2 -> 2.03.23-1)
[2024-02-23T21:26:03-0800] [ALPM] upgraded cryptsetup (2.6.1-3.5 -> 2.7.0-1)
[2024-02-23T21:26:03-0800] [ALPM] upgraded libseccomp (2.5.5-1 -> 2.5.5-2)
[2024-02-23T21:26:03-0800] [ALPM] upgraded shadow (4.14.2-1 -> 4.14.3-1)
[2024-02-23T21:26:03-0800] [ALPM] warning: directory permissions differ on /usr/share/polkit-1/rules.d/
filesystem: 750  package: 755
[2024-02-23T21:26:03-0800] [ALPM] upgraded systemd (255.2-2 -> 255.3-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded atkmm (2.28.3-1 -> 2.28.4-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded xdg-utils (1.2.0r25+g0f49cf5-1 -> 1.2.1-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded sqlite (3.44.2-2 -> 3.45.1-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libpciaccess (0.17-1 -> 0.18-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libdrm (2.4.119-1 -> 2.4.120-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded vulkan-icd-loader (1.3.274-1 -> 1.3.276-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded mesa (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libwacom (2.9.0-2 -> 2.10.0-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libinput (1.24.0-1 -> 1.25.0-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libproxy (0.5.3-2 -> 0.5.4-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded md4c (0.4.8-1 -> 0.5.2-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded gnutls (3.8.2-1 -> 3.8.3-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded xkeyboard-config (2.40-1 -> 2.41-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded qt5-base (5.15.12+kde+r147-1 -> 5.15.12+kde+r150-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded attica5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded babl (0.1.106-1 -> 0.1.108-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libmaxminddb (1.8.0-1 -> 1.9.1-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded libuv (1.47.0-1 -> 1.48.0-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded lmdb (0.9.31-1 -> 0.9.32-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded bind (9.18.21-1 -> 9.18.24-1)
[2024-02-23T21:26:04-0800] [ALPM] upgraded binutils (2.41-3 -> 2.42-2)
[2024-02-23T21:26:04-0800] [ALPM] upgraded bluez-libs (5.71-3 -> 5.72-2)
[2024-02-23T21:26:04-0800] [ALPM] upgraded bluez-utils (5.71-3 -> 5.72-2)
[2024-02-23T21:26:04-0800] [ALPM] upgraded boost-libs (1.83.0-4 -> 1.83.0-5)
[2024-02-23T21:26:05-0800] [ALPM] upgraded boost (1.83.0-4 -> 1.83.0-5)
[2024-02-23T21:26:06-0800] [ALPM] upgraded breeze-icons (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:06-0800] [ALPM] upgraded btrfs-progs (6.6.3-1 -> 6.7-1)
[2024-02-23T21:26:06-0800] [ALPM] upgraded c-ares (1.25.0-1 -> 1.26.0-1)
[2024-02-23T21:26:06-0800] [ALPM] upgraded capstone (4.0.2-7 -> 5.0.1-2)
[2024-02-23T21:26:06-0800] [ALPM] upgraded mpfr (4.2.1-1 -> 4.2.1-2)
[2024-02-23T21:26:06-0800] [ALPM] upgraded gcc (13.2.1-3 -> 13.2.1-5)
[2024-02-23T21:26:06-0800] [ALPM] upgraded compiler-rt (16.0.6-2 -> 16.0.6-3)
[2024-02-23T21:26:06-0800] [ALPM] upgraded clang (16.0.6-1 -> 16.0.6-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded cmake (3.28.1-1 -> 3.28.3-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded polkit (123-1 -> 124-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libcolord (1.4.6-1 -> 1.4.7-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libusb (1.0.26-2 -> 1.0.27-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded colord (1.4.6-1 -> 1.4.7-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded perl (5.38.1-1 -> 5.38.2-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded net-snmp (5.9.1-9 -> 5.9.2-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libtool (2.4.7+4+g1ec8fa28-6 -> 2.4.7+4+g1ec8fa28-7)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libheif (1.17.6-1 -> 1.17.6-3)
[2024-02-23T21:26:07-0800] [ALPM] upgraded rav1e (0.6.6-3 -> 0.7.1-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libavif (1.0.3-1 -> 1.0.4-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded nss (3.96.1-1 -> 3.97-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libsecret (0.21.2-1 -> 0.21.3-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded gnupg (2.4.3-2 -> 2.4.4-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded sane (1.2.1-5 -> 1.2.1-6)
[2024-02-23T21:26:07-0800] [ALPM] upgraded colord-sane (1.4.6-1 -> 1.4.7-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded runc (1.1.11-1 -> 1.1.12-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded containerd (1.7.11-1 -> 1.7.13-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded cronie (1.7.0-4 -> 1.7.1-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded libmicrohttpd (0.9.77-1 -> 1.0.0-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded debuginfod (0.190-1 -> 0.190-2)
[2024-02-23T21:26:07-0800] [ALPM] upgraded dnsmasq (2.89-1 -> 2.90-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded docker (1:24.0.7-1 -> 1:25.0.2-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded docker-compose (2.23.3-1 -> 2.24.5-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded fzf (0.44.1-1 -> 0.46.1-1)
[2024-02-23T21:26:07-0800] [ALPM] upgraded fakeroot (1.32.2-1 -> 1.33-2)
[2024-02-23T21:26:08-0800] [ALPM] upgraded python (3.11.6-1 -> 3.11.7-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded python-idna (3.5-1 -> 3.6-1)
