I saw a thread from a month ago (Gthumb crash after update) that reported the same error and the solution was supposedly to reboot one’s system after the update that caused that person’s crash. But I have rebooted my system many times and this does not resolve the issue.
This is likely not the same issue as that which you referenced.
Rebooting is usually recommended after performing an update, especially if system packages were a part of that update; otherwise, rebooting your machine is not a magical cure to solve all issues.
More detail will be needed in order for anyone to help.
For a start, please provide the expected system information as described (below); edit your previous (first) post to include the inxi output. Don’t forget to place it within a pre-formatted text box (see link also below).
From that point, others may be able to offer suggestions.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
