I’m running plasma 5.24.2 (currently the latest update from Manjaro). I wanted to try wayland but the gtk apps (firefox, thunderbird etc) look blurry when the fractional scaling is set at 125%. Is there any way to solve this?
From arch wiki …
Might be related to this
Check in your /etc/environment
or /home/.profile
to have something like:
GDK_SCALE=2
GDK_DPI_SCALE=0.5
instead of the default
GDK_SCALE=1
GDK_DPI_SCALE=1
The solution for Firefox and Thunderbird is even easier. You just have to ensure these are started in native Wayland mode. To do this, add
export MOZ_ENABLE_WAYLAND=1
to your ~/.profile file.
Any way I can disable fractional scale in kde when I only need integer scale?
Is there any consensus on how to solve this for other apps? Firefox was easy enough to fix, but there are several other apps that still look pretty blurry for me.
Not sure abouz any other solution, but after researching it a bit I think Plasma 5.26. should bring aid: This week in KDE: non-blurry XWayland apps! – Adventures in Linux and KDE
Though those settings can probably somehow already be applied manually(as mentioned above).