[2024-02-23T21:26:08-0800] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2024-02-23T21:26:08-0800] [ALPM] upgraded pacman (6.0.2-16 -> 6.0.2-18)
[2024-02-23T21:26:08-0800] [ALPM] installed pacman-contrib (1.10.4-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded downgrade (11.3.0-1 -> 11.3.0-2)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libpaper (2.1.2-1 -> 2.1.3-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libsynctex (2023.66984-17 -> 2023.66984-19)
[2024-02-23T21:26:08-0800] [ALPM] upgraded texlive-bin (2023.66984-17 -> 2023.66984-19)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libidn (1.41-1 -> 1.42-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded dvisvgm (3.1.2-1 -> 3.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded efivar (38-3 -> 39-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded erlang-nox (26.2.1-1 -> 26.2.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded exiv2 (0.28.1-1 -> 0.28.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded imath (3.1.9-2 -> 3.1.10-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded openexr (3.2.1-1 -> 3.2.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libjxl (0.8.2-2 -> 0.9.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libplacebo (6.338.1-1 -> 6.338.2-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded mpg123 (1.32.3-1 -> 1.32.4-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libpulse (16.1-7 -> 17.0-3)
[2024-02-23T21:26:08-0800] [ALPM] upgraded libvpx (1.13.1-1 -> 1.14.0-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded sdl2 (2.28.5-1 -> 2.30.0-1)
[2024-02-23T21:26:08-0800] [ALPM] installed vapoursynth (R65-1)
[2024-02-23T21:26:08-0800] [ALPM] installed numactl (2.0.18-1)
[2024-02-23T21:26:08-0800] [ALPM] installed libfabric (1.20.0-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded openpmix (4.2.6-1 -> 4.2.9-1)
[2024-02-23T21:26:08-0800] [ALPM] installed prrte (3.0.4-1)
[2024-02-23T21:26:08-0800] [ALPM] upgraded openmpi (4.1.6-1 -> 5.0.2-2)
[2024-02-23T21:26:08-0800] [ALPM] upgraded fftw (3.3.10-4 -> 3.3.10-5)
[2024-02-23T21:26:08-0800] [ALPM] upgraded ffmpeg (2:6.1.1-1 -> 2:6.1.1-5)
[2024-02-23T21:26:08-0800] [ALPM] upgraded thin-provisioning-tools (1.0.9-2 -> 1.0.11-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded lvm2 (2.03.22-2 -> 2.03.23-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded libimobiledevice (1.3.0-9 -> 1.3.0-10)
[2024-02-23T21:26:09-0800] [ALPM] upgraded solid5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kcoreaddons5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kwidgetsaddons5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kjobwidgets5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kdbusaddons5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kconfig5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kwindowsystem5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kcrash5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kglobalaccel5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kauth5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kcodecs5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kguiaddons5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded iso-codes (4.15.0-1 -> 4.16.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded ki18n5 (5.113.0-1 -> 5.115.1-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kconfigwidgets5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded karchive5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kiconthemes5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kitemviews5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kxmlgui5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kbookmarks5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gstreamer (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded orc (0.4.34-1 -> 0.4.37-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gst-plugins-base-libs (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gst-plugins-base (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded knotifications5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kservice5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kwallet5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kcompletion5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded sonnet5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded ktextwidgets5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kded5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kio5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded kpackage5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded syndication5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded knewstuff5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded frameworkintegration5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded libxfce4util (4.18.1-1 -> 4.18.2-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded tracker3 (3.6.0-2 -> 3.6.0-3)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gtk-update-icon-cache (1:4.12.4-1 -> 1:4.12.5-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gtk3 (1:3.24.39-2 -> 1:3.24.41-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded libxfce4ui (4.18.4-1 -> 4.18.5-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded garcon (4.18.1-1 -> 4.18.2-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gc (8.2.4-1 -> 8.2.6-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gcc-fortran (13.2.1-3 -> 13.2.1-5)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gcr (3.41.1-4 -> 3.41.2-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gcr-4 (4.1.0-1 -> 4.2.0-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gdb-common (13.2-1 -> 14.1-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded gdb (13.2-1 -> 14.1-1)
