Gthumb crashes when scrolling, reboot done
so i looked on here and saw that rebooting system usually fixes gthumb and it launches and works until i scroll through my photos then it crashes any idea what i can do?
Please provide your system information as described (below) along with more detail, generally.
I’m sure someone will help when they are able.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
Please use the expected pre-formatted text enclosures for all code or command output, according to forum guidelines. :eyes: :point_down:
[MiniHowTo] Present code or command output
What is a Quark?
im new to all this so im a bit confused
Type the command given into the terminal, press Enter – then paste the output of that command into a pre-formatted text enclosure as described (above).
Hopefully, that’s less confusing.
Nonetheless I’ll also add some links to help you become more acquainted with the forum (see below).
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
Update Announcements
Technical Resources