[2024-02-23T21:26:09-0800] [ALPM] upgraded jasper (4.1.1-1 -> 4.2.0-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded suitesparse (7.4.0-1 -> 7.6.0-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded gegl (0.4.46-2 -> 0.4.48-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded geoclue (2.7.1-1 -> 2.7.1-2)
[2024-02-23T21:26:10-0800] [ALPM] upgraded gimp (2.10.36-1 -> 2.10.36-4)
[2024-02-23T21:26:10-0800] [ALPM] upgraded git (2.43.0-1 -> 2.43.2-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded github-cli (2.41.0-1 -> 2.43.1-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded glib2-docs (2.78.3-1 -> 2.78.4-1)
[2024-02-23T21:26:10-0800] [ALPM] upgraded glibmm-2.68 (2.78.0-1 -> 2.78.1-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded go (2:1.21.6-1 -> 2:1.22.0-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded go-ethereum (1.13.9-1 -> 1.13.12-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded graphicsmagick (1.3.42-1 -> 1.3.42-2)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gst-libav (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gst-plugins-bad-libs (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded serd (0.32.0-1 -> 0.32.2-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded lilv (0.24.22-1 -> 0.24.24-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded neon (0.32.5-2 -> 0.33.0-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded libpipewire (1:1.0.0-2 -> 1:1.0.3-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded imagemagick (7.1.1.26-1 -> 7.1.1.28-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gst-plugins-bad (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded taglib (1.13.1-1 -> 2.0-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded imlib2 (1.12.1-1 -> 1.12.2-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gst-plugins-good (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gst-plugins-ugly (1.22.8-2 -> 1.22.10-1)
[2024-02-23T21:26:11-0800] [ALPM] upgraded gtk4 (1:4.12.4-1 -> 1:4.12.5-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs-afc (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs-gphoto2 (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs-mtp (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded libnfs (5.0.2-1 -> 5.0.3-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs-nfs (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvfs-smb (1.52.2-1 -> 1.52.2-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded vim-runtime (9.1.0000-1 -> 9.1.0080-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded gvim (9.1.0000-1 -> 9.1.0080-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded htop (3.2.2-1 -> 3.3.0-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded hugo (0.121.2-1 -> 0.122.0-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded intel-gmmlib (22.3.16-1 -> 22.3.17-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded intel-graphics-compiler (1:1.0.15136.4-1 -> 1:1.0.15610.11-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded intel-compute-runtime (23.35.27191.9-1 -> 23.48.27912.11-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded intel-ucode (20231114-1 -> 20231114-2)
[2024-02-23T21:26:12-0800] [ALPM] upgraded jre17-openjdk-headless (17.0.9.u8-2 -> 17.0.10.u7-1)
[2024-02-23T21:26:12-0800] [ALPM] upgraded jre17-openjdk (17.0.9.u8-2 -> 17.0.10.u7-1)
[2024-02-23T21:26:13-0800] [ALPM] upgraded noto-fonts (1:24.1.1-1 -> 1:24.2.1-1)
[2024-02-23T21:26:13-0800] [ALPM] upgraded ttf-ibm-plex (6.3.0-1 -> 6.4.0-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded intellij-idea-community-edition (4:2023.3.2-1 -> 4:2023.3.3-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded inxi (3.3.32.1-2 -> 3.3.33.1-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded iputils (20231222-2 -> 20240117-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded python-wcwidth (0.2.12-1 -> 0.2.13-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded ipython (8.20.0-1 -> 8.21.0-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded jre11-openjdk-headless (11.0.21.u9-3 -> 11.0.22.u7-1)
[2024-02-23T21:26:15-0800] [ALPM] upgraded jre11-openjdk (11.0.21.u9-3 -> 11.0.22.u7-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded jdk11-openjdk (11.0.21.u9-3 -> 11.0.22.u7-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded jdk17-openjdk (17.0.9.u8-2 -> 17.0.10.u7-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded jre-openjdk-headless (21.u35-8 -> 21.0.2.u13-3)
[2024-02-23T21:26:16-0800] [ALPM] upgraded jre8-openjdk-headless (8.392.u08-1 -> 8.402.u06-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded jre8-openjdk (8.392.u08-1 -> 8.402.u06-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded kirigami2 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded kitemmodels5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded kwayland5 (5.113.0-1 -> 5.115.0-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-glibc (2.38-7 -> 2.39-1.1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-gcc-libs (13.2.1-3 -> 13.2.1-5)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-alsa-lib (1.2.10-2 -> 1.2.11-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-zlib (1.3-1 -> 1.3.1-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-glib2 (2.78.3-1 -> 2.78.4-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-xz (5.4.5-1 -> 5.4.6-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-openssl (1:3.2.0-1 -> 1:3.2.1-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-pam (1.5.3-1 -> 1.6.0-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-systemd (255.2-1 -> 255.3-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-libjpeg-turbo (3.0.1-1 -> 3.0.2-2)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-colord (1.4.6-1 -> 1.4.7-1)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-libidn2 (2.3.4-2 -> 2.3.7-1)
[2024-02-23T21:26:16-0800] [ALPM] installed lib32-libnghttp2 (1.59.0-2)
[2024-02-23T21:26:16-0800] [ALPM] installed lib32-libnghttp3 (1.1.0-2)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-curl (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:16-0800] [ALPM] upgraded lib32-expat (2.5.0-2 -> 2.6.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-gnutls (3.8.2-1 -> 3.8.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.274-1 -> 1.3.276-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libxml2 (2.12.3-1 -> 2.12.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-mesa (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libpng (1.6.40-2 -> 1.6.42-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-pixman (0.42.2-1 -> 0.43.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-pango (1:1.51.1-1 -> 1:1.51.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libpulse (16.1-6 -> 17.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-gtk3 (1:3.24.39-1 -> 1:3.24.41-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-imlib2 (1.12.1-1 -> 1.12.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libcurl-compat (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libcurl-gnutls (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libdecor (0.2.1-2 -> 0.2.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libdecor (0.2.1-1 -> 0.2.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libpipewire (1:1.0.0-1 -> 1:1.0.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libusb (1.0.26-2 -> 1.0.27-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-libva-mesa-driver (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-mesa-vdpau (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-mpg123 (1.32.3-1 -> 1.32.4-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-sqlite (3.44.2-1 -> 3.45.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-nss (3.96.1-1 -> 3.97-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libcamera-ipa (0.1.0-2 -> 0.2.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libcamera (0.1.0-2 -> 0.2.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded pipewire (1:1.0.0-2 -> 1:1.0.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-pipewire (1:1.0.0-1 -> 1:1.0.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-sdl2 (2.28.5-1 -> 2.30.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-sdl2_ttf (2.20.2-1 -> 2.22.0-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-vulkan-intel (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded vulkan-radeon (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded lib32-vulkan-radeon (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libadwaita (1:1.4.2-1 -> 1:1.4.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libcurl-compat (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libcurl-gnutls (8.5.0-1 -> 8.6.0-3)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libgit2 (1:1.7.1-1 -> 1:1.7.2-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libgsf (1.14.51-1 -> 1.14.52-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libhandy (1.8.2-1 -> 1.8.3-1)
[2024-02-23T21:26:17-0800] [ALPM] upgraded libmanette (0.2.6-5 -> 0.2.7-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libreoffice-fresh (7.6.4-2 -> 24.2.0-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libtraceevent (1:1.8.1-1 -> 1:1.8.2-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libtracefs (1.7.0-1 -> 1.8.0-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libva-mesa-driver (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libwpe (1.14.1-2 -> 1.14.2-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libxkbfile (1.1.2-1 -> 1.1.3-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded libxvmc (1.0.13-2 -> 1.0.14-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded licenses (20231215-1 -> 20240206-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded xorg-xkbcomp (1.4.6-1 -> 1.4.7-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded xorg-server-common (21.1.10-1 -> 21.1.11-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded xorg-server (21.1.10-1 -> 21.1.11-1)
[2024-02-23T21:26:18-0800] [ALPM] upgraded lightdm (1:1.32.0-5 -> 1:1.32.0-6)
[2024-02-23T21:26:18-0800] [ALPM] upgraded linux-firmware-whence (20231211.f2e52a1c-1 -> 20240115.9b6d0b08-2)
[2024-02-23T21:26:19-0800] [ALPM] upgraded linux-firmware (20231211.f2e52a1c-1 -> 20240115.9b6d0b08-2)
[2024-02-23T21:26:19-0800] [ALPM] upgraded mkinitcpio (37.2-1.6 -> 37.3-1)
[2024-02-23T21:26:19-0800] [ALPM] upgraded linux515 (5.15.146-1 -> 5.15.148-2)
[2024-02-23T21:26:20-0800] [ALPM] upgraded linux515-headers (5.15.146-1 -> 5.15.148-2)
[2024-02-23T21:26:21-0800] [ALPM] upgraded linux515-virtualbox-host-modules (7.0.12-12 -> 7.0.14-3)
[2024-02-23T21:26:21-0800] [ALPM] upgraded linux66 (6.6.10-1 -> 6.6.16-2)
[2024-02-23T21:26:22-0800] [ALPM] upgraded linux66-headers (6.6.10-1 -> 6.6.16-2)
[2024-02-23T21:26:22-0800] [ALPM] upgraded linux66-virtualbox-host-modules (7.0.12-34 -> 7.0.14-6)
[2024-02-23T21:26:23-0800] [ALPM] upgraded man-pages (6.05.01-2 -> 6.06-2)
[2024-02-23T21:26:23-0800] [ALPM] upgraded xcursor-breeze (5.27.6-1 -> 5.27.10-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded papirus-icon-theme (20231201-2 -> 20240201-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded manjaro-xfce-minimal-settings (20231011-1 -> 20240216-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mbedtls (3.4.1-1 -> 3.5.1-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded python-psutil (5.9.7-1 -> 5.9.8-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded menulibre (2.2.3-5 -> 2.3.2-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mesa-vdpau (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mhwd-nvidia (545.29.06-2 -> 545.29.06-4)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mhwd-nvidia-470xx (470.223.02-1 -> 470.223.02-2)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mhwd-db (0.6.5-29 -> 0.6.5-31)
[2024-02-23T21:26:25-0800] [ALPM] upgraded v86d (0.1.10-6 -> 0.1.10-7)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mhwd (0.6.5-29 -> 0.6.5-30)
[2024-02-23T21:26:25-0800] [ALPM] upgraded minizip (1:1.3-2 -> 1:1.3.1-1)
[2024-02-23T21:26:25-0800] [ALPM] upgraded mlt (7.22.0-2 -> 7.22.0-3)
[2024-02-23T21:26:25-0800] [ALPM] upgraded ndctl (77-1 -> 78-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded neovim (0.9.5-1 -> 0.9.5-2)
[2024-02-23T21:26:26-0800] [ALPM] upgraded nm-connection-editor (1.34.0-1 -> 1.36.0-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded network-manager-applet (1.34.0-1 -> 1.36.0-1)
[2024-02-23T21:26:26-0800] [ALPM] installed libngtcp2 (1.2.0-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded nodejs (21.5.0-1 -> 21.6.1-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded npm (10.3.0-1 -> 10.4.0-2)
[2024-02-23T21:26:26-0800] [ALPM] upgraded oath-toolkit (2.6.10-1 -> 2.6.11-1)
[2024-02-23T21:26:26-0800] [ALPM] installed libjuice (1.3.4-1)
[2024-02-23T21:26:26-0800] [ALPM] installed libdatachannel (0.20.1-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded vulkan-headers (1:1.3.274-1 -> 1:1.3.276-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded obs-studio (30.0.2-1 -> 30.0.2-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded opencl-clover-mesa (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded opencl-rusticl-mesa (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded openvpn (2.6.8-1 -> 2.6.9-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pangomm (2.46.3-1 -> 2.46.4-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded parole (4.18.1-1 -> 4.18.1-2)
[2024-02-23T21:26:26-0800] [ALPM] upgraded perl-ipc-run3 (0.048-11 -> 0.049-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded protobuf (25.1-1 -> 25.2-1)
[2024-02-23T21:26:26-0800] [ALPM] installed webrtc-audio-processing-1 (1.3-2)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-bluetooth (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-equalizer (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-jack (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-lirc (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-rtp (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pulseaudio-zeroconf (16.1-7 -> 17.0-3)
[2024-02-23T21:26:26-0800] [ALPM] upgraded python-jaraco.functools (3.9.0-1 -> 4.0.0-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded python-pydantic-core (1:2.14.6-1 -> 1:2.16.2-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded python-pydantic (2.5.3-1 -> 2.6.1-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded python-trove-classifiers (2024.1.8-1 -> 2024.1.31-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded py3status (3.54-1 -> 3.56-1)
[2024-02-23T21:26:26-0800] [ALPM] upgraded pypy (7.3.14-1 -> 7.3.15-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded pypy3 (7.3.14-1 -> 7.3.15-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-attrs (23.1.0-1 -> 23.2.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-cachecontrol (1:0.13.1-1 -> 1:0.14.0-2)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-cairo (1.25.1-1 -> 1.26.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-certifi (2023.11.17-1 -> 2024.02.02-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-debugpy (1.8.0-1 -> 1.8.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-dill (0.3.7-1 -> 0.3.8-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pyasn1 (0.4.8-8 -> 0.5.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pyasn1-modules (0.2.8-7 -> 0.3.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-google-auth (2.25.2-1 -> 2.26.2-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded re2 (1:20231101-1 -> 1:20240201-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-grpcio (1.60.0-1 -> 1.60.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-importlib-metadata (5.0.0-5 -> 5.1.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-nest-asyncio (1.5.8-1 -> 1.6.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-ipykernel (6.28.0-1 -> 6.29.2-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-jaraco.classes (3.3.0-1 -> 3.3.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-markupsafe (2.1.3-1 -> 2.1.4-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-jinja (1:3.1.2-4 -> 1:3.1.3-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-rpds-py (0.15.2-1 -> 0.17.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-referencing (0.32.0-1 -> 0.33.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-jsonschema (4.20.0-1 -> 4.21.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-lark-parser (1.1.8-1 -> 1.1.9-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-orjson (3.9.10-1 -> 3.9.13-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pip (23.3.2-1 -> 24.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pipx (1.4.1-1 -> 1.4.3-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pluggy (1.3.0-1 -> 1.4.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-poetry-core (1.8.1-2 -> 1.9.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-protobuf (25.1-1 -> 25.2-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pyopenssl (23.3.0-1 -> 24.0.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pytest (7.4.4-1 -> 1:7.4.4-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-pytz (2023.3.post1-1 -> 2024.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-retrying (1.3.3-16 -> 1.3.4-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-scipy (1.11.4-1 -> 1.12.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-scikit-learn (1.3.2-2 -> 1.4.1-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-termcolor (2.3.0-1 -> 2.4.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded python-waitress (2.1.2-2 -> 3.0.0-1)
[2024-02-23T21:26:27-0800] [ALPM] upgraded qpdf (11.7.0-1 -> 11.8.0-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded qt5-webengine (5.15.16-2 -> 5.15.16-3)
[2024-02-23T21:26:28-0800] [ALPM] upgraded radare2 (5.8.8-1 -> 5.8.8-2)
[2024-02-23T21:26:28-0800] [ALPM] upgraded rust (1:1.75.0-1 -> 1:1.76.0-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded rust-src (1:1.75.0-1 -> 1:1.76.0-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded rust-analyzer (20240108-1 -> 20240212-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded sdl2_image (2.8.2-1 -> 2.8.2-2)
[2024-02-23T21:26:28-0800] [ALPM] upgraded sdl2_mixer (2.6.3-2 -> 2.8.0-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded sdl2_ttf (2.20.2-1 -> 2.22.0-1)
[2024-02-23T21:26:28-0800] [ALPM] upgraded shotcut (23.12-1 -> 24.01-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded signal-desktop (6.43.2-1 -> 6.47.0-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded steam (1.0.0.78-5 -> 1.0.0.79-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded systemd-sysvcompat (255.2-2 -> 255.3-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded telegram-desktop (4.14.4-1 -> 4.14.15-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded telepathy-glib (0.24.2-2 -> 0.24.2-3)
[2024-02-23T21:26:29-0800] [ALPM] upgraded tlpui (1.6.1-1 -> 1.6.4-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded trash-cli (0.23.2.13.2-2 -> 0.23.11.10-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded udiskie (2.5.1-1 -> 2.5.2-1)
[2024-02-23T21:26:29-0800] [ALPM] upgraded valgrind (3.22.0-1 -> 3.22.0-3)
[2024-02-23T21:26:30-0800] [ALPM] upgraded virtualbox (7.0.12-1 -> 7.0.14-2)
[2024-02-23T21:26:30-0800] [ALPM] upgraded vulkan-intel (1:23.3.3-1 -> 1:23.3.5-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded wayland-protocols (1.32-1 -> 1.33-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded webkit2gtk (2.42.4-1 -> 2.42.5-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded webkit2gtk-4.1 (2.42.4-1 -> 2.42.5-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded wireless-regdb (2023.09.01-1 -> 2024.01.23-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded wireshark-cli (4.2.2-1 -> 4.2.3-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded wireshark-qt (4.2.2-1 -> 4.2.3-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xfce4-notifyd (0.9.3-1 -> 0.9.4-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xfce4-screenshooter (1.10.4-1 -> 1.10.5-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xfce4-terminal (1.1.1-2 -> 1.1.2-2)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xfce4-whiskermenu-plugin (2.8.2-1 -> 2.8.3-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xfsprogs (6.5.0-2 -> 6.6.0-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xorg-server-xephyr (21.1.10-1 -> 21.1.11-1)
[2024-02-23T21:26:30-0800] [ALPM] upgraded xorg-server-xvfb (21.1.10-1 -> 21.1.11-1)
[2024-02-23T21:26:30-0800] [ALPM] transaction completed
[2024-02-23T21:26:37-0800] [ALPM] running '20-systemd-sysusers.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-catalog.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-hwdb.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-sysctl.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-02-23T21:26:37-0800] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-02-23T21:26:38-0800] [ALPM] running '30-systemd-update.hook'...
[2024-02-23T21:26:38-0800] [ALPM] running '30-update-mime-database.hook'...
[2024-02-23T21:26:38-0800] [ALPM] running '40-update-ca-trust.hook'...
[2024-02-23T21:26:39-0800] [ALPM] running '60-depmod.hook'...
[2024-02-23T21:26:45-0800] [ALPM] running '70-dkms-install.hook'...
[2024-02-23T21:26:45-0800] [ALPM-SCRIPTLET] ==> dkms install --no-depmod rtl8192eu/1.0 -k 6.6.16-2-MANJARO
[2024-02-23T21:26:45-0800] [ALPM-SCRIPTLET] Deprecated feature: REMAKE_INITRD (/usr/src/rtl8192eu-1.0/dkms.conf)
[2024-02-23T21:28:07-0800] [ALPM-SCRIPTLET] ==> dkms install --no-depmod rtl8192eu/1.0 -k 5.15.148-2-MANJARO
[2024-02-23T21:28:07-0800] [ALPM-SCRIPTLET] Deprecated feature: REMAKE_INITRD (/var/lib/dkms/rtl8192eu/1.0/source/dkms.conf)
[2024-02-23T21:29:27-0800] [ALPM-SCRIPTLET] ==> depmod 6.6.16-2-MANJARO
[2024-02-23T21:29:28-0800] [ALPM-SCRIPTLET] ==> depmod 5.15.148-2-MANJARO
[2024-02-23T21:29:33-0800] [ALPM] running '72-texlive-fmtutil.hook'...
[2024-02-23T21:29:35-0800] [ALPM] running '73-texlive-updmap.hook'...
[2024-02-23T21:29:35-0800] [ALPM] running '80-cronie.hook'...
[2024-02-23T21:29:35-0800] [ALPM] running '90-mkinitcpio-install.hook'...
[2024-02-23T21:29:35-0800] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2024-02-23T21:29:35-0800] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2024-02-23T21:29:35-0800] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2024-02-23T21:29:35-0800] [ALPM-SCRIPTLET] ==> Starting build: '5.15.148-2-MANJARO'
[2024-02-23T21:29:35-0800] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2024-02-23T21:29:36-0800] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-02-23T21:29:37-0800] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-02-23T21:29:37-0800] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-02-23T21:29:37-0800] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET] ==> Image generation successful
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET] ==> Starting build: '5.15.148-2-MANJARO'
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-02-23T21:29:38-0800] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-02-23T21:29:39-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2024-02-23T21:29:39-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2024-02-23T21:29:39-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2024-02-23T21:29:39-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2024-02-23T21:29:41-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-02-23T21:29:42-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-02-23T21:29:42-0800] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2024-02-23T21:29:42-0800] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-02-23T21:29:43-0800] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-02-23T21:29:46-0800] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-02-23T21:29:46-0800] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET] ==> Image generation successful
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img --microcode /boot/intel-ucode.img
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET] ==> Starting build: '6.6.16-2-MANJARO'
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-02-23T21:29:51-0800] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-02-23T21:29:52-0800] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET] ==> Image generation successful
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET] ==> Starting build: '6.6.16-2-MANJARO'
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-02-23T21:29:53-0800] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2024-02-23T21:29:54-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2024-02-23T21:29:55-0800] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-02-23T21:29:56-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-02-23T21:29:57-0800] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-02-23T21:29:57-0800] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2024-02-23T21:29:57-0800] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-02-23T21:29:58-0800] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-02-23T21:30:01-0800] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-02-23T21:30:01-0800] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
[2024-02-23T21:30:06-0800] [ALPM-SCRIPTLET] ==> Image generation successful
[2024-02-23T21:30:06-0800] [ALPM] running '90-qt5-styleplugins.hook'...
[2024-02-23T21:30:06-0800] [ALPM-SCRIPTLET] [WARNING] qt5-base was updated, qt5 applications will break until qt5-styleplugins is rebuilt.
[2024-02-23T21:30:06-0800] [ALPM] running '90-update-appstream-cache.hook'...
[2024-02-23T21:30:06-0800] [ALPM-SCRIPTLET] ✔ Metadata cache was updated successfully.
[2024-02-23T21:30:06-0800] [ALPM] running '99-update-grub.hook'...
[2024-02-23T21:30:06-0800] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.6-x86_64
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2024-02-23T21:30:07-0800] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] Root filesystem isn't btrfs
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2024-02-23T21:30:08-0800] [ALPM-SCRIPTLET] done
[2024-02-23T21:30:08-0800] [ALPM] running 'dbus-reload.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'detect-old-perl-modules.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'fontconfig.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'fontconfig-32.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'gio-querymodules.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'glib-compile-schemas.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2024-02-23T21:30:08-0800] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-02-23T21:30:11-0800] [ALPM] running 'gtk4-querymodules.hook'...
[2024-02-23T21:30:11-0800] [ALPM] running 'gvfsd.hook'...
[2024-02-23T21:30:11-0800] [ALPM] running 'py3status-refresh-arch_updates.hook'...
[2024-02-23T21:30:11-0800] [ALPM] running 'texinfo-install.hook'...
[2024-02-23T21:30:12-0800] [ALPM] running 'update-desktop-database.hook'...
[2024-02-23T21:30:12-0800] [ALPM] running 'vimdoc.hook'...
[2024-02-23T21:30:12-0800] [ALPM] running 'xorg-mkfontscale.hook'...
[2024-02-23T21:32:02-0800] [PACMAN] Running 'pacman -U --config /etc/pacman.conf -- /home/kewbish/.cache/yay/libselinux/libselinux-3.6-3-x86_64.pkg.tar.zst /home/kewbish/.cache/yay/google-chrome/google-chrome-122.0.6261.69-1-x86_64.pkg.tar.zst'
[2024-02-23T21:32:05-0800] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-02-23T21:32:05-0800] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-02-23T21:32:05-0800] [ALPM] transaction started
[2024-02-23T21:32:05-0800] [ALPM] upgraded libselinux (3.6-2 -> 3.6-3)
[2024-02-23T21:32:05-0800] [ALPM] upgraded google-chrome (121.0.6167.160-1 -> 122.0.6261.69-1)
[2024-02-23T21:32:05-0800] [ALPM] transaction completed
[2024-02-23T21:32:06-0800] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-02-23T21:32:06-0800] [ALPM] running '30-systemd-update.hook'...
[2024-02-23T21:32:06-0800] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-02-23T21:32:06-0800] [ALPM] running 'py3status-refresh-arch_updates.hook'...
[2024-02-23T21:32:06-0800] [ALPM] running 'update-desktop-database.hook'...
[2024-02-23T21:32:06-0800] [PACMAN] Running 'pacman -D -q --asdeps --config /etc/pacman.conf -- libselinux'
[2024-02-23T21:32:06-0800] [PACMAN] Running 'pacman -D -q --asexplicit --config /etc/pacman.conf -- google-chrome'
Here is ls -l /usr/share/themes:
[*・゚✧ Julian dev]$ ls -l /usr/share/themes/
total 220
drwxr-xr-x  4 root root 4096 Jan  5  2022  Adwaita
drwxr-xr-x  4 root root 4096 Jan  5  2022  Adwaita-dark
drwxr-xr-x  4 root root 4096 Feb 24 08:00  adw-gtk3
drwxr-xr-x  4 root root 4096 Feb 24 08:00  adw-gtk3-dark
drwxr-xr-x  3 root root 4096 Sep 16  2021  Bright
drwxr-xr-x  3 root root 4096 Sep 16  2021  Daloa
drwxr-xr-x  6 root root 4096 Sep 16  2021  Default
drwxr-xr-x  3 root root 4096 Sep 16  2021  Default-hdpi
drwxr-xr-x  3 root root 4096 Sep 16  2021  Default-xhdpi
drwxr-xr-x  4 root root 4096 Sep 16  2021  Emacs
drwxr-xr-x 12 root root 4096 Jun 15  2022  Equilux
drwxr-xr-x 11 root root 4096 Sep 19  2021  Equilux-compact
drwxr-xr-x  4 root root 4096 Jan  5  2022  HighContrast
drwxr-xr-x  3 root root 4096 Sep 16  2021  Kokodi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-aliz
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-aliz-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-aliz-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-azul
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-azul-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-azul-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-dark-aliz
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-aliz-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-aliz-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-dark-azul
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-azul-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-azul-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-dark-pueril
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-pueril-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-pueril-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-dark-sea
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-sea-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-dark-sea-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-light-aliz
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-aliz-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-aliz-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-light-azul
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-azul-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-azul-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-light-pueril
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-pueril-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-pueril-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-light-sea
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-sea-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-light-sea-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-pueril
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-pueril-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-pueril-xhdpi
drwxr-xr-x 12 root root 4096 Nov  7 22:05  Matcha-sea
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-sea-hdpi
drwxr-xr-x  3 root root 4096 Jan  5  2022  Matcha-sea-xhdpi
drwxr-xr-x  3 root root 4096 Sep 16  2021  Moheli
drwxr-xr-x  3 root root 4096 Sep 16  2021  Raleigh
drwxr-xr-x  3 root root 4096 Sep 16  2021  Retro
drwxr-xr-x  3 root root 4096 Sep 16  2021  Smoke
drwxr-xr-x  3 root root 4096 Sep 16  2021 'ZOMG-PONIES!'
I don’t have a ~/.themes.
Any help is much appreciated!
I had export GTK_THEME=... in my .profile, and this post led me to believe it wasn’t being sourced properly:
After adding [[ -f ~/.profile ]] && . ~/.profile to ~/.bash_profile and restarting, my GTK theme has now been applied and I can switch between themes in the appearance settings again.
